Bonjour, je suis sur Lenny, et je souhaite supprimer le “tap to click” , très désagréable, sur mon Touchpad. J’ ai déjà eu ce genre de problème, sur d’ autres distributions, il suffisait de modifier ces lignes dans son xorg.conf (à la rubrique “synaptic”)
Option "MaxTapTime" "0"
Option "MaxTapMove" "180"
Mais je n’ ai pas cette rubrique :
[code] xorg.conf (X.Org X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
Option “AllowGLXWithComposite” "true"
Option “RenderAccel” "true"
Option “AccelMethod” “XAA”
Que puis je faire ? Créer une section “synaptic” , et insérer les deux lignes précédement citées ?
Merci pour votre aide.
