Bonsoir,
Je souhaite me connecter à ma raspberry en ssh via internet, j’y arrive bien en local de mon PC avec un:
J’ai toute fois noté des changements de port dans auth.log je ne sais pas si c’est normal, en effet je me connecte en ssh sur le 22222 et j’ai ce type de ligne:
et le numéro de port change à chaque authentification. En tout cas en me connectant sous la forme :
J’ai:
OpenSSH_5.9p1 Debian-5ubuntu1, OpenSSL 1.0.1 14 Mar 2012
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to 88.141.111.111 [88.141.111.111] port 22222.
debug1: connect to address 88.141.111.111 port 22222: Connection timed out
ssh: connect to host 88.141.111.111 port 22222: Connection timed out
L’ip 88.141.111.111 est celle donné par mon-ip.com par exemple.
Mon /etc/ssh/ssh_config
[code]# This is the ssh client system-wide configuration file. See
ssh_config(5) for more information. This file provides defaults for
users, and the values can be changed in per-user configuration files
or on the command line.
Configuration data is parsed as follows:
1. command line options
2. user-specific file
3. system-wide file
Any configuration value is only changed the first time it is set.
Thus, host-specific definitions should be at the beginning of the
configuration file, and defaults at the end.
Site-wide defaults for some commonly used options. For a comprehensive
list of available options, their meanings and defaults, please see the
ssh_config(5) man page.
Host *
ForwardAgent no
ForwardX11 no
ForwardX11Trusted yes
RhostsRSAAuthentication no
RSAAuthentication yes
PasswordAuthentication yes
HostbasedAuthentication no
GSSAPIAuthentication no
GSSAPIDelegateCredentials no
GSSAPIKeyExchange no
GSSAPITrustDNS no
BatchMode no
CheckHostIP yes
AddressFamily any
ConnectTimeout 0
StrictHostKeyChecking ask
IdentityFile ~/.ssh/identity
IdentityFile ~/.ssh/id_rsa
IdentityFile ~/.ssh/id_dsa
Port 22
Protocol 2,1
Cipher 3des
Ciphers aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc
MACs hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160
EscapeChar ~
Tunnel no
TunnelDevice any:any
PermitLocalCommand no
VisualHostKey no
ProxyCommand ssh -q -W %h:%p gateway.example.com
SendEnv LANG LC_*
HashKnownHosts yes
GSSAPIAuthentication yes
(J’ai pas bien compris si je devais modifié ce numéro de port là aussi, en tout cas en local ça marche )
/etc/hosts:
[code]127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
127.0.1.1 raspberrypi
Si vous avez une idée, ou besoin d’info supplémentaire dites moi les commandes je suis novice.
Merci de votre attention
