root@debian:/home/carl# dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-5-686 (Debian 2.6.32-48squeeze3) (dannf@debian.org) (gcc version 4.3.5 (Debian 4.3.5-4) ) #1 SMP Fri May 10 08:33:48 UTC 2013
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000100 - 000000000009f000 (usable)
[ 0.000000] BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003f680400 (usable)
[ 0.000000] BIOS-e820: 000000003f680400 - 0000000040000000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed18000 - 00000000fed1c000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed20000 - 00000000fed90000 (reserved)
[ 0.000000] BIOS-e820: 00000000feda0000 - 00000000feda6000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee10000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffe00000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.4 present.
[ 0.000000] last_pfn = 0x3f680 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 03F800000 mask FFF800000 uncachable
[ 0.000000] 2 base 03F700000 mask FFFF00000 uncachable
[ 0.000000] 3 base 0E0000000 mask FF0000000 write-combining
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7010600070106, new 0x7010600070106
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] init_memory_mapping: 0000000000000000-00000000373fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037000000 page 2M
[ 0.000000] 0037000000 - 00373fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 373fe000 @ 7000-d000
[ 0.000000] RAMDISK: 3ec61000 - 3f67583d
[ 0.000000] Allocated new RAMDISK: 00100000 - 00b1483d
[ 0.000000] Move RAMDISK from 000000003ec61000 - 000000003f67583c to 00100000 - 00b1483c
[ 0.000000] ACPI: RSDP 000fbb00 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT 3f681e00 00064 (v01 DELL M08 27D70717 ASL 00000061)
[ 0.000000] ACPI: FACP 3f681c9c 000F4 (v04 DELL M08 27D70717 ASL 00000061)
[ 0.000000] ACPI: DSDT 3f682400 0613B (v02 INT430 SYSFexxx 00001001 INTL 20050624)
[ 0.000000] ACPI: FACS 3f690c00 00040
[ 0.000000] ACPI: HPET 3f681f00 00038 (v01 DELL M08 00000001 ASL 00000061)
[ 0.000000] ACPI: APIC 3f682000 00068 (v01 DELL M08 27D70717 ASL 00000047)
[ 0.000000] ACPI: ASF! 3f681c00 0007E (v32 DELL M08 27D70717 ASL 00000061)
[ 0.000000] ACPI: MCFG 3f681fc0 0003E (v16 DELL M08 27D70717 ASL 00000061)
[ 0.000000] ACPI: SLIC 3f68209c 00176 (v01 DELL M08 27D70717 ASL 00000061)
[ 0.000000] ACPI: TCPA 3f682300 00032 (v01 00000000 ASL 00000000)
[ 0.000000] ACPI: SSDT 3f6806ef 004CC (v01 PmRef CpuPm 00003000 INTL 20050624)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 130MB HIGHMEM available.
[ 0.000000] 883MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 373fe000
[ 0.000000] low ram: 0 - 373fe000
[ 0.000000] node 0 low ram: 00000000 - 373fe000
[ 0.000000] node 0 bootmap 00009000 - 0000fe80
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00373fe000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0001000000 - 00014ced2c] TEXT DATA BSS ==> [0001000000 - 00014ced2c]
[ 0.000000] #4 [000009f000 - 0000100000] BIOS reserved ==> [000009f000 - 0000100000]
[ 0.000000] #5 [00014cf000 - 00014d5188] BRK ==> [00014cf000 - 00014d5188]
[ 0.000000] #6 [0000007000 - 0000009000] PGTABLE ==> [0000007000 - 0000009000]
[ 0.000000] #7 [0000100000 - 0000b1483d] NEW RAMDISK ==> [0000100000 - 0000b1483d]
[ 0.000000] #8 [0000009000 - 0000010000] BOOTMAP ==> [0000009000 - 0000010000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000001 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000373fe
[ 0.000000] HighMem 0x000373fe -> 0x0003f680
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000001 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003f680
[ 0.000000] On node 0 totalpages: 259614
[ 0.000000] free_area_init_node: node 0, pgdat c13b6900, node_mem_map c14d7020
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3966 pages, LIFO batch:0
[ 0.000000] Normal zone: 1736 pages used for memmap
[ 0.000000] Normal zone: 220470 pages, LIFO batch:31
[ 0.000000] HighMem zone: 262 pages used for memmap
[ 0.000000] HighMem zone: 33148 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 40000000:b8000000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 14 pages/cpu @c2000000 s34360 r0 d22984 u2097152
[ 0.000000] pcpu-alloc: s34360 r0 d22984 u2097152 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 257584
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-686 root=UUID=f5e02457-3ae4-4e21-9c00-f6debfb49124 ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000373fe:0003f680)
[ 0.000000] Memory: 1013608k/1038848k available (2509k kernel code, 24368k reserved, 1331k data, 380k init, 133640k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xffd56000 - 0xfffff000 (2724 kB)
[ 0.000000] pkmap : 0xff400000 - 0xff800000 (4096 kB)
[ 0.000000] vmalloc : 0xf7bfe000 - 0xff3fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf73fe000 ( 883 MB)
[ 0.000000] .init : 0xc13c1000 - 0xc1420000 ( 380 kB)
[ 0.000000] .data : 0xc1273703 - 0xc13c0504 (1331 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1273703 (2509 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:1280
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1994.434 MHz processor.
[ 0.008007] Calibrating delay loop (skipped), value calculated using timer frequency.. 3988.86 BogoMIPS (lpj=7977736)
[ 0.008036] Security Framework initialized
[ 0.008044] SELinux: Disabled at boot.
[ 0.008057] Mount-cache hash table entries: 512
[ 0.008274] Initializing cgroup subsys ns
[ 0.008281] Initializing cgroup subsys cpuacct
[ 0.008290] Initializing cgroup subsys devices
[ 0.008295] Initializing cgroup subsys freezer
[ 0.008299] Initializing cgroup subsys net_cls
[ 0.008342] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.008347] CPU: L2 cache: 4096K
[ 0.008353] CPU: Physical Processor ID: 0
[ 0.008357] CPU: Processor Core ID: 0
[ 0.008365] mce: CPU supports 6 MCE banks
[ 0.008380] CPU0: Thermal LVT vector (0xfa) already installed
[ 0.008386] using mwait in idle threads.
[ 0.008396] Performance Events: Core2 events, Intel PMU driver.
