Bonsoir,
J’ai ce message :
● squid.service - LSB: Squid HTTP Proxy version 3.x
Loaded: loaded (/etc/init.d/squid; generated; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2017-10-04 20:24:25 CEST; 13min ago
Docs: man:systemd-sysv-generator(8)
Process: 15593 ExecStart=/etc/init.d/squid start (code=exited, status=3)
oct. 04 20:24:25 serveur-debian systemd[1]: Starting LSB: Squid HTTP Proxy version 3.x...
oct. 04 20:24:25 serveur-debian squid[15593]: FATAL: Error Directory /usr/share/squid3/errors/French: (2) No such file or directory ... failed!
oct. 04 20:24:25 serveur-debian systemd[1]: squid.service: Control process exited, code=exited status=3
oct. 04 20:24:25 serveur-debian systemd[1]: Failed to start LSB: Squid HTTP Proxy version 3.x.
oct. 04 20:24:25 serveur-debian systemd[1]: squid.service: Unit entered failed state.
oct. 04 20:24:25 serveur-debian systemd[1]: squid.service: Failed with result 'exit-code'.
Et puis j’ai çà aussi :
# du -s /var/spool/*
24 /var/spool/cron
8 /var/spool/cups
20 /var/spool/exim4
0 /var/spool/mail
4 /var/spool/rsyslog
4 /var/spool/samba
4 /var/spool/squid
1203584 /var/spool/squid3
