Bonsoir,
Pour répondre à Yanlolot :
Installed: 2:1.7.7-4
Candidate: 2:1.7.7-4
Version table:
*** 2:1.7.7-4 0
500 http://ftp.fr.debian.org/debian/ squeeze/main i386 Packages
100 /var/lib/dpkg/status
le log Xorg :
[code]
X.Org X Server 1.7.7
Release Date: 2010-05-04
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.26-2-amd64 i686 Debian
Current Operating System: Linux LeHibou 2.6.35.4 #1 SMP Thu Sep 16 14:57:30 CEST 2010 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.35.4 root=UUID=mon num
Build Date: 24 August 2010 02:59:40PM
xorg-server 2:1.7.7-4 (Julien Cristau jcristau@debian.org)
Current version of pixman: 0.16.4
Before reporting problems, check http://wiki.x.org
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Sep 17 21:52:29 2010
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
(==) No Layout section. Using the first Screen section.
(==) No screen section available. Using defaults.
() |–>Screen “Default Screen Section” (0)
(**) | |–>Monitor “”
(==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
(II) Loader magic: 0x81eaca0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(++) using VT number 7
(WW) xf86OpenConsole: setpgid failed: Operation not permitted
(WW) xf86OpenConsole: setsid failed: Operation not permitted
(–) PCI:*(0:0:2:0) 8086:27a2:8086:7270 Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller rev 3, Mem @ 0x90380000/524288, 0x80000000/268435456, 0x90400000/262144, I/O @ 0x000020e0/8
(–) PCI: (0:0:2:1) 8086:27a6:8086:7270 Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller rev 3, Mem @ 0x90300000/524288
(II) Open ACPI successful (/var/run/acpid.socket)
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “dri2”
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(==) Matched intel as autoconfigured driver 0
(==) Matched vesa as autoconfigured driver 1
(==) Matched fbdev as autoconfigured driver 2
(==) Assigned the driver to the xf86ConfigLayout
(II) LoadModule: “intel”
(II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 2.9.1
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 6.0
(II) LoadModule: “vesa”
(II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
(II) Module vesa: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 2.3.0
(II) LoadModule: “fbdev”
(II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) Module fbdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 0.4.2
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, Clarkdale, Arrandale
(II) VESA: driver for VESA chipsets: vesa
(II) FBDEV: driver for framebuffer: fbdev
(II) Primary Device is: PCI 00@00:02:0
(WW) Falling back to old probe method for vesa
(WW) Falling back to old probe method for fbdev
(II) Loading sub module “fbdevhw”
(II) LoadModule: “fbdevhw”
(II) Loading /usr/lib/xorg/modules/linux/libfbdevhw.so
(II) Module fbdevhw: vendor=“X.Org Foundation"
compiled for 1.7.7, module version = 0.0.2
(EE) open /dev/fb0: No such file or directory
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 9, (OK)
drmOpenByBusid: Searching for BusID pci:0000:00:02.0
drmOpenByBusid: drmOpenMinor returns 9
drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
(II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section” for depth/fbbpp 24/32
(==) intel(0): Depth 24, (–) framebuffer bpp 32
(==) intel(0): RGB weight 888
(==) intel(0): Default visual is TrueColor
(II) intel(0): Integrated Graphics Chipset: Intel® 945GM
(–) intel(0): Chipset: “945GM”
(II) intel(0): Output VGA1 has no monitor section
(II) intel(0): Output LVDS1 has no monitor section
(II) intel(0): Output DVI1 has no monitor section
(II) intel(0): Output TV1 has no monitor section
(II) intel(0): EDID for output VGA1
(II) intel(0): EDID for output LVDS1
(II) intel(0): Manufacturer: APP Model: 9c5e Serial#: 0
(II) intel(0): Year: 2006 Week: 9
(II) intel(0): EDID Version: 1.3
(II) intel(0): Digital Display Input
(II) intel(0): Max Image Size [cm]: horiz.: 29 vert.: 19
(II) intel(0): Gamma: 2.20
(II) intel(0): No DPMS capabilities specified
(II) intel(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
(II) intel(0): First detailed timing is preferred mode
(II) intel(0): redX: 0.622 redY: 0.346 greenX: 0.333 greenY: 0.528
(II) intel(0): blueX: 0.164 blueY: 0.162 whiteX: 0.312 whiteY: 0.329
(II) intel(0): Manufacturer’s mask: 0
(II) intel(0): Supported detailed timing:
(II) intel(0): clock: 71.0 MHz Image Size: 286 x 178 mm
(II) intel(0): h_active: 1280 h_sync: 1328 h_sync_end 1360 h_blank_end 1440 h_border: 0
(II) intel(0): v_active: 800 v_sync: 803 v_sync_end 809 v_blanking: 823 v_border: 0
(II) intel(0): Unknown vendor-specific block 1
(II) intel(0): N133I1-L01
(II) intel(0): Monitor name: Color LCD
(II) intel(0): EDID (in hex):
(II) intel(0): 00ffffffffffff0006105e9c00000000
(II) intel(0): 09100103801d13780a65219f5855872a
(II) intel(0): 29505400000001010101010101010101
(II) intel(0): 010101010101bc1b00a0502017303020
(II) intel(0): 36001eb2100000180000000100061020
(II) intel(0): 00000000000000000a20000000fe004e
(II) intel(0): 31333349312d4c30310a2020000000fc
(II) intel(0): 00436f6c6f72204c43440a2020200061