[ 0.008408] ... version: 2
[ 0.008412] ... bit width: 40
[ 0.008416] ... generic registers: 2
[ 0.008420] ... value mask: 000000ffffffffff
[ 0.008424] ... max period: 000000007fffffff
[ 0.008429] ... fixed-purpose events: 3
[ 0.008433] ... event mask: 0000000700000003
[ 0.008440] Checking 'hlt' instruction... OK.
[ 0.026611] ACPI: Core revision 20090903
[ 0.038533] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.038973] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.078676] CPU0: Intel(R) Core(TM)2 Duo CPU T7300 @ 2.00GHz stepping 0a
[ 0.080001] Booting processor 1 APIC 0x1 ip 0x6000
[ 0.012000] Initializing CPU#1
[ 0.012000] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.012000] CPU: L2 cache: 4096K
[ 0.012000] CPU: Physical Processor ID: 0
[ 0.012000] CPU: Processor Core ID: 1
[ 0.012000] CPU1: Thermal LVT vector (0xfa) already installed
[ 0.164092] CPU1: Intel(R) Core(TM)2 Duo CPU T7300 @ 2.00GHz stepping 0a
[ 0.164108] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[ 0.168087] Brought up 2 CPUs
[ 0.168093] Total of 2 processors activated (7977.80 BogoMIPS).
[ 0.170756] CPU0 attaching sched-domain:
[ 0.170764] domain 0: span 0-1 level MC
[ 0.170770] groups: group c2003778 cpus 0 group c2203778 cpus 1
[ 0.170785] CPU1 attaching sched-domain:
[ 0.170790] domain 0: span 0-1 level MC
[ 0.170796] groups: group c2203778 cpus 1 group c2003778 cpus 0
[ 0.170918] devtmpfs: initialized
[ 0.172090] regulator: core version 0.5
[ 0.172158] NET: Registered protocol family 16
[ 0.172339] ACPI: bus type pci registered
[ 0.172483] PCI: MCFG configuration 0: base f8000000 segment 0 buses 0 - 63
[ 0.172490] PCI: MCFG area at f8000000 reserved in E820
[ 0.172494] PCI: Using MMCONFIG for extended config space
[ 0.172499] PCI: Using configuration type 1 for base access
[ 0.173203] bio: create slab <bio-0> at 0
[ 0.173489] ACPI: EC: Look up EC in DSDT
[ 0.222072] ACPI: SSDT 3f690c80 00043 (v01 LMPWR DELLLOM 00001001 INTL 20050624)
[ 0.251440] ACPI: Interpreter enabled
[ 0.251450] ACPI: (supports S0 S3 S4 S5)
[ 0.251494] ACPI: Using IOAPIC for interrupt routing
[ 0.385396] ACPI: ACPI Dock Station Driver: 3 docks/bays found
[ 0.421435] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.421643] pci 0000:00:02.0: reg 10 64bit mmio: [0xfea00000-0xfeafffff]
[ 0.421662] pci 0000:00:02.0: reg 18 64bit mmio pref: [0xe0000000-0xefffffff]
[ 0.421675] pci 0000:00:02.0: reg 20 io port: [0xefe8-0xefef]
[ 0.421780] pci 0000:00:02.1: reg 10 64bit mmio: [0xfeb00000-0xfebfffff]
[ 0.421990] pci 0000:00:1a.0: reg 20 io port: [0x6f20-0x6f3f]
[ 0.422104] pci 0000:00:1a.1: reg 20 io port: [0x6f00-0x6f1f]
[ 0.422227] pci 0000:00:1a.7: reg 10 32bit mmio: [0xfed1c400-0xfed1c7ff]
[ 0.422357] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.422368] pci 0000:00:1a.7: PME# disabled
[ 0.422457] pci 0000:00:1b.0: reg 10 64bit mmio: [0xfe9fc000-0xfe9fffff]
[ 0.422590] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.422600] pci 0000:00:1b.0: PME# disabled
[ 0.422789] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.422799] pci 0000:00:1c.0: PME# disabled
[ 0.422991] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.423001] pci 0000:00:1c.1: PME# disabled
[ 0.423201] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.423211] pci 0000:00:1c.5: PME# disabled
[ 0.423315] pci 0000:00:1d.0: reg 20 io port: [0x6f80-0x6f9f]
[ 0.423428] pci 0000:00:1d.1: reg 20 io port: [0x6f60-0x6f7f]
[ 0.423541] pci 0000:00:1d.2: reg 20 io port: [0x6f40-0x6f5f]
[ 0.423662] pci 0000:00:1d.7: reg 10 32bit mmio: [0xfed1c000-0xfed1c3ff]
[ 0.423791] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.423801] pci 0000:00:1d.7: PME# disabled
[ 0.424102] pci 0000:00:1f.0: quirk: region 1000-107f claimed by ICH6 ACPI/GPIO/TCO
[ 0.424114] pci 0000:00:1f.0: quirk: region 1080-10bf claimed by ICH6 GPIO
[ 0.424124] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0900 (mask 007f)
[ 0.424136] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 3 PIO at 0c80 (mask 003f)
[ 0.424244] pci 0000:00:1f.1: reg 10 io port: [0x1f0-0x1f7]
[ 0.424259] pci 0000:00:1f.1: reg 14 io port: [0x3f4-0x3f7]
[ 0.424274] pci 0000:00:1f.1: reg 18 io port: [0x170-0x177]
[ 0.424289] pci 0000:00:1f.1: reg 1c io port: [0x374-0x377]
[ 0.424304] pci 0000:00:1f.1: reg 20 io port: [0x6fa0-0x6faf]
[ 0.424404] pci 0000:00:1f.2: reg 10 io port: [0x6eb0-0x6eb7]
[ 0.424420] pci 0000:00:1f.2: reg 14 io port: [0x6eb8-0x6ebb]
[ 0.424435] pci 0000:00:1f.2: reg 18 io port: [0x6ec0-0x6ec7]
[ 0.424450] pci 0000:00:1f.2: reg 1c io port: [0x6ec8-0x6ecb]
[ 0.424465] pci 0000:00:1f.2: reg 20 io port: [0x6ee0-0x6eef]
[ 0.424480] pci 0000:00:1f.2: reg 24 io port: [0xeff0-0xefff]
[ 0.424548] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.424558] pci 0000:00:1f.2: PME# disabled
[ 0.424606] pci 0000:00:1f.3: reg 10 32bit mmio: [0xfe9fbf00-0xfe9fbfff]
[ 0.424649] pci 0000:00:1f.3: reg 20 io port: [0x10c0-0x10df]
[ 0.424799] pci 0000:00:1c.0: bridge io port: [0x2000-0x2fff]
[ 0.424810] pci 0000:00:1c.0: bridge 32bit mmio: [0x44000000-0x441fffff]
[ 0.424826] pci 0000:00:1c.0: bridge 64bit mmio pref: [0x44200000-0x443fffff]
[ 0.424923] pci 0000:0c:00.0: reg 10 32bit mmio: [0xfe8fc000-0xfe8fffff]
[ 0.425104] pci 0000:0c:00.0: supports D1 D2
[ 0.425165] pci 0000:0c:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.425316] pci 0000:00:1c.1: bridge io port: [0x3000-0x3fff]
