j’ai un raspberry avec une raspbian et apache 2.4.10, squid 2.7.
voici mon fichier squid.conf :
acl all src all
acl manager proto cache_object
acl localhost src 127.0.0.1/32
acl to_localhost dst 127.0.0.0/8 0.0.0.0/32
acl papa src 192.168.1.9/32
acl nonutil src 192.168.1.14-192.168.1.254/32
acl localnet src 192.168.0.0/16 # RFC1918 possible internal network
acl SSL_ports port 443 # https
acl SSL_ports port 563 # snews
acl SSL_ports port 873 # rsync
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 443 # https
acl Safe_ports port 70 # gopher
acl Safe_ports port 210 # wais
acl Safe_ports port 1025-65535 # unregistered ports
acl Safe_ports port 280 # http-mgmt
acl Safe_ports port 488 # gss-http
acl Safe_ports port 591 # filemaker
acl Safe_ports port 777 # multiling http
acl Safe_ports port 631 # cups
acl Safe_ports port 873 # rsync
acl Safe_ports port 901 # SWAT
acl purge method PURGE
acl CONNECT method CONNECT
acl macasuswifipapa arp 11:22:33:44:55:66
acl ipasuswifipapa src 192.168.1.9/32
acl listepapa dstdomain "/etc/squid/listepapa"
http_access allow manager localhost
http_access deny manager
http_access allow purge localhost
http_access deny purge
http_access deny !Safe_ports
http_access deny CONNECT !SSL_ports
http_access deny ipasuswifipapa !macasuswifipapa
http_access deny nonutil
http_access2 deny ipasuswifipapa !listepapa
http_access allow localnet
http_access allow localhost
http_access deny all
icp_access allow localnet
icp_access deny all
http_port 3128
hierarchy_stoplist cgi-bin ?
access_log /var/log/squid/access.log squid
refresh_pattern ^ftp: 1440 20% 10080
refresh_pattern ^gopher: 1440 0% 1440
refresh_pattern -i (/cgi-bin/|\?) 0 0% 0
refresh_pattern (Release|Packages(.gz)*)$ 0 20% 2880
refresh_pattern . 0 20% 4320
acl shoutcast rep_header X-HTTP09-First-Line ^ICY.[0-9]
upgrade_http0.9 deny shoutcast
acl apache rep_header Server ^Apache
broken_vary_encoding allow apache
extension_methods REPORT MERGE MKACTIVITY CHECKOUT
error_directory /usr/share/squid/errors/fr
hosts_file /etc/hosts
coredump_dir /var/spool/squid
Le problème est dans la gestion des erreurs :
site présent dans la liste blanche : accès autorisé (http ou https)
site absent de la liste blanche : 2 comportements différents ->
1.http : envoi d’une page d’erreur de squid (ERR_ACCESS_DENIED)
2.https : c’est firefox qui dit que le proxy refuse la connexion
Je voudrais que la page d’erreur de squid soit appelée
dans les deux cas (je l’ai modifiée pour qu’elle lance un traitement
particulier)
Merci de votre aide