(II) intel(0): Not using default mode “320x175” (doublescan mode not supported)
(II) intel(0): Not using default mode “320x200” (doublescan mode not supported)
(II) intel(0): Not using default mode “360x200” (doublescan mode not supported)
(II) intel(0): Not using default mode “320x240” (doublescan mode not supported)
(II) intel(0): Not using default mode “400x300” (doublescan mode not supported)
(II) intel(0): Not using default mode “1024x768” (interlace mode not supported)
(II) intel(0): Not using default mode “512x384” (doublescan mode not supported)
(II) intel(0): Not using default mode “1152x864” (exceeds panel dimensions)
(II) intel(0): Not using default mode “576x432” (doublescan mode not supported)
(II) intel(0): Not using default mode “1280x960” (exceeds panel dimensions)
(II) intel(0): Not using default mode “640x480” (doublescan mode not supported)
(II) intel(0): Not using default mode “1280x1024” (exceeds panel dimensions)
(II) intel(0): Not using default mode “640x512” (doublescan mode not supported)
(II) intel(0): Not using default mode “1600x1200” (exceeds panel dimensions)
(II) intel(0): Not using default mode “800x600” (doublescan mode not supported)
(II) intel(0): Not using default mode “1792x1344” (exceeds panel dimensions)
(II) intel(0): Not using default mode “896x672” (doublescan mode not supported)
(II) intel(0): Not using default mode “1856x1392” (exceeds panel dimensions)
(II) intel(0): Not using default mode “928x696” (doublescan mode not supported)
(II) intel(0): Not using default mode “1920x1440” (exceeds panel dimensions)
(II) intel(0): Not using default mode “960x720” (doublescan mode not supported)
(II) intel(0): Not using default mode “416x312” (doublescan mode not supported)
(II) intel(0): Not using default mode “1360x768” (monitor doesn’t support reduced blanking)
(II) intel(0): Not using default mode “680x384” (doublescan mode not supported)
(II) intel(0): Not using default mode “1360x768” (exceeds panel dimensions)
(II) intel(0): Not using default mode “1400x1050” (exceeds panel dimensions)
(II) intel(0): Not using default mode “700x525” (doublescan mode not supported)
(II) intel(0): Not using default mode “1440x900” (exceeds panel dimensions)
(II) intel(0): Not using default mode “720x450” (doublescan mode not supported)
(II) intel(0): Not using default mode “1600x1024” (exceeds panel dimensions)
(II) intel(0): Not using default mode “800x512” (doublescan mode not supported)
(II) intel(0): Not using default mode “1680x1050” (monitor doesn’t support reduced blanking)
(II) intel(0): Not using default mode “840x525” (doublescan mode not supported)
(II) intel(0): Not using default mode “1680x1050” (exceeds panel dimensions)
(II) intel(0): Not using default mode “1920x1080” (monitor doesn’t support reduced blanking)
(II) intel(0): Not using default mode “960x540” (doublescan mode not supported)
(II) intel(0): Not using default mode “1920x1200” (monitor doesn’t support reduced blanking)
(II) intel(0): Not using default mode “960x600” (doublescan mode not supported)
(II) intel(0): Not using default mode “2048x1536” (exceeds panel dimensions)
(II) intel(0): Not using default mode “1024x768” (doublescan mode not supported)
(II) intel(0): Printing probed modes for output LVDS1
(II) intel(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 -hsync -vsync (49.3 kHz)
(II) intel(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz)
(II) intel(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(II) intel(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) intel(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(II) intel(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz)
(II) intel(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(II) intel(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) intel(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz)
(II) intel(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
(II) intel(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) intel(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz)
(II) intel(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz)
(II) intel(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz)
(II) intel(0): EDID for output DVI1
(II) intel(0): EDID for output TV1
(II) intel(0): Output VGA1 disconnected
(II) intel(0): Output LVDS1 connected
(II) intel(0): Output DVI1 disconnected
(II) intel(0): Output TV1 disconnected
(II) intel(0): Using exact sizes for initial modes
(II) intel(0): Output LVDS1 using initial mode 1280x800
(II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
(==) intel(0): video overlay key set to 0x101fe
(==) intel(0): DPI set to (96, 96)
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(II) UnloadModule: “vesa”
(II) Unloading /usr/lib/xorg/modules/drivers/vesa_drv.so
(II) UnloadModule: “fbdev”
(II) Unloading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) UnloadModule: “fbdevhw”
(II) Unloading /usr/lib/xorg/modules/linux/libfbdevhw.so
(==) Depth 24 pixmap format is 32 bpp
(II) intel(0): [DRI2] Setup complete
() intel(0): Kernel mode setting active, disabling FBC.
