Je suis sous debian , et j ai du redemarre en rescue mode parceque mon serveur inaccessible.
J ai mis off ufw
Mais pour le moment je n<ai rien trouve
Voici mes logs auth:
Jun 4 11:08:01 ns4000799 CRON[32627]: pam_unix(cron:session): session opened for user root by (uid=0)
Jun 4 11:08:01 ns4000799 CRON[32628]: pam_unix(cron:session): session opened for user root by (uid=0)
Jun 4 11:08:01 ns4000799 CRON[32627]: pam_unix(cron:session): session closed for user root
Jun 4 11:08:01 ns4000799 CRON[32628]: pam_unix(cron:session): session closed for user root
Jun 4 21:30:34 ns4000799 sshd[2937]: error: Bind to port 22 on 0.0.0.0 failed: Address already in use.
Jun 4 21:30:34 ns4000799 sshd[2936]: Server listening on 0.0.0.0 port 22.
Jun 4 21:30:34 ns4000799 sshd[2936]: Server listening on :: port 22.
Jun 4 21:30:34 ns4000799 sshd[2937]: fatal: listen on [::]:22: Address already in use
Voici mon sshd_conf si ca peut aider:
Package generated configuration file
See the sshd_config(5) manpage for details
What ports, IPs and protocols we listen for
Port 22
Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
Lifetime and size of ephemeral version 1 server key
KeyRegenerationInterval 3600
ServerKeyBits 768
Logging
SyslogFacility AUTH
LogLevel INFO
Authentication:
LoginGraceTime 120
PermitRootLogin yes
StrictModes yes
RSAAuthentication yes
PubkeyAuthentication yes
#AuthorizedKeysFile %h/.ssh/authorized_keys
Don’t read the user’s ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
For this to work you will also need host keys in /etc/ssh_known_hosts
RhostsRSAAuthentication no
similar for protocol version 2
HostbasedAuthentication no
Uncomment if you don’t trust ~/.ssh/known_hosts for RhostsRSAAuthentication
#IgnoreUserKnownHosts yes
To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
Change to yes to enable challenge-response passwords (beware issues with
some PAM modules and threads)
ChallengeResponseAuthentication no
Change to no to disable tunnelled clear text passwords
#PasswordAuthentication yes
Kerberos options
#KerberosAuthentication no
#KerberosGetAFSToken no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
Allow client to pass locale environment variables
AcceptEnv LANG LC_*
Subsystem sftp /usr/lib/openssh/sftp-server
Set this to ‘yes’ to enable PAM authentication, account processing,
and session processing. If this is enabled, PAM authentication will
be allowed through the ChallengeResponseAuthentication and
PasswordAuthentication. Depending on your PAM configuration,
PAM authentication via ChallengeResponseAuthentication may bypass
the setting of “PermitRootLogin without-password”.
If you just want the PAM account and session checks to run without
PAM authentication, then enable this but set PasswordAuthentication
and ChallengeResponseAuthentication to ‘no’.
UsePAM yes