[ 0.425326] pci 0000:00:1c.1: bridge 32bit mmio: [0xfe800000-0xfe8fffff]
[ 0.425342] pci 0000:00:1c.1: bridge 64bit mmio pref: [0x44400000-0x445fffff]
[ 0.425511] pci 0000:09:00.0: reg 10 64bit mmio: [0xfe7f0000-0xfe7fffff]
[ 0.425614] pci 0000:09:00.0: reg 30 32bit mmio pref: [0xdde40000-0xdde4ffff]
[ 0.425809] pci 0000:09:00.0: PME# supported from D3hot D3cold
[ 0.425857] pci 0000:09:00.0: PME# disabled
[ 0.432255] pci 0000:00:1c.5: bridge io port: [0x4000-0x4fff]
[ 0.432265] pci 0000:00:1c.5: bridge 32bit mmio: [0xfe700000-0xfe7fffff]
[ 0.432281] pci 0000:00:1c.5: bridge 64bit mmio pref: [0x44600000-0x447fffff]
[ 0.432363] pci 0000:03:01.0: reg 10 32bit mmio: [0xfe600000-0xfe600fff]
[ 0.432427] pci 0000:03:01.0: supports D1 D2
[ 0.432433] pci 0000:03:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.432444] pci 0000:03:01.0: PME# disabled
[ 0.432521] pci 0000:03:01.4: reg 10 32bit mmio: [0xfe6ff000-0xfe6fffff]
[ 0.432537] pci 0000:03:01.4: reg 14 32bit mmio: [0xfe6fe800-0xfe6fefff]
[ 0.432638] pci 0000:03:01.4: supports D1 D2
[ 0.432644] pci 0000:03:01.4: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.432654] pci 0000:03:01.4: PME# disabled
[ 0.432769] pci 0000:00:1e.0: transparent bridge
[ 0.432779] pci 0000:00:1e.0: bridge io port: [0x5000-0x5fff]
[ 0.432789] pci 0000:00:1e.0: bridge 32bit mmio: [0xfe600000-0xfe6fffff]
[ 0.432805] pci 0000:00:1e.0: bridge 64bit mmio pref: [0x40000000-0x43ffffff]
[ 0.432884] pci_bus 0000:00: on NUMA node 0
[ 0.432894] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.433520] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIE._PRT]
[ 0.433865] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.434042] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.434237] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP06._PRT]
[ 0.476544] ACPI: PCI Interrupt Link [LNKA] (IRQs 9 10 11) *0, disabled.
[ 0.476794] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 7) *0, disabled.
[ 0.477036] ACPI: PCI Interrupt Link [LNKC] (IRQs 9 10 11) *0, disabled.
[ 0.477276] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 7 9 10 11) *0, disabled.
[ 0.477520] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.477769] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.478018] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.478266] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.478491] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.478526] vgaarb: loaded
[ 0.478560] PCI: Using ACPI for IRQ routing
[ 0.478560] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.478560] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.478560] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.484042] Switching to clocksource tsc
[ 0.487095] pnp: PnP ACPI init
[ 0.487120] ACPI: bus type pnp registered
[ 0.560712] pnp 00:0b: io resource (0x1000-0x1005) overlaps 0000:00:1f.0 BAR 13 (0x1000-0x107f), disabling
[ 0.560724] pnp 00:0b: io resource (0x1008-0x100f) overlaps 0000:00:1f.0 BAR 13 (0x1000-0x107f), disabling
[ 0.560971] pnp 00:0c: io resource (0x1006-0x1007) overlaps 0000:00:1f.0 BAR 13 (0x1000-0x107f), disabling
[ 0.560981] pnp 00:0c: io resource (0x100a-0x1059) overlaps 0000:00:1f.0 BAR 13 (0x1000-0x107f), disabling
[ 0.560991] pnp 00:0c: io resource (0x1060-0x107f) overlaps 0000:00:1f.0 BAR 13 (0x1000-0x107f), disabling
[ 0.561000] pnp 00:0c: io resource (0x1010-0x102f) overlaps 0000:00:1f.0 BAR 13 (0x1000-0x107f), disabling
[ 0.603976] pnp: PnP ACPI: found 14 devices
[ 0.603982] ACPI: ACPI bus type pnp unregistered
[ 0.603989] PnPBIOS: Disabled by ACPI PNP
[ 0.604014] system 00:05: ioport range 0xc80-0xcaf has been reserved
[ 0.604022] system 00:05: ioport range 0xcc0-0xcff could not be reserved
[ 0.604039] system 00:08: iomem range 0xfed00000-0xfed003ff has been reserved
[ 0.604054] system 00:0a: ioport range 0xcb0-0xcbb has been reserved
[ 0.604062] system 00:0a: iomem range 0xfed40000-0xfed44fff has been reserved
[ 0.604076] system 00:0b: ioport range 0x900-0x97f has been reserved
[ 0.604084] system 00:0b: ioport range 0x4d0-0x4d1 has been reserved
[ 0.604099] system 00:0c: ioport range 0xf400-0xf4fe has been reserved
[ 0.604107] system 00:0c: ioport range 0x1080-0x10bf has been reserved
[ 0.604115] system 00:0c: ioport range 0x10c0-0x10df has been reserved
[ 0.604123] system 00:0c: ioport range 0x809-0x809 has been reserved
[ 0.604137] system 00:0d: iomem range 0x0-0x9efff could not be reserved
[ 0.604146] system 00:0d: iomem range 0x9f000-0x9ffff could not be reserved
[ 0.604153] system 00:0d: iomem range 0xc0000-0xcffff could not be reserved
[ 0.604161] system 00:0d: iomem range 0xe0000-0xfffff could not be reserved
[ 0.604169] system 00:0d: iomem range 0x100000-0x3f6803ff could not be reserved
[ 0.604177] system 00:0d: iomem range 0x3f680400-0x3f6fffff has been reserved
[ 0.604185] system 00:0d: iomem range 0x3f700000-0x3f7fffff has been reserved
[ 0.604193] system 00:0d: iomem range 0x3f700000-0x3fefffff could not be reserved
[ 0.604201] system 00:0d: iomem range 0xffe00000-0xffffffff has been reserved
[ 0.604209] system 00:0d: iomem range 0xffa00000-0xffbfffff has been reserved
[ 0.604217] system 00:0d: iomem range 0xfec00000-0xfec0ffff could not be reserved
[ 0.604226] system 00:0d: iomem range 0xfee00000-0xfee0ffff has been reserved
