Systemd with 3.14
dmesg me remonte ceci puisque /var/log/messages ne s’implémente pas
  51.403198] systemd-logind[5855]: Watching system buttons on /dev/input/event2 (Power Button)
[   51.403263] systemd-logind[5855]: Watching system buttons on /dev/input/event1 (Power Button)
[   51.403305] systemd-logind[5855]: New seat seat0.
[   51.404089] systemd-logind[5855]: New session 1 of user Debian-gdm.
[   51.404171] systemd-logind[5855]: Linked /tmp/.X11-unix/X0 to /run/user/107/X11-display.
[   53.259720] systemd-logind[5855]: New session c1 of user ejabberd.
[   54.716828] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[   54.757343] NFSD: starting 90-second grace period (net ffffffff81886940)
[   60.700974] systemd-logind[5855]: New session c2 of user ejabberd.
[   61.138102] systemd-logind[5855]: New session c3 of user ejabberd.
[   62.324218] systemd-logind[5855]: Removed session c3.
[   62.324674] systemd-logind[5855]: New session c4 of user ejabberd.
[   65.149487] systemd-logind[5855]: Removed session c4.
[   73.262526] postgres (7260): /proc/7260/oom_adj is deprecated, please use /proc/7260/oom_score_adj instead.
[  132.179049] systemd-logind[5855]: New session 2 of user jb1.
[  132.179145] systemd-logind[5855]: Linked /tmp/.X11-unix/X0 to /run/user/1000/X11-display.
[  580.279190] perf samples too long (2502 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
[ 2325.004542] systemd-hostnamed[15755]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
root@alpha30:~#
nss-hostname j’installe?
A+
JB1
[09:04:18] ~ # divi nss-myhostname libnss-myhostname - nss module providing fallback resolution for the current hostname Homepage: http://0pointer.de/lennart/projects/nss-myhostname/ 0.2-5 oldstable 0.3-5~deb7u1 stable 0.3-6 testing unstable [09:04:23] ~ #
[code][09:06:53] ~ # ash libnss-myhostname
Paquet : libnss-myhostname
Nouveau: oui
État: non installé
Multiarchitecture : même
Version : 0.3-5~deb7u1
Priorité : supplémentaire
Section : admin
Responsable : Joachim Breitner nomeata@debian.org
Architecture : i386
Taille décompressée : 57,3 k
Dépend: libc6 (>= 2.1.3)
Pré-dépend: multiarch-support
Description : nss module providing fallback resolution for the current hostname
This package contains a plugin for the Name Service Switch, providing host name resolution for the locally configured system hostname as
returned by gethostname(2). It returns all locally configured public IP addresses or – if none are configured, the IPv4 address 127.0.1.1
(which is on the local loopback) and the IPv6 address ::1 (which is the local host).
A lot of software relies on that the local host name is resolvable. This package provides an alternative to the fragile and error-prone manual
editing of /etc/hosts.
Site : http://0pointer.de/lennart/projects/nss-myhostname/
[09:07:02] ~ # [/code]
[09:08:15] ~ # acp libnss-myhostname libnss-myhostname: Installé : (aucun) Candidat : 0.3-5~deb7u1 Table de version : 0.3-6 0 97 http://ftp.fr.debian.org/debian/ testing/main i386 Packages 95 http://ftp.fr.debian.org/debian/ unstable/main i386 Packages 0.3-5~deb7u1 0 990 http://ftp.fr.debian.org/debian/ stable/main i386 Packages 0.2-5 0 500 http://ftp.fr.debian.org/debian/ oldstable/main i386 Packages [09:08:19] ~ #
bonjour oh utilisateur du RPI,
les commandes que tu me donnes ne sont pas implémentées chez moi,
je ne sais pas leurs actions
Amical bonjour,
A+
JB1
[quote=“jb1”]bonjour oh utilisateur du RPI,
Amical bonjour,
A+
JB1[/quote]
Ce sont des alias, c’est bien normale que les commandes te sont inconnu si tu n’utilise pas les mêmes alias :005
Nein, nicht normalø.
Conseils inexploitables …
C’est comme si je te disais de regarder l’icone en haut à gauche de mon écran sans joindre de capture.
Joindre des clarifications aux alias sataniques.
$ alias
les commandes que tu me donnes ne sont pas implémentées chez moi,[/quote]
Quoi de plus personnel qu’un alias.
Alias que je ne balance pas (plus) à un novice.
Avec un peu de bouteille et sans être un membre patenté du Camp de Coëtquidan, pas bien difficile de deviner de quoi il en retourne … :033
bonsoir,
j’ai du m’absenter!
nss-myhostname est installé
A+
JB1
