je recheck mais les infos de blkid ont l’air de correspondre avec ce que j’ai en /etc/fstab
[code]# /etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
/ was on /dev/sda5 during installation
UUID=f0e6eea4-264d-42f2-97c1-0ad6d60e9e76 / ext4 errors=remount-ro 0 1
swap was on /dev/sda6 during installation
#UUID=d464c414-6e10-4fb1-adaf-43096cf52ab5 none swap sw 0 0
changed home on new partition
#UUID=83192ee9-fd8a-4d8c-9988-bca2d0fdf630 /home ext4 nodev,nosuid 0 2
#/dev/sr0 /media/cdrom0 udf,iso9660 user,noauto 0 0
#/dev/fd0 /media/floppy0 auto rw,user,noauto 0 0
#/dev/md0 /media/raid5 ext4 defaults 0 0
#UUID=ea59484a-3652-4d1d-a398-f417cbd0ae7c /media/backup ext4 defaults 0 0
for virtualbox, changed on june 5th
#none /proc/bus/usb usbfs devgid=126,devmode=664 0 0
for sftp in chroot
#/media/raid5/TV\040SHOWS/ /home/quest/tv/ ext4 bind,ro 0 0
#/media/raid5/MOVIES/ /home/quest/movies/ ext4 bind,ro 0 0
#/media/raid5/ANIME/ /home/quest/anime/ ext4 bind,ro 0 0
#garmin fenix 2
#UUID=489A-9E97 /media/raid5/fenix2 vfat defaults,user,noauto,errors=remount-ro 0 1
blkid
/dev/sdc1: UUID="e7c87d29-37d0-d6b4-9a33-6d4f0e239a13" UUID_SUB="4cc4d747-5c88-9bc6-59c1-5f29603fba57" LABEL="bigbenn:0" TYPE="linux_raid_member" PARTLABEL="Linux filesystem" PARTUUID="af78f725-7354-448b-a3f7-9149937d440c"
/dev/sdb1: UUID="83192ee9-fd8a-4d8c-9988-bca2d0fdf630" TYPE="ext4" PARTUUID="8aaed40e-01"
/dev/sdb5: UUID="f0e6eea4-264d-42f2-97c1-0ad6d60e9e76" TYPE="ext4" PARTUUID="8aaed40e-05"
/dev/sdb6: UUID="d464c414-6e10-4fb1-adaf-43096cf52ab5" TYPE="swap" PARTUUID="8aaed40e-06"
/dev/sde1: UUID="ea59484a-3652-4d1d-a398-f417cbd0ae7c" TYPE="ext4" PARTUUID="1433120b-01"
/dev/sdf1: UUID="e7c87d29-37d0-d6b4-9a33-6d4f0e239a13" UUID_SUB="69383fe0-2113-a305-87fe-51057bfdd681" LABEL="bigbenn:0" TYPE="linux_raid_member" PARTUUID="873db73f-01"
/dev/sda1: UUID="e7c87d29-37d0-d6b4-9a33-6d4f0e239a13" UUID_SUB="cfdfaca9-f350-3c3a-a6a7-75a9844e9660" LABEL="bigbenn:0" TYPE="linux_raid_member" PARTUUID="4483559b-01"
/dev/sdd1: UUID="e7c87d29-37d0-d6b4-9a33-6d4f0e239a13" UUID_SUB="efb1db76-0169-ee95-ba36-d64adf36de65" LABEL="bigbenn:0" TYPE="linux_raid_member" PARTUUID="092c2257-01"
/dev/sdg1: UUID="e7c87d29-37d0-d6b4-9a33-6d4f0e239a13" UUID_SUB="c6dc6576-3d94-e0e9-77b8-abb62563277d" LABEL="bigbenn:0" TYPE="linux_raid_member" PARTUUID="000d77f7-01"
/dev/md0: UUID="0a0dc09a-0714-4fed-99e2-31a08b753373" TYPE="ext4"
pour répondre (si il y avait question) à Belzebuth, la populace est effectivement sur une jessie avec à priori un sources.list qui va bien, un fichier preferences aussi, etc, etc,
la populace apprend, découvre, expérimente, progresse, et elle adore ça, et elle va continuer, longtemps !
