Touchpad xfce scroll et taping
Bonjour, j’utilise xfce4 (Version : 4.8.0.3) sur mon portable.
Tout roule sauf le tapping et le scrolling du touchpad (alors qu’ils fonctionnent sous gnome 3).
Quelqu’un est il confronté au même problème et si oui comment l’a t il résolu ?
thx
Et la marmotte elle doit deviner quel touchpad c’est?
Comme a dit triangle il faut connaître ton touchpad pour pouvoir avancer.
Sinon tu peux commencer par regarder le man de synaptics : http://www.x.org/archive/X11R7.5/doc/man/man4/synaptics.4.html
bah, c’est pas une super marmotte ?
:033
[quote=“crustyourmind”]bah, c’est pas une super marmotte ?
:033[/quote]
Pas compris ???
Alors voila les sorties demandées
[code]cyrille@trollfest:~$ cat /usr/share/X11/xorg.conf.d/50-synaptics.conf
Example xorg.conf.d snippet that assigns the touchpad driver
to all touchpads. See xorg.conf.d(5) for more information on
InputClass.
DO NOT EDIT THIS FILE, your distribution will likely overwrite
it when updating. Copy (and rename) this file into
/etc/X11/xorg.conf.d first.
Additional options may be added in the form of
Option “OptionName” “value”
Section "InputClass"
Identifier "touchpad catchall"
Driver "synaptics"
MatchIsTouchpad “on”
This option is recommend on all Linux systems using evdev, but cannot be
enabled by default. See the following link for details:
http://who-t.blogspot.com/2010/11/how-to-ignore-configuration-errors.html
MatchDevicePath “/dev/input/event*”
EndSection
Identifier "touchpad ignore duplicates"
MatchIsTouchpad "on"
MatchOS "Linux"
MatchDevicePath "/dev/input/mouse*"
Option “Ignore” "on"
EndSection
This option enables the bottom right corner to be a right button on
non-synaptics clickpads.
This option is only interpreted by clickpads.
Identifier "Default clickpad buttons"
MatchDriver "synaptics"
Option “SoftButtonAreas” "50% 0 82% 0 0 0 0 0"
EndSection
This option disables software buttons on Apple touchpads.
Identifier "Disable clickpad buttons on Apple touchpads"
MatchProduct "Apple|bcm5974"
Option “SoftButtonAreas” "0 0 0 0 0 0 0 0"
EndSection
As tu regardé le man de synaptics ?
Je sais que la solution est dedans.
J’ai un Aurore BB1-i5-4-H5 et par le passé je devais créer un script avec les commandes de synaptic afin d’activer les options du touchpad.
Avec gnome 3 plus ce souci (mais bien d’autres …)
OK je vais lire attentivement ce man, mais demain :wink:
par contre à priori il ne reconnaît pas mes cartes SD, tu n’as pas eu de problèmes de ce coté ?
En tout cas, merci
regarde synclient ou xinput
j’utilise synclient. Avant je lançais ceci lorsque ma session démarrait , maintenant je le fais partir avec X.
j’ai crée un fichier /etc/X11/Xsession.d/60synatics-scroll et j’ai mis dedans
synclient VertEdgeScroll=1
synclient HorizEdgeScroll=1
deux à lire:
http://www.debian-fr.org/acceleration-souris-xfce-t35397.html
http://www.debian-fr.org/tapotement-du-touchpad-t24821.html
cool merci j’essaie tout cela cet ap. midi.
pour le SD c’est bon
bugs.launchpad.net/ubuntu/+sour … bug/971876
je m’occupe du scroll sous xfce :wink:
OK
marche à merveille
Bien vu limax, je l’avais oubli ce petit là.
@crustyourmind : tu peux même créer un script afin d’appliquer les changements au démarrage.
Le man de synaptic est dans le but de modifier le fichier xorg.conf mais vu que celui-ci n’est plus présent …
oui oui c’est ce que j’ai fait :wink:
ça marche nickel. Thx