[ 0.604234] system 00:0d: iomem range 0xfed20000-0xfed3ffff has been reserved
[ 0.604242] system 00:0d: iomem range 0xfed45000-0xfed8ffff has been reserved
[ 0.604249] system 00:0d: iomem range 0xfeda0000-0xfeda3fff has been reserved
[ 0.604257] system 00:0d: iomem range 0xfeda4000-0xfeda4fff has been reserved
[ 0.604265] system 00:0d: iomem range 0xfeda5000-0xfeda5fff has been reserved
[ 0.604273] system 00:0d: iomem range 0xfeda6000-0xfeda6fff has been reserved
[ 0.604281] system 00:0d: iomem range 0xfed18000-0xfed1bfff has been reserved
[ 0.604289] system 00:0d: iomem range 0xf8000000-0xfbffffff has been reserved
[ 0.639249] pci 0000:09:00.0: BAR 6: no parent found for of device [0xdde40000-0xdde4ffff]
[ 0.639397] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:0b
[ 0.639406] pci 0000:00:1c.0: IO window: 0x2000-0x2fff
[ 0.639419] pci 0000:00:1c.0: MEM window: 0x44000000-0x441fffff
[ 0.639430] pci 0000:00:1c.0: PREFETCH window: 0x00000044200000-0x000000443fffff
[ 0.639446] pci 0000:00:1c.1: PCI bridge, secondary bus 0000:0c
[ 0.639454] pci 0000:00:1c.1: IO window: 0x3000-0x3fff
[ 0.639467] pci 0000:00:1c.1: MEM window: 0xfe800000-0xfe8fffff
[ 0.639477] pci 0000:00:1c.1: PREFETCH window: 0x00000044400000-0x000000445fffff
[ 0.639495] pci 0000:00:1c.5: PCI bridge, secondary bus 0000:09
[ 0.639503] pci 0000:00:1c.5: IO window: 0x4000-0x4fff
[ 0.639516] pci 0000:00:1c.5: MEM window: 0xfe700000-0xfe7fffff
[ 0.639526] pci 0000:00:1c.5: PREFETCH window: 0x00000044600000-0x000000447fffff
[ 0.639547] pci 0000:03:01.0: CardBus bridge, secondary bus 0000:04
[ 0.639553] pci 0000:03:01.0: IO window: 0x005000-0x0050ff
[ 0.639563] pci 0000:03:01.0: IO window: 0x005400-0x0054ff
[ 0.639574] pci 0000:03:01.0: PREFETCH window: 0x40000000-0x43ffffff
[ 0.639585] pci 0000:03:01.0: MEM window: 0x48000000-0x4bffffff
[ 0.639596] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:03
[ 0.639604] pci 0000:00:1e.0: IO window: 0x5000-0x5fff
[ 0.639617] pci 0000:00:1e.0: MEM window: 0xfe600000-0xfe6fffff
[ 0.639627] pci 0000:00:1e.0: PREFETCH window: 0x00000040000000-0x00000043ffffff
[ 0.639665] pci 0000:00:1c.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.639676] pci 0000:00:1c.0: setting latency timer to 64
[ 0.639698] pci 0000:00:1c.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 0.639708] pci 0000:00:1c.1: setting latency timer to 64
[ 0.639728] pci 0000:00:1c.5: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 0.639738] pci 0000:00:1c.5: setting latency timer to 64
[ 0.639754] pci 0000:00:1e.0: setting latency timer to 64
[ 0.639777] pci 0000:03:01.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 0.639790] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.639797] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.639804] pci_bus 0000:0b: resource 0 io: [0x2000-0x2fff]
[ 0.639811] pci_bus 0000:0b: resource 1 mem: [0x44000000-0x441fffff]
[ 0.639817] pci_bus 0000:0b: resource 2 pref mem [0x44200000-0x443fffff]
[ 0.639824] pci_bus 0000:0c: resource 0 io: [0x3000-0x3fff]
[ 0.639831] pci_bus 0000:0c: resource 1 mem: [0xfe800000-0xfe8fffff]
[ 0.639837] pci_bus 0000:0c: resource 2 pref mem [0x44400000-0x445fffff]
[ 0.639844] pci_bus 0000:09: resource 0 io: [0x4000-0x4fff]
[ 0.639862] pci_bus 0000:09: resource 1 mem: [0xfe700000-0xfe7fffff]
[ 0.639868] pci_bus 0000:09: resource 2 pref mem [0x44600000-0x447fffff]
[ 0.639875] pci_bus 0000:03: resource 0 io: [0x5000-0x5fff]
[ 0.639882] pci_bus 0000:03: resource 1 mem: [0xfe600000-0xfe6fffff]
[ 0.639888] pci_bus 0000:03: resource 2 pref mem [0x40000000-0x43ffffff]
[ 0.639895] pci_bus 0000:03: resource 3 io: [0x00-0xffff]
[ 0.639901] pci_bus 0000:03: resource 4 mem: [0x000000-0xffffffff]
[ 0.639908] pci_bus 0000:04: resource 0 io: [0x5000-0x50ff]
[ 0.639914] pci_bus 0000:04: resource 1 io: [0x5400-0x54ff]
[ 0.639920] pci_bus 0000:04: resource 2 pref mem [0x40000000-0x43ffffff]
[ 0.639927] pci_bus 0000:04: resource 3 mem: [0x48000000-0x4bffffff]
[ 0.639985] NET: Registered protocol family 2
[ 0.640157] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.640791] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.641580] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.641956] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.641961] TCP reno registered
[ 0.642094] NET: Registered protocol family 1
[ 0.642128] pci 0000:00:02.0: Boot video device
[ 0.642151] pci 0000:00:1a.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 0.642182] pci 0000:00:1a.0: PCI INT A disabled
[ 0.642199] pci 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 0.642229] pci 0000:00:1a.1: PCI INT B disabled
[ 0.642253] pci 0000:00:1a.7: PCI INT C -> GSI 22 (level, low) -> IRQ 22
[ 0.642291] pci 0000:00:1a.7: PCI INT C disabled
[ 0.642316] pci 0000:00:1d.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 0.642346] pci 0000:00:1d.0: PCI INT A disabled
[ 0.642360] pci 0000:00:1d.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 0.642390] pci 0000:00:1d.1: PCI INT B disabled
[ 0.642403] pci 0000:00:1d.2: PCI INT C -> GSI 22 (level, low) -> IRQ 22
[ 0.642433] pci 0000:00:1d.2: PCI INT C disabled
[ 0.642455] pci 0000:00:1d.7: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 0.642481] pci 0000:00:1d.7: PCI INT A disabled
[ 0.642607] Unpacking initramfs...