() intel(0): Framebuffer compression disabled
() intel(0): Tiling enabled
() intel(0): SwapBuffers wait enabled
(==) intel(0): VideoRam: 262144 KB
(II) intel(0): Attempting memory allocation with tiled buffers.
(II) intel(0): Tiled allocation successful.
(II) UXA(0): Driver registered support for the following operations:
(II) solid
(II) copy
(II) composite (RENDER acceleration)
(==) intel(0): Backing store disabled
(==) intel(0): Silken mouse enabled
(II) intel(0): Initializing HW Cursor
(II) intel(0): No memory allocations
(II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(==) intel(0): DPMS enabled
(==) intel(0): Intel XvMC decoder disabled
(II) intel(0): Set up textured video
(II) intel(0): Set up overlay video
(II) intel(0): direct rendering: DRI2 Enabled
(–) RandR disabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
SELinux: Disabled on system, not enabling in X server
(II) AIGLX: enabled GLX_MESA_copy_sub_buffer
(II) AIGLX: enabled GLX_SGI_make_current_read
(II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
(II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
(II) AIGLX: Loaded and initialized /usr/lib/dri/i915_dri.so
(II) GLX: Initialized DRI2 GL provider for screen 0
(II) intel(0): Setting screen physical size to 338 x 211
(II) config/udev: Adding input device Power Button (/dev/input/event4)
() Power Button: Applying InputClass “evdev keyboard catchall”
(II) LoadModule: “evdev”
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 2.3.2
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 7.0
() Power Button: always reports core events
() Power Button: Device: “/dev/input/event4”
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD)
() Option “xkb_rules” “evdev”
() Option “xkb_model” “pc105”
() Option “xkb_layout” “fr”
() Option “xkb_variant” “latin9”
(II) config/udev: Adding input device Video Bus (/dev/input/event0)
() Video Bus: Applying InputClass “evdev keyboard catchall”
() Video Bus: always reports core events
() Video Bus: Device: “/dev/input/event0”
(II) Video Bus: Found keys
(II) Video Bus: Configuring as keyboard
(II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD)
(II) config/udev: Adding input device Power Button (/dev/input/event2)
() Power Button: Device: “/dev/input/event2”
(II) config/udev: Adding input device Lid Switch (/dev/input/event1)
(II) No input driver/identifier specified (ignoring)
(II) config/udev: Adding input device Sleep Button (/dev/input/event3)
() Sleep Button: Applying InputClass “evdev keyboard catchall”
() Sleep Button: always reports core events
() Sleep Button: Device: “/dev/input/event3”
(II) Sleep Button: Found keys
(II) Sleep Button: Configuring as keyboard
(II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD)
(II) config/udev: Adding input device HDA Intel Line In at Ext Left Jack (/dev/input/event9)
(II) config/udev: Adding input device HDA Intel Mic at Ext Left Jack (/dev/input/event12)
(II) config/udev: Adding input device HDA Intel HP Out at Ext Left Jack (/dev/input/event13)
(II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/event6)
() Logitech USB-PS/2 Optical Mouse: Applying InputClass “evdev pointer catchall”
() Logitech USB-PS/2 Optical Mouse: always reports core events
() Logitech USB-PS/2 Optical Mouse: Device: “/dev/input/event6”
(II) Logitech USB-PS/2 Optical Mouse: Found 3 mouse buttons
(II) Logitech USB-PS/2 Optical Mouse: Found scroll wheel(s)
(II) Logitech USB-PS/2 Optical Mouse: Found relative axes
(II) Logitech USB-PS/2 Optical Mouse: Found x and y relative axes
(II) Logitech USB-PS/2 Optical Mouse: Configuring as mouse
() Logitech USB-PS/2 Optical Mouse: YAxisMapping: buttons 4 and 5
() Logitech USB-PS/2 Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device “Logitech USB-PS/2 Optical Mouse” (type: MOUSE)
(II) Logitech USB-PS/2 Optical Mouse: initialized for relative axes.
