Sur mon Sheeva ARM, plantage kernel après apt-get install
Voila, j’ai fait une install fraiche de Squeeze sur mon Sheeva (archi ARM). 1ère manip : # apt-get install openssh-server : gros plantage au moment de générer la clé SSH1, il me met plein de message "pointer null etc !"
Bref je n’ai plus la main sur le sheeva. Je le relance, je tente d’installer htop pour autre chose et la il me demande un “dpkg --configure -a” car il a été interrompu.[code]root@sheeva:~# apt-get install htop
E: dpkg was interrupted, you must manually run ‘dpkg --configure -a’ to correct the problem.
root@sheeva:~# dpkg --configure -a
Setting up openssh-server (1:5.5p1-6) …
Creating SSH1 key; this may take some time …
[ 145.369923] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 145.378092] pgd = df954000
[ 145.380808] [00000000] *pgd=00000000
[ 145.384430] Internal error: Oops: 805 [#3]
[ 145.388543] last sysfs file: /sys/devices/virtual/net/lo/operstate
[ 145.394750] Modules linked in: ipv6 loop mv_cesa(+) aes_generic ext4 mbcache jbd2 sd_mod crc_t10dif usb_storage scsi_mod mvsdio ehci_hcd mv643xx_eth mmc_core usbcore nls_base libphy
[ 145.411148] CPU: 0 Tainted: G D (2.6.32-5-kirkwood #1)
[ 145.417360] PC is at __memzero+0x78/0xc0
[ 145.421298] LR is at 0x0
[ 145.423844] pc : [] lr : [<00000000>] psr: 00000013
[ 145.423850] sp : df30fed4 ip : 00000000 fp : beba00fc
[ 145.435387] r10: 00000000 r9 : df30e000 r8 : c0027048
[ 145.440636] r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : 00000000
[ 145.447194] r3 : 00000000 r2 : 00000000 r1 : ffffffd0 r0 : 00000000
[ 145.453752] Flags: nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 145.460920] Control: 0005397f Table: 1f954000 DAC: 00000015
[ 145.466693] Process sshd (pid: 1216, stack limit = 0xdf30e270)
[ 145.472552] Stack: (0xdf30fed4 to 0xdf310000)
[ 145.476931] fec0: 00000000 df924000 00000010
[ 145.485150] fee0: df30ff08 c028b534 c0027048 df924000 df30ff08 c0291e88 df450000 00000010
[ 145.493371] ff00: beba009c c0232c14 00000000 00000000 00000000 00000000 01000000 00000000
[ 145.501596] ff20: 00000000 df30ff4c 00000003 de95c700 df450000 c02d764c c02d764c c0232d90
[ 145.509817] ff40: c02d764c df30e000 00000000 00000000 00000000 c0367c5f df450000 00000000
[ 145.518041] ff60: 00000003 df450000 00000119 c0027048 00000000 c0232e24 beba00fc de95c700
[ 145.526263] ff80: 00000000 00000000 00000000 00000000 000000f0 beb9ff74 beb9ff4c 2a0827c8
[ 145.534487] ffa0: 0000011b c0026ea0 beb9ff74 beb9ff4c 00000003 beba009c 00000010 00000000
[ 145.542710] ffc0: beb9ff74 beb9ff4c 2a0827c8 0000011b 40429000 00000001 beba0128 beba00fc
[ 145.550933] ffe0: 0000000a beb9ff30 403a0ab0 403c574c 60000010 00000003 e5803034 e5913038
[ 145.559157] Code: 08bd80f0 e3110020 18a050fc e3110010 (18a000f0)
[ 145.565310] —[ end trace 62431bb6b5be163b ]—
Message from syslogd@sheeva at Apr 28 04:47:26 …
kernel:[ 145.384430] Int[ 145.578507] Unable to handle kernel NULL pointer dereference at virtual address 00000064
ernal error: Oop[ 145.587076] pgd = c0004000
s: 805 [#3]
[ 145.591181] [00000064] *pgd=00000000
Message from s
yslogd@sheeva at[ 145.597575] Internal error: Oops: 5 [#4]