[ 1.356600] Freeing initrd memory: 10322k freed
[ 1.368578] audit: initializing netlink socket (disabled)
[ 1.368606] type=2000 audit(1369156174.365:1): initialized
[ 1.376513] highmem bounce pool size: 64 pages
[ 1.376525] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 1.379811] VFS: Disk quotas dquot_6.5.2
[ 1.379945] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.380117] msgmni has been set to 1739
[ 1.380563] alg: No test for stdrng (krng)
[ 1.380676] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.380684] io scheduler noop registered
[ 1.380689] io scheduler anticipatory registered
[ 1.380694] io scheduler deadline registered
[ 1.380778] io scheduler cfq registered (default)
[ 1.381077] pcieport 0000:00:1c.0: irq 24 for MSI/MSI-X
[ 1.381098] pcieport 0000:00:1c.0: setting latency timer to 64
[ 1.381376] pcieport 0000:00:1c.1: irq 25 for MSI/MSI-X
[ 1.381396] pcieport 0000:00:1c.1: setting latency timer to 64
[ 1.381668] pcieport 0000:00:1c.5: irq 26 for MSI/MSI-X
[ 1.381687] pcieport 0000:00:1c.5: setting latency timer to 64
[ 1.382058] isapnp: Scanning for PnP cards...
[ 1.736704] isapnp: No Plug & Play device found
[ 1.739737] Linux agpgart interface v0.103
[ 1.739911] agpgart-intel 0000:00:00.0: Intel 965GM Chipset
[ 1.742833] agpgart-intel 0000:00:00.0: detected 7676K stolen memory
[ 1.752813] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[ 1.752987] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.753167] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.753930] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.754325] PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.757687] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.757703] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.757843] mice: PS/2 mouse device common for all mice
[ 1.757927] rtc_cmos 00:03: RTC can wake from S4
[ 1.758014] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 1.758060] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.758089] cpuidle: using governor ladder
[ 1.758094] cpuidle: using governor menu
[ 1.758103] No iBFT detected.
[ 1.758914] TCP cubic registered
[ 1.759237] NET: Registered protocol family 10
[ 1.760982] Mobile IPv6
[ 1.760988] NET: Registered protocol family 17
[ 1.761016] Using IPI No-Shortcut mode
[ 1.761024] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.761154] PM: Resume from disk failed.
[ 1.761177] registered taskstats version 1
[ 1.762031] rtc_cmos 00:03: setting system clock to 2013-05-21 17:09:35 UTC (1369156175)
[ 1.762148] Initalizing network drop monitor service
[ 1.762189] Freeing unused kernel memory: 380k freed
[ 1.762518] Write protecting the kernel text: 2512k
[ 1.762572] Write protecting the kernel read-only data: 924k
[ 1.800346] udev[56]: starting version 164
[ 2.122467] usbcore: registered new interface driver usbfs
[ 2.122516] usbcore: registered new interface driver hub
[ 2.123337] usbcore: registered new device driver usb
[ 2.144046] SCSI subsystem initialized
[ 2.159027] thermal LNXTHERM:01: registered as thermal_zone0
[ 2.159050] ACPI: Thermal Zone [THM] (40 C)
[ 2.205140] libata version 3.00 loaded.
[ 2.207981] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.208034] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 22 (level, low) -> IRQ 22
[ 2.208071] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 2.208079] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 2.208130] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 2.208197] ehci_hcd 0000:00:1a.7: debug port 1
[ 2.212090] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported
[ 2.212120] ehci_hcd 0000:00:1a.7: irq 22, io mem 0xfed1c400
[ 2.225019] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 2.225063] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.225070] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.225076] usb usb1: Product: EHCI Host Controller
[ 2.225082] usb usb1: Manufacturer: Linux 2.6.32-5-686 ehci_hcd
[ 2.225087] usb usb1: SerialNumber: 0000:00:1a.7
[ 2.225254] usb usb1: configuration #1 chosen from 1 choice
[ 2.225323] hub 1-0:1.0: USB hub found
[ 2.225337] hub 1-0:1.0: 4 ports detected
[ 2.225453] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 2.225481] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 2.225489] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 2.225506] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 2.225567] ehci_hcd 0000:00:1d.7: debug port 1
[ 2.229456] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 2.229894] ehci_hcd 0000:00:1d.7: irq 20, io mem 0xfed1c000
[ 2.239112] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.245020] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 2.245061] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.245068] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.245075] usb usb2: Product: EHCI Host Controller
[ 2.245080] usb usb2: Manufacturer: Linux 2.6.32-5-686 ehci_hcd
[ 2.245085] usb usb2: SerialNumber: 0000:00:1d.7
[ 2.245257] usb usb2: configuration #1 chosen from 1 choice
[ 2.245328] hub 2-0:1.0: USB hub found
[ 2.245343] hub 2-0:1.0: 6 ports detected
[ 2.245458] ata_piix 0000:00:1f.1: version 2.13
[ 2.245480] ata_piix 0000:00:1f.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 2.245551] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 2.248623] scsi0 : ata_piix
[ 2.248774] scsi1 : ata_piix
[ 2.252091] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x6fa0 irq 14
[ 2.252099] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x6fa8 irq 15
[ 2.252155] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 2.252172] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 2.252179] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 2.252200] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 2.252242] uhci_hcd 0000:00:1a.0: irq 20, io base 0x00006f20
[ 2.252311] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.252317] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.252324] usb usb3: Product: UHCI Host Controller
[ 2.252329] usb usb3: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
[ 2.252334] usb usb3: SerialNumber: 0000:00:1a.0
[ 2.252486] usb usb3: configuration #1 chosen from 1 choice
[ 2.252551] hub 3-0:1.0: USB hub found
[ 2.252565] hub 3-0:1.0: 2 ports detected
[ 2.253098] ata_piix 0000:00:1f.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 2.253109] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 2.253613] ata2: port disabled. ignoring.
