Bonjour tout le monde !
Alors avec les modifications du script “test.sh” faites, ça me donne ceci :
[code]root@aymeric-laptop:/home/aymeric# /home/aymeric/test.sh
Internet Systems Consortium DHCP Client 4.1.1-P1
Copyright 2004-2010 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/eth0/00:0e:9b:26:95:0a
Sending on LPF/eth0/00:0e:9b:26:95:0a
Sending on Socket/fallback
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 13
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 11
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 16
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
Quand au fichier /tmp/log, il est affreusement long… Et c’est encore incompréhensible pour moi ! Je vous le colle quand même ? Oui, bon allé c’est parti… Mais en fait je crois qu’il me renvoie 12 fois la même chose ?!ioctl[SIOCSIWGENIE]: Operation not supported
Initializing interface 'eth0' conf 'wpa_Livebox-7A6F.conf' driver 'wext' ctrl_interface 'N/A' bridge 'N/A'
Configuration file 'wpa_Livebox-7A6F.conf' -> '/home/aymeric/wpa_Livebox-7A6F.conf'
Reading configuration file '/home/aymeric/wpa_Livebox-7A6F.conf'
ctrl_interface='/var/run/wpa_supplicant'
ap_scan=1
Priority group 0
id=0 ssid='Livebox-7A6F'
Initializing interface (2) 'eth0'
SIOCGIWRANGE: WE(compiled)=22 WE(source)=19 enc_capa=0x0
capabilities: key_mgmt 0x0 enc 0x3 flags 0x0
WEXT: Operstate: linkmode=1, operstate=5
Own MAC address: 00:0e:9b:26:95:0a
wpa_driver_wext_set_wpa
Driver does not support WPA.
wpa_driver_wext_set_key: alg=0 key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_countermeasures
wpa_driver_wext_set_drop_unencrypted
RSN: flushing PMKID list in the driver
Setting scan request: 0 sec 100000 usec
WPS: UUID based on MAC address - hexdump(len=16): de 09 ac 2e 35 62 57 c6 98 48 62 06 5e c9 ce 51
WPS: Build Beacon and Probe Response IEs
WPS: * Version
WPS: * Wi-Fi Protected Setup State (0)
WPS: * Version
WPS: * Response Type (2)
WPS: * UUID-E
WPS: * Manufacturer
WPS: * Model Name
WPS: * Model Number
WPS: * Serial Number
WPS: * Primary Device Type
WPS: * Device Name
WPS: * Config Methods (0)
WPS: * RF Bands (3)
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
Added interface eth0
RTM_NEWLINK: operstate=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
RTM_NEWLINK, IFLA_IFNAME: Interface 'eth0' added
Wireless event: cmd=0x8b06 len=8
RTM_NEWLINK: operstate=0 ifi_flags=0x11003 ([UP][LOWER_UP])
State: DISCONNECTED -> SCANNING
Starting AP scan (specific SSID)
Scan SSID - hexdump_ascii(len=12):
4c 69 76 65 62 6f 78 2d 37 41 36 46 Livebox-7A6F
Trying to get current scan results first without requesting a new scan to speed up initial association
Received 195 bytes of scan results (1 BSSes)
New scan results available
Selecting BSS from priority group 0
Try to find WPA-enabled AP
0: 00:18:e7:3c:78:82 ssid='Livebox-7A6F' wpa_ie_len=22 rsn_ie_len=0 caps=0x11
selected based on WPA IE
selected WPA AP 00:18:e7:3c:78:82 ssid='Livebox-7A6F'
Trying to associate with 00:18:e7:3c:78:82 (SSID='Livebox-7A6F' freq=2412 MHz)
Cancelling scan request
WPA: clearing own WPA/RSN IE
Automatic auth_alg selection: 0x1
WPA: using IEEE 802.11i/D3.0
WPA: Selected cipher suites: group 8 pairwise 8 key_mgmt 2 proto 1
WPA: set AP WPA IE - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
WPA: clearing AP RSN IE
WPA: using GTK TKIP
WPA: using PTK TKIP
WPA: using KEY_MGMT WPA-PSK
WPA: Set own WPA IE default - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
No keys have been configured - skip key clearing
State: SCANNING -> ASSOCIATING
wpa_driver_wext_set_operstate: operstate 0->0 (DORMANT)
WEXT: Operstate: linkmode=-1, operstate=5
wpa_driver_wext_associate
wpa_driver_wext_set_psk
Association request to the driver failed
Setting authentication timeout: 5 sec 0 usec
EAPOL: External notification - EAP success=0
EAPOL: External notification - EAP fail=0
EAPOL: External notification - portControl=Auto
Wireless event: cmd=0x8b04 len=12
EAPOL: disable timer tick
Authentication with 00:18:e7:3c:78:82 timed out.