[ 145.602898] last sysfs file: /sys/devices/virtual/net/lo/operstate
[ 145.609105] Modules linked in: ipv6 loop mv_cesa(+) aes_generic ext4 mbcache jbd2 sd_mod crc_t10dif usb_storage scsi_mod mvsdio ehci_hcd mv643xx_eth mmc_core usbcore nls_base libphy
[ 145.625503] CPU: 0 Tainted: G D (2.6.32-5-kirkwood #1)
[ 145.631801] PC is at ipv6_sock_mc_close+0xf4/0x10c [ipv6]
[ 145.637288] LR is at ipv6_sock_mc_close+0xf4/0x10c [ipv6]
[ 145.642716] pc : [] lr : [] psr: a0000013
[ 145.642722] sp : df30fbf0 ip : df627a00 fp : df627a00
[ 145.654259] r10: c0440f30 r9 : df815580 r8 : 00000000
[ 145.659509] r7 : df924000 r6 : de95c700 r5 : df450000 r4 : df924000
[ 145.666067] r3 : 00000100 r2 : df30e000 r1 : de95c700 r0 : df924000
[ 145.672624] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 145.679792] Control: 0005397f Table: 1f954000 DAC: 00000015
[ 145.685564] Process sshd (pid: 1216, stack limit = 0xdf30e270)
[ 145.691424] Stack: (0xdf30fbf0 to 0xdf310000)
[ 145.695805] fbe0: 00000000 df924000 df450000 de95c700
[ 145.704021] fc00: df627a00 df450028 df450028 bf1740c4 40000013 bf1a80b0 df450000 c0233734
[ 145.712244] fc20: df627a00 00000000 00000008 c02337c0 df627a00 c00cd518 00000000 00000000
[ 145.720467] fc40: 00000000 de95c700 00000000 df315840 0000000c df315848 00000008 00000000
[ 145.728690] fc60: 00000000 c00c9fc0 df315840 00000001 00000000 c0045d74 de9a9220 0000000b
[ 145.736913] fc80: de9a9220 c01a7b1a c01a7b1c 00000000 00000001 c0047730 c01a7b1c 00000000
[ 145.745135] fca0: 00000008 00000001 df30fcf7 c01a7b1a c01a7b1c 00000000 00000008 bf000000
[ 145.753359] fcc0: 00000000 c002abe0 df30e270 00000020 30000003 38646238 20306630 31313365
[ 145.761582] fce0: 30323030 61383120 66303530 33652063 30303131 28203031 30613831 30663030
[ 145.769805] fd00: 00002029 00000805 df30fe88 00000000 df30fe88 df8f2300 00000805 00000805
[ 145.778028] fd20: df30fe88 df8f2334 beba00fc c002de78 df30fe7c 00010000 de9a9220 00000000
[ 145.786251] fd40: df8f2300 c002e064 df319800 bf17f1a8 def09b80 df831000 df30fe7c df30fd9c
[ 145.794474] fd60: 00000001 c01aae58 00000122 00000000 df30fd8c df30fda4 00000000 df312f78
[ 145.802697] fd80: df30fd9c 00000000 df312f78 c00ae03c 00000000 c002e878 c009ed34 de93612c
[ 145.810919] fda0: 00000100 00000000 00000000 df4445b8 0000002e 0000002e 00000000 c045a260
[ 145.819142] fdc0: 00000000 0091330f c03b6ac0 df30febc 00000805 df30fe88 00000000 40000013
[ 145.827366] fde0: 00000000 c0026280 00000000 0000002e 4032b000 c045a260 df30fe8c de9a9220
[ 145.835589] fe00: 00000000 debaacac df312f78 4032b000 df954000 00000201 00000000 c00b4908
[ 145.843811] fe20: 0000002e 00000000 00000000 c00d4324 00000000 0000012b df8f2300 000004ac
[ 145.852034] fe40: df955008 00001600 0000001c df312f78 de9a9220 4032bd48 df8f2300 80000005
[ 145.860258] fe60: df30ffb0 00000200 de9a9220 c002dfc8 ffffffff df30febc 00000000 00000000
[ 145.868480] fe80: c0027048 c0026a8c 00000000 ffffffd0 00000000 00000000 00000000 00000000
[ 145.876703] fea0: 00000000 00000000 c0027048 df30e000 00000000 beba00fc 00000000 df30fed4
[ 145.884926] fec0: 00000000 c01a7b18 00000013 ffffffff beb9ff4c 00000000 df924000 00000010