[ 2.276027] tg3.c:v3.116 (December 3, 2010)
[ 2.276098] tg3 0000:09:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 2.276113] tg3 0000:09:00.0: setting latency timer to 64
[ 2.279418] firewire_ohci 0000:03:01.4: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 2.298145] tg3 0000:09:00.0: eth0: Tigon3 [partno(BCM95755m) rev a002] (PCI Express) MAC address 00:1c:23:03:53:cb
[ 2.298156] tg3 0000:09:00.0: eth0: attached PHY is 5755 (10/100/1000Base-T Ethernet) (WireSpeed[1])
[ 2.298164] tg3 0000:09:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 2.298171] tg3 0000:09:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 2.352019] firewire_ohci: Added fw-ohci device 0000:03:01.4, OHCI version 1.10
[ 2.409057] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 2.409377] scsi2 : ata_piix
[ 2.409508] scsi3 : ata_piix
[ 2.412864] ata3: SATA max UDMA/133 cmd 0x6eb0 ctl 0x6eb8 bmdma 0x6ee0 irq 17
[ 2.412878] ata4: SATA max UDMA/133 cmd 0x6ec0 ctl 0x6ec8 bmdma 0x6ee8 irq 17
[ 2.412980] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 2.413017] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 2.413025] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 2.413048] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 2.413104] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00006f00
[ 2.413175] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.413182] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.413188] usb usb4: Product: UHCI Host Controller
[ 2.413193] usb usb4: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
[ 2.413199] usb usb4: SerialNumber: 0000:00:1a.1
[ 2.413361] usb usb4: configuration #1 chosen from 1 choice
[ 2.413427] hub 4-0:1.0: USB hub found
[ 2.413442] hub 4-0:1.0: 2 ports detected
[ 2.413554] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 2.413577] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 2.413585] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 2.413602] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[ 2.413645] uhci_hcd 0000:00:1d.0: irq 20, io base 0x00006f80
[ 2.413711] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.413717] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.413723] usb usb5: Product: UHCI Host Controller
[ 2.413729] usb usb5: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
[ 2.413734] usb usb5: SerialNumber: 0000:00:1d.0
[ 2.413875] usb usb5: configuration #1 chosen from 1 choice
[ 2.413939] hub 5-0:1.0: USB hub found
[ 2.413953] hub 5-0:1.0: 2 ports detected
[ 2.414058] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 2.414074] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 2.414081] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 2.414098] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 2.414140] uhci_hcd 0000:00:1d.1: irq 21, io base 0x00006f60
[ 2.414204] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.414211] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.414217] usb usb6: Product: UHCI Host Controller
[ 2.414222] usb usb6: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
[ 2.414227] usb usb6: SerialNumber: 0000:00:1d.1
[ 2.414369] usb usb6: configuration #1 chosen from 1 choice
[ 2.414432] hub 6-0:1.0: USB hub found
[ 2.414446] hub 6-0:1.0: 2 ports detected
[ 2.414544] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 22 (level, low) -> IRQ 22
[ 2.414559] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 2.414567] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 2.414593] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 2.414634] uhci_hcd 0000:00:1d.2: irq 22, io base 0x00006f40
[ 2.414698] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.414705] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.414711] usb usb7: Product: UHCI Host Controller
[ 2.414716] usb usb7: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
[ 2.414722] usb usb7: SerialNumber: 0000:00:1d.2
[ 2.414863] usb usb7: configuration #1 chosen from 1 choice
[ 2.414926] hub 7-0:1.0: USB hub found
[ 2.414940] hub 7-0:1.0: 2 ports detected
[ 2.417454] ata1.00: ATAPI: Optiarc DVD+/-RW AD-5560A, DD11, max UDMA/33
[ 2.428735] ata1.00: configured for UDMA/33
[ 2.430253] scsi 0:0:0:0: CD-ROM Optiarc DVD+-RW AD-5560A DD11 PQ: 0 ANSI: 5
[ 2.556024] usb 2-2: new high speed USB device using ehci_hcd and address 2
[ 2.691473] usb 2-2: New USB device found, idVendor=0930, idProduct=6545
[ 2.691481] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.691488] usb 2-2: Product: DT 101 G2
[ 2.691493] usb 2-2: Manufacturer: Kingston
[ 2.691498] usb 2-2: SerialNumber: 001E4FB765BBECA1E77000FE
[ 2.691646] usb 2-2: configuration #1 chosen from 1 choice
[ 2.709128] Initializing USB Mass Storage driver...
[ 2.709311] scsi4 : SCSI emulation for USB Mass Storage devices
[ 2.709462] usbcore: registered new interface driver usb-storage
[ 2.709469] USB Mass Storage support registered.