Added BSSID 00:18:e7:3c:78:82 into blacklist
State: ASSOCIATING -> DISCONNECTED
EAPOL: External notification - portEnabled=0
EAPOL: External notification - portValid=0
Setting scan request: 0 sec 0 usec
Starting AP scan (broadcast SSID)
Scan requested (ret=0) - scan timeout 5 seconds
Wireless event: cmd=0x8b19 len=8
WPA: using GTK TKIP
WPA: using PTK TKIP
BSSID 00:18:e7:3c:78:82 blacklist count incremented to 2
Scan requested (ret=0) - scan timeout 30 seconds
skip - blacklisted
Try to find non-WPA AP
skip - blacklisted
No APs found - clear blacklist and try again
Removed BSSID 00:18:e7:3c:78:82 from blacklist (clear)
WPA: using GTK TKIP
WPAioctl[SIOCSIWGENIE]: Operation not supported
: using PTK TKIP
WPA: using GTK TKIP
WPA: using PTK TKIP
Wireless event: cmd=0xioctl[SIOCSIWGENIE]: Operation not supported
8b19 len=8
skip - blacklisted
skip - blacklisted
WPA: using GTK TKIP
WPA: using PTK TKIP
WPA: using GTK TKIP
WPA: using PTK TKIP
EAPOL: External notificatioioctl[SIOCSIWGENIE]: Operation not supported
skip - blacklisted
skip - blacklisted
WPA: using GTK TKIP
WPA: using PTK TKIP
selected based oioctl[SIOCSIWGENIE]: Operation not supported
n WPA IE
WPA: using GTK TKIP
WPA: using PTK TKIP
skip - blacklisted
skip - blacklisted
WPA: using GTK TKIP
WPA: using PTK TKIP
RTM_NEWLINK, IFLA_IFNAME: Interface 'eth0' aioctl[SIOCSIWGENIE]: Operation not supported
dded
WPA: using GTK TKIP
WPA: using PTK TKIP
skip - blacklisted
skip - blacklisted
Trying to associate with 00:18:e7:3c:78:82 (SSID='Livebox-7ioctl[SIOCSIWGENIE]: Operation not supported
A6F' freq=2412 MHz)
WPA: using GTK TKIP
WPA: using PTK TKIP
WPA: using GTK TKIP
WPA: using PTK TKIP
Setting scan request: 0 secioctl[SIOCSIWGENIE]: Operation not supported
0 usec
skip - blacklisted
skip - blacklisted
WPA: using GTK TKIP
WPA: using PTK TKIP
WPA: using GTK TKIP
WPA: using PTK TKIP
State: SCANNING -> ioctl[SIOCSIWGENIE]: Operation not supported
ASSOCIATING
skip - blacklisted
skip - blacklisted
WPA: using GTK TKIP
WPA: using PTK TKIP
RTM_NEWLINK: oioctl[SIOCSIWGENIE]: Operation not supported
WPA: using GTK TKIP
WPA: using PTK TKIP
skip - blacklisted
skip - blacklisted
WPA: using GTK TKIP
WPA: using PTK TKIP
wpa_driver_wextioctl[SIOCSIWGENIE]: Operation not supported
Ensuite la commande iwconfig eth0 me revoie ça :
root@aymeric-laptop:/home/aymeric# iwconfig eth0
eth0 IEEE 802.11-DS ESSID:""
Mode:Managed Frequency:2.412 GHz Access Point: Invalid
Bit Rate=1 Mb/s Tx-Power=17 dBm Sensitivity=0/65535
Retry limit:16 RTS thr:off Fragment thr:off
Encryption key:****-****-****-****-****-****-** [4] Security mode:open
Power Management:off
Link Quality=0/100 Signal level=-106 dBm Noise level=-97 dBm
Rx invalid nwid:14915 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:84353 Missed beacon:0
Est-ce normal que le ESSID ne soit pas renseigné ?
La commande suivantes me renvoie :
[code]root@aymeric-laptop:/home/aymeric# iptables -L -v
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
pkts bytes target prot opt in out source destination
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
pkts bytes target prot opt in out source destination[/code]
Et enfin pour répondre à Triangle, ma carte WIFI est reconnue et s’appelle dans iwconfig, wifi0 mais aussi eth0. Or, lorsque je lance un essai de connection avec wifi0, ça va encore moins loin parce qu’il me dit ceci : Ignoring unknown interface wifi0=wifi0. Il semble donc que ce soit bien eth0 qui permette de me connecter et non pas wifi0. Après, à vrai dire, je n’en sais trop rien !
