hello
bon je tente d’aider un team qui heberge son serveur chez ovh.
je tente d’y mettre une debian avec un kernel propre a debian
le problème c’est que le kernel n’aparrait pas dans la list de dpkg ![]()
grub 2 est installer
ls /boot/
boot.0800 bzImage-2.6.34.6-xxxx-grs-ipv6-64 initrd.img-2.6.32-5-amd64 System.map-2.6.34.6-xxxx-grs-ipv6-64
boot.0801 config-2.6.32-5-amd64 map vmlinuz-2.6.32-5-amd64
boot.0810 grub System.map-2.6.32-5-amd64
dpkg -l |grep linux-image
rc linux-image-2.6.26-2-amd64 2.6.26-26lenny2 Linux 2.6.26 image on AMD64
ii linux-image-2.6.32-5-amd64 2.6.32-31 Linux 2.6.32 for 64-bit PCs
dpkg -l |grep bzImage
cat /boot/grub/grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
load_env
fi
set default="0"
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
insmod raid
insmod mdraid
insmod part_msdos
insmod part_msdos
insmod ext2
set root='(md1)'
search --no-floppy --fs-uuid --set 31359d64-af1c-4247-96e0-d319ee9a6448
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=640x480
load_video
insmod gfxterm
fi
terminal_output gfxterm
insmod raid
insmod mdraid
insmod part_msdos
insmod part_msdos
insmod ext2
set root='(md1)'
set locale_dir=($root)/boot/grub/locale
set lang=fr
insmod gettext
set timeout=5
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=cyan/blue
set menu_color_highlight=white/blue
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/06_OVHkernel ###
menuentry "Debian GNU/Linux, OVH kernel 2.6.34.6-xxxx-grs-ipv6-64" {
insmod raid
insmod mdraid
insmod part_msdos
insmod part_msdos
insmod ext2
set root='(md1)'
linux /boot/bzImage-2.6.34.6-xxxx-grs-ipv6-64 root=/dev/md1 ro
### END /etc/grub.d/06_OVHkernel ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Debian GNU/Linux, avec Linux 2.6.32-5-amd64' --class debian --class gnu-linux --class gnu --class os {
insmod raid
insmod mdraid
insmod part_msdos
insmod part_msdos
insmod ext2
set root='(md1)'
echo 'Chargement de Linux 2.6.32-5-amd64 ...'
linux /boot/vmlinuz-2.6.32-5-amd64 root=UUID=31359d64-af1c-4247-96e0-d319ee9a6448 ro
echo 'Chargement du disque m�moire initial ...'
initrd /boot/initrd.img-2.6.32-5-amd64
menuentry 'Debian GNU/Linux, avec Linux 2.6.32-5-amd64 (mode de d�pannage)' --class debian --class gnu-linux --class gnu --class os {
insmod raid
insmod mdraid
insmod part_msdos
insmod part_msdos
insmod ext2
set root='(md1)'
linux /boot/vmlinuz-2.6.32-5-amd64 root=UUID=31359d64-af1c-4247-96e0-d319ee9a6448 ro single
menuentry 'Debian GNU/Linux, avec Linux 2.6.26-2-amd64' --class debian --class gnu-linux --class gnu --class os {
insmod raid
insmod mdraid
insmod part_msdos
insmod part_msdos
insmod ext2
set root='(md1)'
echo 'Chargement de Linux 2.6.26-2-amd64 ...'
linux /boot/vmlinuz-2.6.26-2-amd64 root=UUID=31359d64-af1c-4247-96e0-d319ee9a6448 ro
initrd /boot/initrd.img-2.6.26-2-amd64
menuentry 'Debian GNU/Linux, avec Linux 2.6.26-2-amd64 (mode de d�pannage)' --class debian --class gnu-linux --class gnu --class os {
insmod raid
insmod mdraid
insmod part_msdos
insmod part_msdos
insmod ext2
set root='(md1)'
linux /boot/vmlinuz-2.6.26-2-amd64 root=UUID=31359d64-af1c-4247-96e0-d319ee9a6448 ro single
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
comment on vire ce kernel
avec l’amorçage du noyau OVH du coup il tourne avec un noyau compilé sans souci.
