bonjour, ![]()
voila ,je n’arrive pas a avoir les temperatures de la carte mere,du cpu et du disc
voila mon conky:
[quote][#avoid flicker
double_buffer yes
#own window to run simultanious 2 or more conkys
own_window yes
own_window_transparent yes
own_window_type normal
own_window_hints undecorate,sticky,skip_taskbar,skip_pager
#borders
draw_borders no
border_margin 3
#shades
draw_shades no
#position
gap_x 0
gap_y 4
alignment top_left
#behaviour
update_interval 1
#colour
default_color ff3333
#default_shade_color 000000
own_window_colour ff3333
#font
use_xft yes
xftfont sans:size=11
Force UTF8? note that UTF8 support required XFT
override_utf8_locale yes
#to prevent window from moving
use_spacer none
minimum_size 1024 0
#mpd
#mpd_host localhost
#mpd_port 6600
TEXT
${alignc}Date: ${color e0e0e0}${time %d/%m/%y}${color} Time: ${color e0e0e0}${time %H:%M}${color} | Kernel: ${color e0e0e0}$kernel${color} Uptime: ${color e0e0e0}${uptime_short}${color} | Cpu: ${color e0e0e0}${cpu}%${color} Ram: ${color e0e0e0}${memperc}%${color} Swap: ${color e0e0e0}${swapperc}%${color} Disk: ${color e0e0e0}${fs_used_perc /}%${color} | Motherboard: ${color e0e0e0}${execi 300 sensors | grep M/B | cut -c15-16 ;}°C${color} Cpu: ${color e0e0e0}${execi 300 sensors | grep CPU | cut -c15-16 ;}°C${color} Disk: ${color e0e0e0}${execi 300 nc localhost 7634 | cut -c29-30 ;}°C${color} | ${if_existing /proc/net/route wlan0}Signal: ${color e0e0e0}${wireless_link_qual wlan0}%${color} Up: ${color e0e0e0}${upspeed wlan0} kb/s${color} Down: ${color e0e0e0}${downspeed wlan0} kb/s${color}${else}${if_existing /proc/net/route eth0}Up: ${color e0e0e0}${upspeed eth0} kb/s${color} Down: ${color e0e0e0}${downspeed eth0} kb/s${color}${endif}${else}Network Unavailable${endif}${alignc}[/quote]
et la partie interressente du conky:
j’ai installé “hddtemp” ainsi que “lm-sensors”,j’ai fait aussi “sensors-detect”
j’ai recuperer ce conky sur “gnome-look”
