STRETCH quelques scories
salut,
root@debian:/# lsb_release --all
No LSB modules are available.
Distributor ID:	Debian
Description:	Debian GNU/Linux testing-updates (sid)
Release:	testing-updates
Codename:	sid
root@debian:/# uname --all
Linux debian 4.4.0-1-amd64 #1 SMP Debian 4.4.6-1 (2016-03-17) x86_64 GNU/Linux
root@debian:/# cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda1 during installation
UUID=78ec612e-d1d9-4c88-88ec-17d9b0815a8f /               ext4    errors=remount-ro 0       1
# /home was on /dev/sda6 during installation
UUID=0231cd69-6248-497c-a18c-4d5c92666f35 /home           ext4    defaults        0       2
# swap was on /dev/sda5 during installation
UUID=a101ccab-5f9a-4f81-bee3-73cda7f5ad0a none            swap    sw              0       0
/dev/sr0        /media/cdrom0   udf,iso9660 user,noauto     0       0
root@debian:/# blkid
    /dev/sda1: UUID="78ec612e-d1d9-4c88-88ec-17d9b0815a8f" TYPE="ext4" PARTUUID="00038c4c-01"
    /dev/sda5: UUID="a101ccab-5f9a-4f81-bee3-73cda7f5ad0a" TYPE="swap" PARTUUID="00038c4c-05"
    /dev/sda6: UUID="0231cd69-6248-497c-a18c-4d5c92666f35" TYPE="ext4" PARTUUID="00038c4c-06"
Quelques erreurs dans le démarrage
avril 20 17:06:14 debian systemd[1]: sys-kernel-config.mount: Start request repeated too quickly.
avril 20 17:06:14 debian systemd[1]: Failed to mount Configuration File System.
avril 20 17:06:14 debian systemd[1]: systemd-binfmt.service: Start request repeated too quickly.
avril 20 17:06:14 debian systemd[1]: Failed to start Set Up Additional Binary Formats.
avril 20 17:06:14 debian systemd[1]: systemd-hwdb-update.service: Start request repeated too quickly.
avril 20 17:06:14 debian systemd[1]: Failed to start Rebuild Hardware Database.
avril 20 17:06:14 debian systemd[1]: systemd-fsck-root.service: Start request repeated too quickly.
avril 20 17:06:14 debian systemd[1]: Failed to start File System Check on Root Device.
avril 20 17:06:14 debian systemd[1]: Starting Show Plymouth Boot Screen...
avril 20 17:06:14 debian systemd[1]: sys-fs-fuse-connections.mount: Start request repeated too quickly.
avril 20 17:06:14 debian systemd[1]: Failed to mount FUSE Control File System.
avril 20 17:06:15 debian systemd[1]: Reached target Sound Card.
avril 20 17:06:15 debian systemd[1]: Started Show Plymouth Boot Screen.
avril 20 17:06:15 debian systemd[1]: Found device Hitachi_HTS725032A9A364 5.
avril 20 17:06:15 debian systemd[1]: Activating swap /dev/disk/by-uuid/a101ccab-5f9a-4f81-bee3-73cda7f5ad0a...
avril 20 17:06:15 debian systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
avril 20 17:06:15 debian systemd[1]: Starting Load/Save RF Kill Switch Status...
avril 20 17:06:15 debian systemd[1]: sys-fs-fuse-connections.mount: Start request repeated too quickly.
avril 20 17:06:15 debian systemd[1]: Failed to mount FUSE Control File System.
avril 20 17:06:15 debian systemd[1]: sys-kernel-config.mount: Start request repeated too quickly.
avril 20 17:06:15 debian systemd[1]: Failed to mount Configuration File System.
avril 20 17:06:15 debian systemd[1]: Starting Show Plymouth Boot Screen...
avril 20 17:06:15 debian systemd[1]: systemd-fsck-root.service: Start request repeated too quickly.
avril 20 17:06:15 debian systemd[1]: Failed to start File System Check on Root Device.
