hello …
je bloque sur une conf sudo.
J’aimerais pouvoir faire un sudo su tout en gardant mon home initial (pour pouvoir par exemple garder l’historique bash de mon user etc …)
voici mon sudoers :
[code]## Sudoers allows particular users to run various commands as
the root user, without needing the root password.
Examples are provided at the bottom of the file for collections
of related commands, which can then be delegated out to particular
users or groups.
This file must be edited with the ‘visudo’ command.
Host Aliases
Groups of machines. You may prefer to use hostnames (perhaps using
wildcards for entire domains) or IP addresses instead.
Host_Alias FILESERVERS = fs1, fs2
Host_Alias MAILSERVERS = smtp, smtp2
User Aliases
These aren’t often necessary, as you can use regular groups
(ie, from files, LDAP, NIS, etc) in this file - just use %groupname
rather than USERALIAS
User_Alias ADMINS = jsmith, mikem
Command Aliases
These are groups of related commands…
Networking
Cmnd_Alias NETWORKING = /sbin/route, /sbin/ifconfig, /bin/ping, /sbin/dhclient, /usr/bin/net, /sbin/iptables, /usr/bin/rfcomm, /usr/bin/wvdial, /sbin/iwconfig, /sbin/mii-tool
Installation and management of software
Cmnd_Alias SOFTWARE = /bin/rpm, /usr/bin/up2date, /usr/bin/yum
Services
Cmnd_Alias SERVICES = /sbin/service, /sbin/chkconfig
Updating the locate database
Cmnd_Alias LOCATE = /usr/bin/updatedb
Storage
Cmnd_Alias STORAGE = /sbin/fdisk, /sbin/sfdisk, /sbin/parted, /sbin/partprobe, /bin/mount, /bin/umount
Delegating permissions
Cmnd_Alias DELEGATING = /usr/sbin/visudo, /bin/chown, /bin/chmod, /bin/chgrp
Processes
Cmnd_Alias PROCESSES = /bin/nice, /bin/kill, /usr/bin/kill, /usr/bin/killall
Drivers
Cmnd_Alias DRIVERS = /sbin/modprobe
Defaults specification
Disable "ssh hostname sudo ", because it will show the password in clear.
You have to run "ssh -t hostname sudo ".
Defaults requiretty
Refuse to run if unable to disable echo on the tty. This setting should also be
changed in order to be able to use sudo without a tty. See requiretty above.
Defaults !visiblepw
Preserving HOME has security implications since many programs
use it when searching for configuration files.
Defaults always_set_home
Defaults env_reset
Defaults env_keep = "COLORS DISPLAY HOSTNAME HISTSIZE INPUTRC KDEDIR LS_COLORS"
Defaults env_keep += "MAIL PS1 PS2 QTDIR USERNAME LANG LC_ADDRESS LC_CTYPE"
Defaults env_keep += "LC_COLLATE LC_IDENTIFICATION LC_MEASUREMENT LC_MESSAGES"
Defaults env_keep += "LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER LC_TELEPHONE"
Defaults env_keep += “LC_TIME LC_ALL LANGUAGE LINGUAS _XKB_CHARSET XAUTHORITY”
Adding HOME to env_keep may enable a user to run unrestricted
commands via sudo.
Defaults env_keep += “HOME”
Defaults secure_path = /sbin:/bin:/usr/sbin:/usr/bin
Next comes the main part: which users can run what software on
which machines (the sudoers file can be shared between multiple
systems).
Syntax:
user MACHINE=COMMANDS
The COMMANDS section may have other options added to it.
Allow root to run any commands anywhere
ALL ALL=(ALL) NOPASSWD: ALL
Allows members of the ‘sys’ group to run networking, software,
service management apps and more.
%sys ALL = NETWORKING, SOFTWARE, SERVICES, STORAGE, DELEGATING, PROCESSES, LOCATE, DRIVERS
Allows people in group wheel to run all commands
%wheel ALL=(ALL) ALL
Same thing without a password
%wheel ALL=(ALL) NOPASSWD: ALL
Allows members of the users group to mount and unmount the
cdrom as root
%users ALL=/sbin/mount /mnt/cdrom, /sbin/umount /mnt/cdrom
Allows members of the users group to shutdown this system
%users localhost=/sbin/shutdown -h now
Read drop-in files from /etc/sudoers.d (the # here does not mean a comment)
#includedir /etc/sudoers.d
le .bashrc de mon root :
[code]# Source global definitions
if [ -f /etc/bashrc ]; then
. /etc/bashrc
fi
Global variables
export PATH=/opt/ant/bin:/opt/jdk/bin:$PATH
export ANT_HOME=/opt/ant
export JAVA_HOME=/opt/jdk
Various system settings
export LANG=“en_US.UTF-8"
export EDITOR=/usr/bin/vim
export HISTTIMEFORMAT=”%F %T "
export HISTFILE=~/.bash_history
export HISTSIZE=5000
export SAVEHIST=5000
export GREP_OPTIONS=’–color=auto’
export GREP_COLOR=‘1;32’
Aliases
alias dos2unix='dos2unix -k’
alias scp='scp -p’
alias rm='rm -i’
alias mv='mv -i’
alias cp='cp -ip’
alias ls='ls --color=auto’
alias ll=‘ls -la’
#alias top='top -c -d 05.00’
alias top='htop -d 50’
alias htop=‘htop -d 50’
Colors used for prompt
NORMAL=$’\e[0m’
RED=$’\e[0;31m’
LRED=$’\e[1;31m’
GREEN=$’\e[0;32m’
LGREEN=$’\e[1;32m’
YELLOW=$’\e[0;33m’
LYELLOW=$’\e[1;33m’
BLUE=$’\e[0;34m’
LBLUE=$’\e[1;34m’
MAGENTA=$’\e[0;35m’
LMAGENTA=$’\e[1;35m’
CYAN=$’\e[0;36m’
LCYAN=$’\e[1;36m’
WHITE=$’\e[0;37m’
LWHITE=$’\e[1;37m’
Prompt displayed as <17:18>[root@hostname:/opt]# with colors
#export PS1="$LBLUE<$CYAN\t$LBLUE>[$LRED\u@\h$LBLUE:$YELLOW\w$LBLUE]$LWHITE#$NORMAL “
export PS1=”[$LBLUE]<[$CYAN]\t[$LBLUE]>[[$LRED]\u@\h[$LBLUE]:[$YELLOW]\w[$LBLUE]][$LWHITE]#[$NORMAL] "
c’est quoi le soucis ???