[ 145.893149] fee0: df30ff08 c028b534 c0027048 df924000 df30ff08 c0291e88 df450000 00000010
[ 145.901372] ff00: beba009c c0232c14 00000000 00000000 00000000 00000000 01000000 00000000
[ 145.909595] ff20: 00000000 df30ff4c 00000003 de95c700 df450000 c02d764c c02d764c c0232d90
[ 145.917817] ff40: c02d764c df30e000 00000000 00000000 00000000 c0367c5f df450000 00000000
[ 145.926041] ff60: 00000003 df450000 00000119 c0027048 00000000 c0232e24 beba00fc de95c700
[ 145.934264] ff80: 00000000 00000000 00000000 00000000 000000f0 beb9ff74 beb9ff4c 2a0827c8
[ 145.942487] ffa0: 0000011b c0026ea0 beb9ff74 beb9ff4c 00000003 beba009c 00000010 00000000
[ 145.950710] ffc0: beb9ff74 beb9ff4c 2a0827c8 0000011b 40429000 00000001 beba0128 beba00fc
[ 145.958933] ffe0: 0000000a beb9ff30 403a0ab0 403c574c 60000010 00000003 e5803034 e5913038
[ 145.967277] [] (ipv6_sock_mc_close+0xf4/0x10c [ipv6]) from [] (inet6_release+0x2c/0x44 [ipv6])
[ 145.977734] [] (inet6_release+0x2c/0x44 [ipv6]) from [] (sock_release+0x24/0x8c)
[ 145.986919] [] (sock_release+0x24/0x8c) from [] (sock_close+0x24/0x34)
[ 145.995232] [] (sock_close+0x24/0x34) from [] (__fput+0x114/0x1f0)
[ 146.003190] [] (__fput+0x114/0x1f0) from [] (filp_close+0x70/0x7c)
[ 146.011150] [] (filp_close+0x70/0x7c) from [] (put_files_struct+0x80/0xe0)
[ 146.019808] [] (put_files_struct+0x80/0xe0) from [] (do_exit+0x1f8/0x64c)
[ 146.028381] [] (do_exit+0x1f8/0x64c) from [] (die+0x250/0x284)
[ 146.035996] [] (die+0x250/0x284) from [] (__do_kernel_fault+0x68/0x80)
[ 146.044305] [] (__do_kernel_fault+0x68/0x80) from [] (do_page_fault+0x1d4/0x1ec)
[ 146.053486] [] (do_page_fault+0x1d4/0x1ec) from [] (do_DataAbort+0x34/0x94)
[ 146.062230] [] (do_DataAbort+0x34/0x94) from [] (__dabt_svc+0x4c/0x60)
[ 146.070534] Exception stack(0xdf30fe88 to 0xdf30fed0)
[ 146.075613] fe80: 00000000 ffffffd0 00000000 00000000 00000000 00000000
[ 146.083829] fea0: 00000000 00000000 c0027048 df30e000 00000000 beba00fc 00000000 df30fed4
[ 146.092049] fec0: 00000000 c01a7b18 00000013 ffffffff
[ 146.097129] [] (__dabt_svc+0x4c/0x60) from [] (__memzero+0x78/0xc0)
[ 146.105176] Code: e1a00007 e3a02020 eb428622 eb3adb30 (e5985064)
Apr 28 04:47:26[ 146.111324] —[ end trace 62431bb6b5be163c ]—
kernel:[[ 146.117347] Kernel panic - not syncing: Fatal exception in interrupt
145.388543] la[ 146.125137] [] (unwind_backtrace+0x0/0xdc) from [] (panic+0x34/0x128)
st sysfs file: /[ 146.134743] [] (panic+0x34/0x128) from [] (die+0x248/0x284)
sys/devices/virt[ 146.143481] [] (die+0x248/0x284) from [] (__do_kernel_fault+0x68/0x80)
ual/net/lo/opers[ 146.153178] [] (__do_kernel_fault+0x68/0x80) from [] (do_page_fault+0x1d4/0x1ec)
tate
Messa[ 146.163745] [] (do_page_fault+0x1d4/0x1ec) from [] (do_DataAbort+0x34/0x94)
ge from syslogd@[ 146.173875] [] (do_DataAbort+0x34/0x94) from [] (__dabt_svc+0x4c/0x60)
sheeva at Apr 28[ 146.183566] Exception stack(0xdf30fba8 to 0xdf30fbf0)
04:47:26 …
[ 146.190032] fba0: df924000 de95c700 df30e000 00000100 df924000 df450000
kernel:[ 145.4[ 146.199643] fbc0: de95c700 df924000 00000000 df815580 c0440f30 df627a00 df627a00 df30fbf0
66693] Process s[ 146.209247] fbe0: bf1932d4 bf1932d4 a0000013 ffffffff
shd (pid: 1216, [ 146.215798] [] (__dabt_svc+0x4c/0x60) from [] (ipv6_sock_mc_close+0xf4/0x10c [ipv6])
stack limit = 0x[ 146.226756] [] (ipv6_sock_mc_close+0xf4/0x10c [ipv6]) from [] (inet6_release+0x2c/0x44 [ipv6])
df30e270)
[ 146.238482] [] (inet6_release+0x2c/0x44 [ipv6]) from [] (sock_release+0x24/0x8c)
Message from sys[ 146.249004] [] (sock_release+0x24/0x8c) from [] (sock_close+0x24/0x34)
logd@sheeva at A[ 146.258701] [] (sock_close+0x24/0x34) from [] (__fput+0x114/0x1f0)
pr 28 04:47:26 .[ 146.268047] [] (__fput+0x114/0x1f0) from [] (filp_close+0x70/0x7c)
kernel:[ [ 146.277392] [] (filp_close+0x70/0x7c) from [] (put_files_struct+0x80/0xe0)
145.472552] Stac[ 146.287436] [] (put_files_struct+0x80/0xe0) from [] (do_exit+0x1f8/0x64c)
k: (0xdf30fed4 t[ 146.297396] [] (do_exit+0x1f8/0x64c) from [] (die+0x250/0x284)
o 0xdf310000)
[ 146.306397] [] (die+0x250/0x284) from [] (__do_kernel_fault+0x68/0x80)
Message from[ 146.316096] [] (__do_kernel_fault+0x68/0x80) from [] (do_page_fault+0x1d4/0x1ec)
syslogd@sheeva [ 146.326660] [] (do_page_fault+0x1d4/0x1ec) from [] (do_DataAbort+0x34/0x94)
at Apr 28 04:47:[ 146.336791] [] (do_DataAbort+0x34/0x94) from [] (__dabt_svc+0x4c/0x60)
26 …
kernel[ 146.346481] Exception stack(0xdf30fe88 to 0xdf30fed0)
:[ 145.476931] [ 146.352955] fe80: 00000000 ffffffd0 00000000 00000000 00000000 00000000
fec0: [ 146.362565] fea0: 00000000 00000000 c0027048 df30e000 00000000 beba00fc 00000000 df30fed4
[ 146.372171] fec0: 00000000 c01a7b18 00000013 ffffffff
[ 146.378641] [] (__dabt_svc+0x4c/0x60) from [] (__memzero+0x78/0xc0)
kernel:[ 145.485150] fee0: df30ff08 c028b534 c0027048 df924000 df30ff08 c0291e88 df450000 00000010
kernel:[ 145.493371] ff00: beba009c c0232c14 00000000 00000000 00000000 00000000 01000000 00000000
kernel:[ 145.501596] ff20: 00000000 df30ff4c 00000003 de95c700 df450000 c02d764c c02d764c c0232d90
kernel:[ 145.509817] ff40: c02d764c df30e000 00000000 00000000 00000000 c0367c5f df450000 00000000
kernel:[ 145.518041] ff60: 00000003 df450000 00000119 c0027048 00000000 c0232e24 beba00fc de95c700
kernel:[ 145.526263] ff80: 00000000 00000000 00000000 00000000 000000f0 beb9ff74 beb9ff4c 2a0827c8
kernel:[ 145.534487] ffa0: 0000011b c0026ea0 beb9ff74 beb9ff4c 00000003 beba009c 00000010 00000000
kernel:[ 145.542710] ffc0: beb9ff74 beb9ff4c 2a0827c8 0000011b 40429000 00000001 beba0128 beba00fc
kernel:[ 145.550933] ffe0: 0000000a beb9ff30 403a0ab0 403c574c 60000010 00000003 e5803034 e5913038
kernel:[ 145.559157] Code: 08bd80f0 e3110020 18a050fc e3110010 (18a000f0)[/code]Et la je n’ai plus la main.
Qu’en pensez vous ?
A savoir que l’installation de htop si une installation fraiche se passe bien. C’est toujours openssh-server qui plante le noyau au même endroit. Cela ne parait pas aléatoire. (si cela peut vous aider)
Bon j’ai trouvé,
J’ai désactivé l’ipv6setenv bootargs_console console=ttyS0,115200 [b]ipv6.disable=1[/b] dans les variables d’uboot de mon sheevaplug et cela marche bien que la séquence de boot comporte encore un gros plantage :frowning:
J’ai vraiment du mal à m’en sortir la