(II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/mouse0)
(II) config/udev: Adding input device Apple Computer Apple Internal Keyboard / Trackpad (/dev/input/event10)
() Apple Computer Apple Internal Keyboard / Trackpad: Applying InputClass “evdev keyboard catchall”
() Apple Computer Apple Internal Keyboard / Trackpad: always reports core events
() Apple Computer Apple Internal Keyboard / Trackpad: Device: “/dev/input/event10”
(II) Apple Computer Apple Internal Keyboard / Trackpad: Found keys
(II) Apple Computer Apple Internal Keyboard / Trackpad: Configuring as keyboard
(II) XINPUT: Adding extended input device “Apple Computer Apple Internal Keyboard / Trackpad” (type: KEYBOARD)
(II) config/udev: Adding input device appletouch (/dev/input/event8)
() appletouch: Applying InputClass “evdev touchpad catchall”
() appletouch: Applying InputClass “touchpad catchall”
(II) LoadModule: “synaptics”
(II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
(II) Module synaptics: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 1.2.2
(II) Synaptics touchpad driver version 1.2.2
() Option “Device” “/dev/input/event8”
(II) appletouch: x-axis range 0 - 1215
(II) appletouch: y-axis range 0 - 575
(II) appletouch: pressure range 0 - 300
(II) appletouch: finger width range 0 - 0
(II) appletouch: buttons: left double triple
(–) appletouch: touchpad found
() appletouch: always reports core events
(II) XINPUT: Adding extended input device “appletouch” (type: TOUCHPAD)
() appletouch: (accel) keeping acceleration scheme 1
() appletouch: (accel) acceleration profile 0
() appletouch: (accel) acceleration factor: 2.000
() appletouch: (accel) acceleration threshold: 4
(II) config/udev: Adding input device appletouch (/dev/input/mouse1)
appletouch no synaptics event device found
() Option “Device” "/dev/input/mouse1"
Query no Synaptics: 6003C8
(–) appletouch: no supported touchpad found
(EE) appletouch Unable to query/initialize Synaptics hardware.
(EE) PreInit failed for input device “appletouch”
(II) UnloadModule: “synaptics”
(II) config/udev: Adding input device Apple Computer Apple Internal Keyboard / Trackpad (/dev/input/event11)
() Apple Computer Apple Internal Keyboard / Trackpad: Device: “/dev/input/event11”
(II) config/udev: Adding input device applesmc (/dev/input/event7)
(II) config/udev: Adding input device applesmc (/dev/input/js0)
(II) config/udev: Adding input device PC Speaker (/dev/input/event5)
(II) config/udev: Adding input device ACPI Virtual Keyboard Device (/dev/input/event14)
() ACPI Virtual Keyboard Device: Applying InputClass “evdev keyboard catchall”
() ACPI Virtual Keyboard Device: always reports core events
() ACPI Virtual Keyboard Device: Device: “/dev/input/event14”
(II) ACPI Virtual Keyboard Device: Found keys
(II) ACPI Virtual Keyboard Device: Configuring as keyboard
(II) XINPUT: Adding extended input device “ACPI Virtual Keyboard Device” (type: KEYBOARD)
(II) intel(0): EDID vendor “APP”, prod id 40030
(II) intel(0): Printing DDC gathered Modelines:
(II) intel(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 -hsync -vsync (49.3 kHz)
(II) intel(0): Modeline “1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 -hsync -vsync (49.3 kHz)
(II) config/udev: Adding input device USB Keyboard (/dev/input/event15)
() USB Keyboard: Applying InputClass “evdev keyboard catchall”
() USB Keyboard: always reports core events
() USB Keyboard: Device: “/dev/input/event15”
(II) USB Keyboard: Found keys
(II) USB Keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device " USB Keyboard" (type: KEYBOARD)
(II) config/udev: Adding input device USB Keyboard (/dev/input/event16)
() USB Keyboard: Device: “/dev/input/event16”
(II) XINPUT: Adding extended input device " USB Keyboard” (type: KEYBOARD)
() Option “xkb_variant” “latin9”[/code]
es modules, j’avais installé ceux correspondant à la famille de chipset. Je tenterai (demain) de les réinstaller pour voir.
Une fois le desktop chargé, tout est nickel. Et lorsque je me log out, le retour au bureau ne prend que 2 secondes maxi (comme ce devrait être quoi).
A fran.b :
startx en user normal est refusé et en root, me dit qu’il est déjà lancé.
Autre point : avec ou sans hal, le résultat est équivalent.
Merci et à demain pour de nouvelles pistes
(j’ai une installation de funtoo qui m’attend cette nuit)
