Premièrement, merci pour ta réponse.
Peux-tu passer en mode terminal (ALT+CTRL+F3 par ex)
Non
Arrives-tu à éteindre avec ALT+CRTL+Supp ce qui est déjà mieux que le bouton On/Off
Du coup, non.
que vois-tu dans dmesg (au démrrage, en cours de fonctionnement)?
Je ne sais pas exactement quoi chercher, et je ne peux mettre le retour complet de la commande ici (je dépasse la limite de caractère autoriser). Du coup, je met que les parties d’erreur (rouge) ci-dessous.
[ 0.411038] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.411047] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.411051] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.411054] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.411059] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.411061] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.411381] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.411386] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.411388] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.411391] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.411395] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.411398] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.411709] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.411714] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.411717] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.411720] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.411724] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.411727] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.412043] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.412048] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.412050] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.412054] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.412058] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.412060] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.412373] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.412377] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.412380] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.412383] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS05._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.412387] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.412390] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.412701] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.412706] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.412708] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.412711] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.412715] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.412718] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.413029] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.413034] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.413036] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.413040] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS07._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.413044] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.413046] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.413357] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.413362] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.413365] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.413368] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS08._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.413372] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.413374] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.413684] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.413689] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.413692] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.413695] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.413699] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.413701] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.414012] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.414017] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.414019] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.414022] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS10._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.414026] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.414029] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.414339] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS11._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.414343] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.414346] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.414349] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS11._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.414353] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.414356] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.414667] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS12._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.414671] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.414674] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.414677] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS12._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.414681] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.414684] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415017] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.USR1._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415021] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415024] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415027] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.USR1._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415031] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415034] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415038] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.USR2._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415042] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415045] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415048] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.USR2._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415052] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415055] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415092] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415097] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415099] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415102] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415106] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415109] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415147] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415151] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415154] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415157] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415161] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415163] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415200] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415205] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415207] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415210] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415214] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415217] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415254] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415258] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415261] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415264] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415268] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415271] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415308] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415312] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415315] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415318] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS05._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415322] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415324] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415361] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415366] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415368] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415371] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS06._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415375] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415378] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415415] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS07._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415419] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415422] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415425] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS07._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415429] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415432] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415468] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS08._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415473] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415475] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415478] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS08._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415482] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415485] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415522] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS09._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415527] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415529] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415532] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS09._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415536] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415539] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415576] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS10._UPC], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415580] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415583] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 0.415586] ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS10._PLD], AE_ALREADY_EXISTS (20180810/dswload2-316)
[ 0.415590] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
[ 0.415593] ACPI Error: Skip parsing opcode OpcodeName unavailable (20180810/psloop-543)
[ 2.359897] nouveau 0000:01:00.0: DRM: Pointer to TMDS table invalid
[ 2.979807] psmouse serio1: synaptics: Unable to query device: -5
[ 6.136142] iTCO_wdt iTCO_wdt: can't request region for resource [mem 0x00c5fffc-0x00c5ffff]
[ 6.709564] ath10k_pci 0000:3b:00.0: firmware: failed to load ath10k/pre-cal-pci-0000:3b:00.0.bin (-2)
[ 6.710070] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[ 6.710586] ath10k_pci 0000:3b:00.0: firmware: failed to load ath10k/cal-pci-0000:3b:00.0.bin (-2)
[ 9.707847] nouveau 0000:01:00.0: secboot: error during falcon reset: -110
[ 9.707850] nouveau 0000:01:00.0: gr: init failed, -110
[ 13.323852] ath10k_pci 0000:3b:00.0: wmi service ready event not received
[ 13.404301] ath10k_pci 0000:3b:00.0: Could not init core: -110
[ 23.692205] nouveau 0000:01:00.0: secboot: error during falcon reset: -110
[ 23.692216] nouveau 0000:01:00.0: gr: init failed, -110
Merci pour ton aide.
