j’ai une machine qui fait dhcp, dns, tftpd et pxe par dnsmasq.
je souhaite me connecter sur 10.8.0.1 en tftp “client” et poussé un fichier dans le repoire cible mais ça coince avec l’erreur.
tftp 10.8.0.1
tftp> put f1.txt
Error code 4: requête de 10.8.0.1 non supportée
tftp> put f1.txt /var/lib/tftpboot
tftp> get f1.txt
Received 7 bytes in 0.0 seconds
tftp>
tftp> status
Connected to 10.8.0.1.
Mode: netascii Verbose: on Tracing: off
Rexmt-interval: 5 seconds, Max-timeout: 25 seconds
tftp> status
tftp> ascii
mode set to netascii
tftp> status
tftp> binary
mode set to octet
tftp> status
Mode: octet Verbose: on Tracing: off
tftp> put f1.txt
putting f1.txt to 10.8.0.1:f1.txt [octet]
tftp> mode
Using octet mode to transfer files.
tftp> status
/var/log/syslog:Jan 23 12:44:09 localhost dnsmasq-tftp[3591]: requête de 10.8.0.1 non supportée
/var/log/syslog:Jan 23 13:57:32 localhost dnsmasq-tftp[3591]: envoyé /var/lib/tftpboot/f1.txt à 10.8.0.1
/var/log/syslog:Jan 23 14:00:10 localhost dnsmasq-tftp[3591]: requête de 10.8.0.1 non supportée
/var/log/syslog:Jan 23 14:00:18 localhost dnsmasq-tftp[3591]: envoyé /var/lib/tftpboot/f1.txt à 10.8.0.1
/var/log/syslog:Jan 23 14:00:25 localhost dnsmasq-tftp[3591]: requête de 10.8.0.1 non supportée
tftp 127.0.0.1
tftp> get f1.txt
tftp> put f1.txt
mon dnsmasq.conf
[code]cat /etc/dnsmasq.conf
Only listen to routers’ LAN NIC. Doing so opens up tcp/udp port 53 to
localhost and udp port 67 to world:
interface=eth4
dnsmasq will open tcp/udp port 53 and udp port 67 to world to help with
dynamic interfaces (assigning dynamic ips). Dnsmasq will discard world
requests to them, but the paranoid might like to close them and let the
kernel handle them:
bind-interfaces
Dynamic range of IPs to make available to LAN pc
dhcp-range=10.8.0.10,10.8.0.30,12h
If you’d like to have dnsmasq assign static IPs, bind the LAN computer’s
NIC MAC address:
#dhcp-host=aa:bb:cc:dd:ee:ff,192.168.111.50
listen-address=127.0.0.1
lts client
rootpath option
###dhcp-option=17,/opt/ltsp/amd64
define common netboot types
dhcp-vendorclass=etherboot,Etherboot
dhcp-vendorclass=pxe,PXEClient
Set the boot filename for BOOTP.
dhcp-boot=net:pxe,pxelinux.0
enable the TFTP server (needs dnsmasq 2.36+)
enable-tftp
tftp-root=/var/lib/tftpboot
mon but finale est de pouvoir utiliser http://hdt-project.org/wiki/BootParameters#dump
