Thinkpad X31 problème de lecteur dvd
J’ai des problèmes récurrents avec mon lecteur de dvd (thinkpad X31 ibm). Heureusement, je ne l’utilise pas souvent.
Lorsque j’insère un dvd voici ce que me dis dmesg : [ 1493.028120] hdc: status error: status=0x00 { } [ 1493.028128] ide: failed opcode was: unknown [ 1493.028186] hdc: status error: status=0x00 { } [ 1493.028188] ide: failed opcode was: unknown [ 1493.028235] hdc: status error: status=0x00 { } [ 1493.028237] ide: failed opcode was: unknown [ 1493.028298] hdc: status error: status=0x00 { } [ 1493.028301] ide: failed opcode was: unknown [ 1493.028355] hdc: status error: status=0x00 { } [ 1493.028357] ide: failed opcode was: unknown [ 1495.028116] hdc: status error: status=0x00 { } [ 1495.028123] ide: failed opcode was: unknown [ 1495.028181] hdc: status error: status=0x00 { } [ 1495.028183] ide: failed opcode was: unknown [ 1495.028230] hdc: status error: status=0x00 { } [ 1495.028232] ide: failed opcode was: unknown [ 1495.028292] hdc: status error: status=0x00 { } [ 1495.028295] ide: failed opcode was: unknown [ 1495.028349] hdc: status error: status=0x00 { } [ 1495.028351] ide: failed opcode was: unknown [ 1497.028138] hdc: status error: status=0x00 { } [ 1497.028146] ide: failed opcode was: unknown [ 1497.028205] hdc: status error: status=0x00 { } [ 1497.028207] ide: failed opcode was: unknown [ 1497.028254] hdc: status error: status=0x00 { } [ 1497.028257] ide: failed opcode was: unknown [ 1497.028319] hdc: status error: status=0x00 { } [ 1497.028321] ide: failed opcode was: unknown [ 1497.028377] hdc: status error: status=0x00 { } [ 1497.028379] ide: failed opcode was: unknown [ 1499.028135] hdc: status error: status=0x00 { } [ 1499.028143] ide: failed opcode was: unknown [ 1499.028201] hdc: status error: status=0x00 { } [ 1499.028203] ide: failed opcode was: unknown [ 1499.028250] hdc: status error: status=0x00 { } [ 1499.028253] ide: failed opcode was: unknown [ 1499.028312] hdc: status error: status=0x00 { } [ 1499.028315] ide: failed opcode was: unknown [ 1499.028370] hdc: status error: status=0x00 { } [ 1499.028372] ide: failed opcode was: unknown Voici mon fichier /etc/fstab : [code]$ cat /etc/fstab
/etc/fstab: static file system information.
proc /proc proc defaults 0 0
/dev/hda1 / ext3 noatime,errors=remount-ro 0 1
/dev/hda6 /home ext3 noatime 0 2
/dev/hda5 none swap sw 0 0
/dev/hdc /media/cdrom0 udf,iso9660 user,noauto 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto 0 0
/dev/sda1 /media/sda1 vfat rw,user,noauto 0 0
/dev/sdb1 /media/flash vfat rw,user,noauto 0 0
[/code] Est-ce que mon lecteur de dvd souffre d’un problème matériel ? (j’ai acheté mon ordinateur d’occasion) ou est-ce qu’il s’agit d’un problème de configuration ?
À noter que je peux extraire un cd audio sans problème.
