Le problème:
je ne parviens plus à synchroniser mon palm T|X depuis que je suis sous Squeeze, alors que sous Lenny il n’y avait ( presque ) pas de problème.( via le cable USB )
Le message d’erreur qui apparaît à l’écran est le suivant:(cf capture d’écran)
Sur les fichiers de log, je ne trouve pas la suite du message, mais:
tail -25 /var/log/syslog
Jun 8 17:23:20 php75 kernel: [ 1952.569994] usb 7-2: Product: Palm Handheld
Jun 8 17:23:20 php75 kernel: [ 1952.569996] usb 7-2: Manufacturer: Palm, Inc.
Jun 8 17:23:20 php75 kernel: [ 1952.569997] usb 7-2: SerialNumber: PN70M1Y8V072
Jun 8 17:23:20 php75 kernel: [ 1952.570050] usb 7-2: configuration #1 chosen from 1 choice
Jun 8 17:24:01 php75 /USR/SBIN/CRON[3112]: (eric) CMD (':')
Jun 8 17:24:24 php75 kernel: [ 2016.640042] usb 7-2: USB disconnect, address 4
Jun 8 17:24:24 php75 kernel: [ 2017.132020] usb 7-2: new full speed USB device using uhci_hcd and address 5
Jun 8 17:24:25 php75 kernel: [ 2017.305089] usb 7-2: New USB device found, idVendor=0830, idProduct=0061
Jun 8 17:24:25 php75 kernel: [ 2017.305091] usb 7-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
Jun 8 17:24:25 php75 kernel: [ 2017.305093] usb 7-2: Product: Palm Handheld
Jun 8 17:24:25 php75 kernel: [ 2017.305095] usb 7-2: Manufacturer: Palm, Inc.
Jun 8 17:24:25 php75 kernel: [ 2017.305097] usb 7-2: SerialNumber: PN70M1Y8V072
Jun 8 17:24:25 php75 kernel: [ 2017.305148] usb 7-2: configuration #1 chosen from 1 choice
Jun 8 17:24:43 php75 kernel: [ 2035.984040] usb 7-2: USB disconnect, address 5
Jun 8 17:24:44 php75 kernel: [ 2036.472022] usb 7-2: new full speed USB device using uhci_hcd and address 6
Jun 8 17:24:44 php75 kernel: [ 2036.645714] usb 7-2: New USB device found, idVendor=0830, idProduct=0061
Jun 8 17:24:44 php75 kernel: [ 2036.645717] usb 7-2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
Jun 8 17:24:44 php75 kernel: [ 2036.645719] usb 7-2: Product: Palm Handheld
Jun 8 17:24:44 php75 kernel: [ 2036.645721] usb 7-2: Manufacturer: Palm, Inc.
Jun 8 17:24:44 php75 kernel: [ 2036.645722] usb 7-2: SerialNumber: PN70M1Y8V072
Jun 8 17:24:44 php75 kernel: [ 2036.645774] usb 7-2: configuration #1 chosen from 1 choice
grep -3 tty /var/log/messages , ne montre aucune erreur
grep -3 tty /var/log/kernel , non plus
et
egrep -i ttyS0 *: ( Extraits les plus récents de lignes répétées )
syslog:Jun 8 16:51:05 php75 modem-manager: (tty/ttyS0): port's parent platform driver is not whitelisted
debug:Jun 8 16:51:05 php75 modem-manager: (tty/ttyS0): port's parent platform driver is not whitelisted
daemon.log:Jun 6 08:52:58 php75 modem-manager: (tty/ttyS0): port's parent platform driver is not whitelisted
J’ai créé un lien physique
ln /dev/tty0 /dev/ttyUSB
mais évidemment sans succès
Quelqu’un a surement une solution, mais je ne l’ai pas trouvé sur internet.
Sur le palm, il y a 2 types de questions pour sa configuration:
1 Menu réseau:
service [Unix/USB/Wi-Fi] j’ai essayé “USB” puis "Unix"
Type de connexion: [PPP/SLIP/CSLIP] j’utilise "ppp"
Délai d’inactivité "Jamais"
Interrogation DNS: coché ( sinon, il demande des adresses )
Adresse IP: Automatique ( sinon il demande une adresse )
2 Connexion:
station/cable, avec :
vitesse: “115200” et
Ctrl flux: “activé” ( j’ai aussi tenté “Automatique” et
Se connecter au [PC/Modem/Téléphone/Réseau local] j’utilise “PC”
Si j’ai bien compris, le noyau ( 2.6.32-5-amd64 ) ne gère plus l’adresse device de la même façon, et palm TX ne semble pas présenter d’alternative.
Je suppose qu’il doit y avoir un moyen ( peut être un module du noyau ? ) pour garantir une “compatibilité ascendante” ( excusez la grossièreté )