avril 20 17:06:15 debian systemd[1]: systemd-binfmt.service: Start request repeated too quickly.
avril 20 17:06:15 debian systemd[1]: Failed to start Set Up Additional Binary Formats.
avril 20 17:06:15 debian systemd[1]: systemd-hwdb-update.service: Start request repeated too quickly.
avril 20 17:06:15 debian systemd[1]: Failed to start Rebuild Hardware Database.
avril 20 17:06:15 debian kernel: Bluetooth: Core ver 2.21
avril 20 17:06:15 debian kernel: NET: Registered protocol family 31
avril 20 17:06:15 debian kernel: Bluetooth: HCI device and connection manager initialized
avril 20 17:06:15 debian kernel: Bluetooth: HCI socket layer initialized
avril 20 17:06:15 debian kernel: Bluetooth: L2CAP socket layer initialized
avril 20 17:06:15 debian kernel: Bluetooth: SCO socket layer initialized
avril 20 17:06:15 debian kernel: Adding 7852028k swap on /dev/sda5.  Priority:-1 extents:1 across:7852028k FS
avril 20 17:06:15 debian systemd[1]: Activated swap /dev/disk/by-uuid/a101ccab-5f9a-4f81-bee3-73cda7f5ad0a.
avril 20 17:06:15 debian systemd[1]: Reached target Swap.
avril 20 17:06:15 debian systemd[1]: Found device Hitachi_HTS725032A9A364 6.
avril 20 17:06:15 debian systemd[1]: Starting File System Check on /dev/disk/by-uuid/0231cd69-6248-497c-a18c-4d5c92666f35...
avril 20 17:06:15 debian systemd[1]: plymouth-start.service: Start request repeated too quickly.
avril 20 17:06:15 debian systemd[1]: Failed to start Show Plymouth Boot Screen.
avril 20 17:06:15 debian systemd[1]: systemd-ask-password-console.path: Start request repeated too quickly.
avril 20 17:06:15 debian systemd[1]: Failed to start Dispatch Password Requests to Console Directory Watch.
avril 20 17:06:15 debian systemd-udevd[267]: Process '/usr/sbin/alsactl -E HOME=/run/alsa restore 1' failed with exit code 19.
avril 20 17:06:15 debian kernel: usbcore: registered new interface driver btusb
avril 20 17:06:15 debian kernel: uvcvideo: Found UVC 1.00 device 2SF022 (0bda:5801)
avril 20 17:06:15 debian kernel: input: 2SF022 as /devices/pci0000:00/0000:00:12.2/usb1/1-3/1-3:1.0/input/input17
avril 20 17:06:15 debian kernel: usbcore: registered new interface driver uvcvideo
avril 20 17:06:15 debian kernel: USB Video Class driver (1.1.1)
avril 20 17:06:15 debian systemd[1]: Started File System Check Daemon to report status.
Pas de conséquences visibles
kesako :worried:
salut,
en cherchant systemd Start request repeated too quickly, ce retour
une collision a priori sans conséquence entre laptop-mode-tools et systemd
réf : FS#48267 - [systemd] “Start request repeated too quickly” after update to 229.2
ok merci.
je n’ai plus ces erreurs
apt-cache policy laptop*
laptop-detect:
Installé : (aucun)
Candidat : 0.13.7
Table de version :
0.13.7 500
500 http://httpredir.debian.org/debian stretch/main amd64 Packages
laptop-mode-tools:
Installé : 1.69.2-1
Candidat : 1.69.2-1
Table de version :
*** 1.69.2-1 500
500 http://httpredir.debian.org/debian stretch/main i386 Packages
100 /var/lib/dpkg/status
root@debian:/# apt-cache policy systemd
systemd:
Installé : 229-6
Candidat : 229-6
Table de version :
*** 229-6 500
j’ai pas compris pourquoi ce message du mois d’avril est ressorti en tête du forum aujourd"hui :grinning:
