Bonjour.
Je viens d’acheter et monter un Q9550 sur une carte mère Asus P5KPL-AM EPU.
Puis j’ai installé une Wheezy, et j’ai lancé dmidecode.
voilà ce que donnent les premières lignes:
[code]root@deb9550:~# dmidecode
dmidecode 2.11
SMBIOS 2.5 present.
53 structures occupying 1938 bytes.
Table at 0x000F06A0.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: American Megatrends Inc.
Version: 0501
Release Date: 08/20/2010
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 1024 kB
Characteristics:
ISA is supported
PCI is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Targeted content distribution is supported
BIOS Revision: 8.12
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: System manufacturer
Product Name: System Product Name
Version: System Version
Serial Number: System Serial Number
UUID: C08767CA-4867-DE11-A2FC-0026186131CB
Wake-up Type: Power Switch
SKU Number: To Be Filled By O.E.M.
Family: To Be Filled By O.E.M.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: ASUSTeK Computer INC.
Product Name: P5KPL-AM EPU
Version: x.0x
Serial Number: 100648340001024
Asset Tag: To Be Filled By O.E.M.
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: To Be Filled By O.E.M.
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 21 bytes
Chassis Information
Manufacturer: Chassis Manufacture
Type: Desktop
Lock: Not Present
Version: Chassis Version
Serial Number: Chassis Serial Number
Asset Tag: Asset-1234567890
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000001
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
Handle 0x0004, DMI type 4, 40 bytes
Processor Information
Socket Designation: Socket 775
Type: Central Processor
Family: Other
Manufacturer: Intel
ID: 7A 06 01 00 FF FB EB BF
Signature: Type 0, Family 6, Model 23, Stepping 10
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Multi-threading)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: Intel® Core™2 Quad CPU Q9550 @ 2.83GHz
Voltage: 1.3 V
External Clock: 333 MHz
Max Speed: 3800 MHz
Current Speed: 2833 MHz
Status: Populated, Enabled
Upgrade: Socket LGA775
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: 0x0007
Serial Number: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Characteristics: None
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1-Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 32 kB
Maximum Size: 32 kB
Supported SRAM Types:
Other
Installed SRAM Type: Other
Speed: Unknown
Error Correction Type: Parity
System Type: Data
Associativity: 2-way Set-associative
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2-Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 6144 kB
Maximum Size: 6144 kB
Other
Speed: Unknown
Error Correction Type: Single-bit ECC
System Type: Data
Handle 0x0007, DMI type 7, 19 bytes
Cache Information
Socket Designation: L3-Cache
Configuration: Disabled, Not Socketed, Level 3
Operational Mode: Unknown
Installed Size: 0 kB
Maximum Size: 0 kB
Unknown
Installed SRAM Type: Unknown
Speed: Unknown
Error Correction Type: Unknown
System Type: Unknown
Associativity: Unknown
Je ne connais pas grand chose, mais j’ai cru comprendre dans ce retour de commande que le cache L2 était de : "…Installed Size: 6144 kB…"
alors que j’ai lu que le Q9550 avait un cache L2 de 12Mo.
Je me trompe ?
Ce processeur a un défaut ?
j’ai mal utilisé dmidecode, ou alors j’ai mal interprété son retour ?
ma carte mère est en cause ? (le bios a été mis à jour)
Si quelqu’un pouvait m’éclairer, me donner des liens ou autre…
D’avance je vous remercie.