[ 2.709478] usb-storage: device found at 2
[ 2.709482] usb-storage: waiting for device to settle before scanning
[ 2.800024] usb 2-3: new high speed USB device using ehci_hcd and address 3
[ 2.848128] firewire_core: created device fw0: GUID 424fc0001e1a7181, S400
[ 2.949356] usb 2-3: New USB device found, idVendor=148f, idProduct=3070
[ 2.949364] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.949370] usb 2-3: Product: 802.11 n WLAN
[ 2.949376] usb 2-3: Manufacturer: Ralink
[ 2.949380] usb 2-3: SerialNumber: 1.0
[ 2.949521] usb 2-3: configuration #1 chosen from 1 choice
[ 3.208116] ata3.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 3.208144] ata3.01: SATA link down (SStatus 0 SControl 300)
[ 3.216537] ata3.00: ATA-7: ST980813AS, 3.ADB, max UDMA/133
[ 3.216545] ata3.00: 156301488 sectors, multi 8: LBA48 NCQ (depth 0/32)
[ 3.232581] ata3.00: configured for UDMA/133
[ 3.232776] scsi 2:0:0:0: Direct-Access ATA ST980813AS 3.AD PQ: 0 ANSI: 5
[ 3.368020] usb 6-2: new low speed USB device using uhci_hcd and address 2
[ 3.544238] usb 6-2: New USB device found, idVendor=046d, idProduct=c03d
[ 3.544245] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.544252] usb 6-2: Product: USB-PS/2 Optical Mouse
[ 3.544257] usb 6-2: Manufacturer: Logitech
[ 3.544395] usb 6-2: configuration #1 chosen from 1 choice
[ 3.760019] ata4.01: failed to resume link (SControl 0)
[ 3.760151] ata4.00: SATA link down (SStatus 0 SControl 300)
[ 3.760181] ata4.01: SATA link down (SStatus 0 SControl 0)
[ 3.782943] b43-pci-bridge 0000:0c:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 3.782962] b43-pci-bridge 0000:0c:00.0: setting latency timer to 64
[ 3.783753] usbcore: registered new interface driver hiddev
[ 3.788053] usb 7-1: new full speed USB device using uhci_hcd and address 2
[ 3.797740] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.0/input/input1
[ 3.797874] generic-usb 0003:046D:C03D.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1d.1-2/input0
[ 3.797918] usbcore: registered new interface driver usbhid
[ 3.797924] usbhid: v2.6:USB HID core driver
[ 3.805187] sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[ 3.805194] Uniform CD-ROM driver Revision: 3.20
[ 3.805383] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 3.806750] sd 2:0:0:0: [sda] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 3.806873] sd 2:0:0:0: [sda] Write Protect is off
[ 3.806881] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.806934] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.807232] sda:
[ 3.819146] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 3.819214] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 3.851764] sda1 sda2 <
[ 3.852133] ssb: Sonics Silicon Backplane found on PCI device 0000:0c:00.0
[ 3.879221] sda5 >
[ 3.879804] sd 2:0:0:0: [sda] Attached SCSI disk
[ 3.942750] usb 7-1: New USB device found, idVendor=0b97, idProduct=7761
[ 3.942758] usb 7-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.942911] usb 7-1: configuration #1 chosen from 1 choice
[ 3.945832] hub 7-1:1.0: USB hub found
[ 3.947747] hub 7-1:1.0: 4 ports detected
[ 4.233760] usb 7-1.2: new full speed USB device using uhci_hcd and address 3
[ 4.259629] PM: Starting manual resume from disk
[ 4.259637] PM: Resume from partition 8:5
[ 4.259641] PM: Checking hibernation image.
[ 4.287467] PM: Error -22 checking image file
[ 4.287473] PM: Resume from disk failed.
[ 4.360761] usb 7-1.2: New USB device found, idVendor=0b97, idProduct=7772
[ 4.360770] usb 7-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.360776] usb 7-1.2: Product: O2Micro CCID SC Reader
[ 4.360782] usb 7-1.2: Manufacturer: O2
[ 4.360943] usb 7-1.2: configuration #1 chosen from 1 choice
[ 4.362441] kjournald starting. Commit interval 5 seconds
[ 4.362458] EXT3-fs: mounted filesystem with ordered data mode.
[ 6.013669] udev[440]: starting version 164
[ 6.481753] ACPI: SSDT 3f6810f6 00286 (v01 PmRef Cpu0Ist 00003000 INTL 20050624)
[ 6.483285] ACPI: SSDT 3f680bbb 004B6 (v01 PmRef Cpu0Cst 00003001 INTL 20050624)
[ 6.500408] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
[ 6.501212] ACPI: Lid Switch [LID]
[ 6.501339] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 6.501354] ACPI: Power Button [PBTN]
[ 6.501470] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input4
[ 6.501480] ACPI: Sleep Button [SBTN]
[ 6.535789] Monitor-Mwait will be used to enter C-1 state
[ 6.565816] Monitor-Mwait will be used to enter C-2 state
[ 6.579378] Monitor-Mwait will be used to enter C-3 state
[ 6.579397] Marking TSC unstable due to TSC halts in idle
[ 6.579586] processor LNXCPU:00: registered as cooling_device0
[ 6.588173] Switching to clocksource hpet
[ 6.653025] ACPI: SSDT 3f68137c 000C4 (v01 PmRef Cpu1Ist 00003000 INTL 20050624)
[ 6.653690] ACPI: SSDT 3f681071 00085 (v01 PmRef Cpu1Cst 00003000 INTL 20050624)
[ 6.692160] processor LNXCPU:01: registered as cooling_device1
[ 6.696479] ACPI: Battery Slot [BAT0] (battery present)
[ 6.707069] ACPI: AC Adapter [AC] (on-line)
[ 6.707159] ACPI: WMI: Mapper loaded
[ 6.707295] ACPI: Battery Slot [BAT1] (battery absent)
[ 6.748884] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 6.796908] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 6.811854] yenta_cardbus 0000:03:01.0: CardBus bridge found [1028:01f9]
[ 6.811895] yenta_cardbus 0000:03:01.0: O2: res at 0x94/0xD4: 00/ea
[ 6.811901] yenta_cardbus 0000:03:01.0: O2: enabling read prefetch/write burst
[ 6.942409] yenta_cardbus 0000:03:01.0: ISA IRQ mask 0x0cb8, PCI irq 19
[ 6.942419] yenta_cardbus 0000:03:01.0: Socket status: 30000006
[ 6.942431] yenta_cardbus 0000:03:01.0: pcmcia: parent PCI bridge I/O window: 0x5000 - 0x5fff
[ 6.942439] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x5000-0x5fff: clean.
[ 6.943025] yenta_cardbus 0000:03:01.0: pcmcia: parent PCI bridge Memory window: 0xfe600000 - 0xfe6fffff
[ 6.943032] yenta_cardbus 0000:03:01.0: pcmcia: parent PCI bridge Memory window: 0x40000000 - 0x43ffffff
[ 7.077083] i801_smbus 0000:00:1f.3: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 7.395682] [drm] Initialized drm 1.1.0 20060810
[ 7.491833] cfg80211: Using static regulatory domain info
[ 7.491839] cfg80211: Regulatory domain: US
[ 7.491844] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 7.491852] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 7.491859] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 7.491865] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 7.491871] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 7.491878] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 7.491885] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 7.492079] cfg80211: Calling CRDA for country: US
[ 7.697612] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: clean.
[ 7.700157] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: clean.
