[TRANSMISSION] Could not connect to tracker
Bonjour !
J’ai un VPS avec un daemon transmission qui tourne via systemctl. Le soucis est qu’il a des comportements plutot aleatoire. Certaines fois je n’ai aucun probleme pour telecharger des torrents, et d’autre fois il n’arrive pas a se connecter au tracker.
Transmission est lance via l’user debian-transmission, l’interface web est proxy via apache. Le port ‘XXXX’ est ouvert en INPUT.
Voici les infos utiles :
uname -a
[quote]Linux xxx.yyy 3.2.0-4-amd64 #1 SMP Debian 3.2.65-1 x86_64 GNU/Linux
cat /usr/lib/systemd/system/transmission.service
[quote][Unit]
Description=Transmission BitTorrent Daemon
After=network.target
[Service]
User=debian-transmission
Type=simple
ExecStart=/usr/bin/transmission-daemon -f --log-debug -e /home/debian-transmission/transmission.log
ExecReload=/bin/kill -s HUP $MAINPID
[Install]
WantedBy=multi-user.target
cat /home/debian-transmission/.config/settings.json
[quote] cat /home/debian-transmission/.config/transmission-daemon/settings.json
“alt-speed-down”: 50,
“alt-speed-enabled”: false,
“alt-speed-time-begin”: 540,
“alt-speed-time-day”: 127,
“alt-speed-time-enabled”: false,
“alt-speed-time-end”: 1020,
“alt-speed-up”: 50,
“bind-address-ipv4”: “0.0.0.0”,
“bind-address-ipv6”: “::”,
“blocklist-enabled”: false,
“blocklist-url”: “http://www.example.com/blocklist”,
“cache-size-mb”: 4,
“dht-enabled”: true,
“download-dir”: “/var/lib/transmission-daemon/downloads”,
“download-queue-enabled”: true,
“download-queue-size”: 5,
“encryption”: 1,
“idle-seeding-limit”: 30,
“idle-seeding-limit-enabled”: false,
“incomplete-dir”: “/var/lib/transmission-daemon/downloads”,
“incomplete-dir-enabled”: false,
“lpd-enabled”: false,
“message-level”: 3,
“peer-congestion-algorithm”: “”,
“peer-limit-global”: 240,
“peer-limit-per-torrent”: 60,
“peer-port”: xxxxx,
“peer-port-random-high”: 65535,
“peer-port-random-low”: 49152,
“peer-port-random-on-start”: false,
“peer-socket-tos”: “default”,
“pex-enabled”: true,
“port-forwarding-enabled”: false,
“preallocation”: 1,
“prefetch-enabled”: 1,
“queue-stalled-enabled”: true,
“queue-stalled-minutes”: 30,
“ratio-limit”: 2,
“ratio-limit-enabled”: false,
“rename-partial-files”: true,
“rpc-authentication-required”: false,
“rpc-bind-address”: “0.0.0.0”,
“rpc-enabled”: true,
“rpc-password”: “{xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”,
“rpc-port”: 9091,
“rpc-url”: “/transmission/”,
“rpc-username”: “”,
“rpc-whitelist”: “127.0.0.1”,
“rpc-whitelist-enabled”: false,
“scrape-paused-torrents-enabled”: true,
“script-torrent-done-enabled”: false,
“script-torrent-done-filename”: “”,
“seed-queue-enabled”: false,
“seed-queue-size”: 10,
“speed-limit-down”: 100,
“speed-limit-down-enabled”: false,
“speed-limit-up”: 100,
“speed-limit-up-enabled”: false,
“start-added-torrents”: true,
“trash-original-torrent-files”: false,
“umask”: 18,
“upload-slots-per-torrent”: 14,
“utp-enabled”: false
cat /home/debian-transmission/transmission.log
[quote][14:07:55.253] Saved “/home/debian-transmission/.config/transmission-daemon/resume/Visteur du Futur - Intégrale.9fd17c4ac6396722.resume” (bencode.c:1731)
[14:07:55.253] XXX Queued for verification (verify.c:260)
[14:07:55.253] XXX Verifying torrent (verify.c:218)
[14:07:55.253] XXX verifying torrent… (verify.c:61)
[14:07:55.253] XXX Verification is done. It took 0 seconds to verify 8604606399 bytes (8604606399 bytes per second) (verify.c:155)
[14:07:55.253] XXX Announcing to tracker (announcer.c:1532)
[14:08:12.254] YYY Scrape error: Could not connect to tracker (announcer.c:1259)
[14:08:12.254] YYY Retrying scrape in 946 seconds. (announcer.c:1268)
[14:08:59.257] XXX Could not connect to tracker (announcer.c:994)
[14:08:59.257] XXX Retrying announce in 314 seconds. (announcer.c:1003)
[14:09:32.259] XXX Scrape error: Could not connect to tracker (announcer.c:1259)
[14:09:32.259] XXX Retrying scrape in 956 seconds. (announcer.c:1268)
[14:09:43.260] Saved “/home/debian-transmission/.config/transmission-daemon/resume/YYY.9fd17c4ac53hp822.resume” (bencode.c:1731)
[14:09:43.260] Saved “/home/debian-transmission/.config/transmission-daemon/resume/XXX.9fd17c4ac6396722.resume” (bencode.c:1731)
[14:11:16.265] YYY Announcing to tracker (announcer.c:1532)
[14:11:23.266] DHT Finished bootstrapping (tr-dht.c:258)
[14:12:20.269] YYY Could not connect to tracker (announcer.c:994)
[14:12:20.269] YYY Retrying announce in 3655 seconds. (announcer.c:1003)
[14:14:13.276] XXX Announcing to tracker (announcer.c:1532)
[14:15:16.280] XXX Could not connect to tracker (announcer.c:994)
[14:15:16.280] XXX Retrying announce in 1820 seconds. (announcer.c:1003)
Si quelqu’un a une idee, je prends !
Merci d’avance !
Et par pur hasard le port ne serait pas XX969 si oui alors le problème peut aussi être du au tracker lui même qui décroche ?
Pour être sûr de ton port un netstat te permettra de visualiser tes ports en écoute, si aucune règle de filtrage n’est en place il ne devrait pas y avoir de problème.
Pour l’histoire du proxy, c’est juste pour l’interface web ?
Je confirme que le tracker de T411 est bancal depuis quelques mois déjà.
