SYSTÈME: \impossible de monter /var sous XFS
(Système cassé: Squeeze)
  1. mon système est cassé: impossible de monter la partition LVM2 xfs contenant /var (à partir d’un autre système, Wheezy)
Le message de mount est:
j’ai essayé
qui renvoi aussi une erreur:
[quote]ERROR: The filesystem has valuable metadata changes in a log which needs to be replayed. Mount the filesystem to replay the log, and unmount it before re-running xfs_check. If you are unable to mount the filesystem, then use the xfs_repair -L option to destroy the log and attempt a repair.
Note that destroying the log may cause corruption – please attempt a mount of the filesystem before doing this.[/quote]
Si j’ai bien compris ce message, il est conseillé de faire xfs_repair -L qui détruira le log et peut causer une corruption, autrement dit, un quitte ou double (en aveugle pour moi !): soit ça répare, soit ça casse la possibilité de réparer.
J’ai donc limité mon intervention à essayer de comprendre (en vain):
en faisant: #xfs_repair -n /dev/mapper/VG_tout-var
Phase 1 - find and verify superblock... Phase 2 - using internal log - scan filesystem freespace and inode maps... agf_freeblks 83808, counted 83791 in ag 3 agi unlinked bucket 40 is 232 in ag 3 (inode=25166056) sb_ifree 6501, counted 6457 sb_fdblocks 1307638, counted 1293036 - found root inode chunk Phase 3 - for each AG... - scan (but don't clear) agi unlinked lists... - process known inodes and perform inode discovery... - agno = 0 - agno = 1 - agno = 2 7f6b32eaf700: Badness in key lookup (length) bp=(bno 7323760, len 16384 bytes) key=(bno 7323760, len 8192 bytes) - agno = 3 - agno = 4 - agno = 5 - agno = 6 - agno = 7 - agno = 8 - process newly discovered inodes... Phase 4 - check for duplicate blocks... - setting up duplicate extent list... - check for inodes claiming duplicate blocks... - agno = 1 - agno = 3 - agno = 4 - agno = 5 - agno = 0 - agno = 6 - agno = 8 - agno = 2 - agno = 7 No modify flag set, skipping phase 5 Phase 6 - check inode connectivity... - traversing filesystem ... - traversal finished ... - moving disconnected inodes to lost+found ... disconnected inode 25166056, would move to lost+found Phase 7 - verify link counts... would have reset inode 25166056 nlinks from 0 to 1 No modify flag set, skipping filesystem flush and exiting
d’où je crois seulement comprendre qu’un inode devrait être supprimé (déplacé vers lost+found).
Deuxièmes données du problème:
L’utilitaire de disque de Gnome3 reconnait le RAID0 sur lequel est installé le Groupe de volumes (VG_tout) qui contient 4 volumes logiques, dont 3 sont montés correctement, le 4e étant celui dédié à /var.
Mais en lançant la «Vérification de l’ensemble Raid» de l’utilitaire, j’obtiens le message d’information suivant:
[quote]Une erreur est apparue pendant l’exécution d’une opération sur «Ensemble RAID-0 2,0 TB» …: l’opération a échoué.
Détails:
Error checking array: helper exited with exit code 1: device /dev/md0 is not idle[/quote]
La cause probable est dans une première réparation, apparemment réussie, grace à une aise patiente, persistante de PascalHambourg, que vous pourrez trouver ici: raid0-en-cours-formatage-funeste-t51666.html?hilit=RAID.
Peu avant une panne physique (démarrage aléatoire),j’avais pu retrouver un Squeeze apparemment fonctionnel en utilisant un LVM_miroir pour chaque volume logique (je ne l’avais fait auparavant que pour /home)
La panne qui est survenue ensuite était physique, due à un important empoussiérage, mais j’avais tout de même réussi à installer Wheezy (sur un autre disque interne).
Le dépoussiérage ayant eu lieu, Wheezy tourne normalement, mais toujours pas Squeeze, à cause de ce /var inaccessible.
Ouf, je crois avoir dit l’essentiel.
ANNEXE
Pour les précisions:
1) Squeeze est ainsi construit:
« / » sur /sdc1 (ext4)
« /boot » sur /sdc2 (ext4)
(ces choix car j’avais des inquiétudes sur le démarrage direct en LVM)
Le reste en xfs, sur le groupe de volume VG_tout, groupe unique sur le RAID-0 (/dev/md0) assemblant /dev/sdc4 et /dev/sdf4:
« /home » sur /dev/mapper/VG_tout-home
« /usr » sur/dev/mapper/VG_tout-usr
« /usr/local » sur /dev/mapper/VG_tout-usr-var
« /var » sur /dev/mapper/VG_tout-var
  1. lvs -a -o +devices /dev/VG_tout renvoie:
LV VG Attr LSize Pool Origin Data% Move Log Copy% Convert Devices home VG_tout mwi-aom- 1,46t home_mlog 100,00 home_mimage_0(0),home_mimage_1(0) [home_mimage_0] VG_tout iwi-aom- 1,46t /dev/sdd1(0) [home_mimage_1] VG_tout iwi-aom- 1,46t /dev/md0(0) [home_mlog] VG_tout lwi-aom- 4,00m /dev/sdd2(0) usr VG_tout mwi-aom- 12,00g usr_mlog 100,00 usr_mimage_0(0),usr_mimage_1(0) usr_local VG_tout mwi-aom- 1,86g usr_local_mlog 100,00 usr_local_mimage_0(0),usr_local_mimage_1(0) [usr_local_mimage_0] VG_tout iwi-aom- 1,86g /dev/sdd1(386560) [usr_local_mimage_1] VG_tout iwi-aom- 1,86g /dev/sdd2(3) [usr_local_mlog] VG_tout lwi-aom- 4,00m /dev/md0(389120) [usr_mimage_0] VG_tout iwi-aom- 12,00g /dev/sdd1(384000) [usr_mimage_0] VG_tout iwi-aom- 12,00g /dev/sdd1(389596) [usr_mimage_1] VG_tout iwi-aom- 12,00g /dev/md0(386560) [usr_mimage_1] VG_tout iwi-aom- 12,00g /dev/md0(389121) [usr_mlog] VG_tout lwi-aom- 4,00m /dev/sdd2(2) var VG_tout mwi-a-m- 10,00g var_mlog 100,00 var_mimage_0(0),var_mimage_1(0) [var_mimage_0] VG_tout iwi-aom- 10,00g /dev/sdd1(387036) [var_mimage_1] VG_tout iwi-aom- 10,00g /dev/md0(384000) [var_mlog] VG_tout lwi-aom- 4,00m /dev/sdd2(1)
  1. J’avais déjà oublié: peut-être y-a-t il un rapport avec ce problème: une bizarrerie dans l’installation de Wheezy (le système à partir duquel je tente la réparation: la bizarrerie est décrite ici: gnome3-utilitaire-de-disques-incoherences-t52380.html
Est-ce qu’une réparation est possible, et si c’est la cas, est-ce qu’elle est accessible à l’éternel newbie que je m’entête à rester, bref, est-ce que cela vaut le coup de tenter cette réparation, et pour vous, de m’y aider ?
Il me semble avoir lu, il y a longtemps une page web concernant la réparation d’une partition /var cassée, ce qui serait une voie possible de réparation.
Par ailleurs, cet état «non montable» d’une partition et ce terme de «nettoyage» du messge de mount me laisse -une fois de plus- perplexe.
Merci pour votre patience à m’avoir lu.
[quote] ERROR: The filesystem has valuable metadata changes in a log which needs to be replayed. Mount the filesystem to replay the log, and unmount it before re-running xfs_check. If you are unable to mount the filesystem, then use the xfs_repair -L option to destroy the log and attempt a repair.
Si j’ai bien compris ce message, il est conseillé de faire xfs_repair -L qui détruira le log et peut causer une corruption, autrement dit, un quitte ou double (en aveugle pour moi !): soit ça répare, soit ça casse la possibilité de réparer.[/quote]
Avant de tenter xfs_repair, il est lourdement insisté sur le montage : [mono]please attempt a mount of the filesystem before doing this[/mono]
[mono]Mount the filesystem to replay the log[/mono].
xfs_repair ne doit se tenter qu’après avoir vainement tenté de le monter.
[mono]If you are unable to mount the filesystem, then use the xfs_repair -L[/mono]
xfs_repair se dégaine quand le montage est rendu impossible.
Quand il n’y a plus moyen de monter/démonter, rendu à cette extrémité ça veut dire que tu ne risques pas grand chose à accepter l’ultime recours, les réparations suggérées par xfs_repair. Il m’est arrivé par le passé de réparer un système de fichier xfs inmontable grâce à xfs_repair.
Les logs de la simulation ne semblent pas déborder d’erreurs, a vist de naz, ça devrait bien se passer.
Bonjour et merci etxeberrizahar
J’ ai omis de le préciser, mais c’est bien parce que je ne parviens pas à monter ce volume que se pose le problème.
mount renvoie: « La structure a besoin d’un nettoyage »
La commande mount recèlerait-elle un secret que je n’aurais pas percé ? à quel genre de nettoyage fait-elle référence ?
Bonjour, chers lecteurs
Suite
après avoir trouvé ceci:
https://www.debian-fr.org/verification-d-une-partition-lvm-t51569.html
j’ai tenté d’utiliser [size=110]badblocks[/size] pour vérifier l’état physique des disques.
sur une partition logique (démontée): refuse
sur le raid0 (tout son contenu démonté) : refuse
sur chaque disque concerné par le RAID0 (après démontage de tout, y compris les swap), ou par le LVM (miroir sur un DD différent); refuse en indiquant que le disque est utilisé (j’ai supposé qu’il sagissait du fait qu’une partition soit en raid, même si celui-ci n’est pas utilisé (tout ce qu’il contient n’est pas monté):
( /dev/sdd1/ appartient au groupe de volume et contient les miroirs LVM ; il ne participe pas au RAID0 (/dev/sdc4 + /dev/sdf4)
à plus tard, pour la suite