[ 7.701338] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 7.702257] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 7.703268] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 7.709212] usb-storage: device scan complete
[ 7.711187] scsi 4:0:0:0: Direct-Access Kingston DT 101 G2 PMAP PQ: 0 ANSI: 4
[ 7.712194] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 7.713281] sd 4:0:0:0: [sdb] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[ 7.716288] sd 4:0:0:0: [sdb] Write Protect is off
[ 7.716296] sd 4:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 7.716301] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 7.722638] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 7.722709] sdb: sdb1
[ 7.726651] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 7.726723] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 7.954742] i915 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 7.954755] i915 0000:00:02.0: setting latency timer to 64
[ 7.963347] i915 0000:00:02.0: irq 27 for MSI/MSI-X
[ 7.963362] [drm] set up 7M of stolen space
[ 8.021482] b43-phy0: Broadcom 4311 WLAN found (core revision 10)
[ 8.162265] phy0: Selected rate control algorithm 'minstrel'
[ 8.163779] Registered led device: b43-phy0::tx
[ 8.163821] Registered led device: b43-phy0::rx
[ 8.163859] Registered led device: b43-phy0::radio
[ 8.163962] Broadcom 43xx driver loaded [ Features: PMLS, Firmware-ID: FW13 ]
[ 8.274696] phy1: Selected rate control algorithm 'minstrel'
[ 8.276998] Registered led device: rt2800usb-phy1::radio
[ 8.277123] Registered led device: rt2800usb-phy1::assoc
[ 8.277222] Registered led device: rt2800usb-phy1::quality
[ 8.277568] usbcore: registered new interface driver rt2800usb
[ 8.345426] rt2870sta: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.358447] rtusb init --->
[ 8.358533] usbcore: registered new interface driver rt2870
[ 8.365235] input: DualPoint Stick as /devices/platform/i8042/serio1/input/input6
[ 8.388226] input: AlpsPS/2 ALPS DualPoint TouchPad as /devices/platform/i8042/serio1/input/input7
[ 8.414625] rtusb init rt2870 --->
[ 8.414635] Error: Driver 'rt2870' is already registered, aborting...
[ 8.414712] usbcore: error -16 registering interface driver rt2870
[ 8.439236] [drm] initialized overlay support
[ 9.314588] Console: switching to colour frame buffer device 160x50
[ 9.326258] fb0: inteldrmfb frame buffer device
[ 9.326262] registered panic notifier
[ 9.328832] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/LNXVIDEO:01/input/input8
[ 9.329195] ACPI: Video Device [VID1] (multi-head: yes rom: no post: no)
[ 9.329327] ACPI Warning for \_SB_.PCI0.VID2._DOD: Return Package has no elements (empty) (20090903/nspredef-433)
[ 9.329746] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/LNXVIDEO:02/input/input9
[ 9.329902] ACPI: Video Device [VID2] (multi-head: yes rom: no post: no)
[ 9.330363] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 9.679970] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[ 9.680040] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 9.881584] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input10
[ 9.901802] input: HDA Intel Mic at Ext Left Jack as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 9.901997] input: HDA Intel HP Out at Ext Left Jack as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 10.699261] Adding 2000888k swap on /dev/sda5. Priority:-1 extents:1 across:2000888k
[ 10.925705] EXT3 FS on sda1, internal journal
[ 11.091057] loop: module loaded
[ 12.249615] fuse init (API version 7.13)
[ 12.785661] tg3 0000:09:00.0: irq 28 for MSI/MSI-X
[ 12.821407] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.011384] apm: BIOS not found.
[ 14.372151] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input13
[ 16.310320] Bluetooth: Core ver 2.15
[ 16.310425] NET: Registered protocol family 31
[ 16.310429] Bluetooth: HCI device and connection manager initialized
[ 16.310435] Bluetooth: HCI socket layer initialized
[ 16.586093] Bluetooth: L2CAP ver 2.14
[ 16.586099] Bluetooth: L2CAP socket layer initialized
[ 16.705538] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.705545] Bluetooth: BNEP filters: protocol multicast
[ 16.712791] Bluetooth: RFCOMM TTY layer initialized
[ 16.712799] Bluetooth: RFCOMM socket layer initialized
[ 16.712804] Bluetooth: RFCOMM ver 1.11
[ 16.818416] Bridge firewalling registered
[ 16.935438] Bluetooth: SCO (Voice Link) ver 0.6
[ 16.935445] Bluetooth: SCO socket layer initialized
[ 17.051308] lp: driver loaded but no devices found
[ 17.092902] ppdev: user-space parallel port driver
[ 21.357079] b43 ssb0:0: firmware: requesting b43/ucode5.fw
[ 21.424878] b43 ssb0:0: firmware: requesting b43/pcm5.fw
[ 21.531076] b43 ssb0:0: firmware: requesting b43/b0g0initvals5.fw
[ 21.659925] b43 ssb0:0: firmware: requesting b43/b0g0bsinitvals5.fw
[ 21.868078] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
[ 21.960863] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 32.991909] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
[ 33.097846] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 33.992433] tg3 0000:09:00.0: PME# enabled
[ 34.024176] tg3 0000:09:00.0: irq 28 for MSI/MSI-X
[ 34.060837] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 34.588106] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
[ 34.689531] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 37.949179] wlan0: direct probe to AP a8:39:44:4e:3b:c8 (try 1)
[ 37.953345] wlan0: direct probe responded
[ 37.953355] wlan0: authenticate with AP a8:39:44:4e:3b:c8 (try 1)
[ 37.955219] wlan0: authenticated
[ 37.955290] wlan0: associate with AP a8:39:44:4e:3b:c8 (try 1)
[ 37.957887] wlan0: RX AssocResp from a8:39:44:4e:3b:c8 (capab=0x411 status=0 aid=2)
[ 37.957894] wlan0: associated
[ 37.965778] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 38.583066] padlock: VIA PadLock not detected.
[ 48.241084] wlan0: no IPv6 routers present
[ 112.651938] usb 2-3: USB disconnect, address 3
[ 235.369288] usb 2-3: new high speed USB device using ehci_hcd and address 6
[ 235.518512] usb 2-3: New USB device found, idVendor=148f, idProduct=3070
[ 235.518522] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 235.518529] usb 2-3: Product: 802.11 n WLAN
[ 235.518534] usb 2-3: Manufacturer: Ralink
[ 235.518538] usb 2-3: SerialNumber: 1.0
[ 235.518764] usb 2-3: configuration #1 chosen from 1 choice
[ 235.549815] phy2: Selected rate control algorithm 'minstrel'
[ 235.551658] Registered led device: rt2800usb-phy2::radio
[ 235.551700] Registered led device: rt2800usb-phy2::assoc
[ 235.551741] Registered led device: rt2800usb-phy2::quality
[ 235.570320] rtusb init rt2870 --->
[ 235.570326] Error: Driver 'rt2870' is already registered, aborting...
[ 235.570330] usbcore: error -16 registering interface driver rt2870
