Bonjour, j’arrive pas imprimer. Pourtant cette commande donne ;
[quote]hp-probe
HP Linux Imaging and Printing System (ver. 3.14.6)
Printer Discovery Utility ver. 4.1
Copyright © 2001-13 Hewlett-Packard Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
| SELECT CONNECTION (I/O) TYPE |
Num Connection Description
Type
0* usb Universal Serial Bus (USB)
1 net Network/Ethernet/Wireless (direct connection or JetDirect)
2 par Parallel Port (LPT:)
Enter number 0…2 for connection type (q=quit, enter=usb*) ? 0
Using connection type: usb
| DEVICE DISCOVERY |
Device URI Model
hp:/usb/Photosmart_C4500_series?serial=CN8CMG208K05CB HP Photosmart C4500 series
Found 1 printer(s) on the ‘usb’ bus.
Done.
J’installai cups, hplip et task-print-server excepté les paquets “pinned” (Bogues de gravité serious)
[quote]cat /etc/apt/preferences
Explanation: Pinned by apt-listbugs at 2014-06-26 10:54:46 +0200
Explanation: #745529: Please drop lcms1
Package: ghostscript
Pin: version *
Pin-Priority: -30000
Explanation: Pinned by apt-listbugs at 2014-06-26 10:55:14 +0200
Explanation: #694320: [gsfonts] Fonts include copyrighted adobe fragment all right reserved
Explanation: #694321: [gsfonts] Fonts include copyrighted adobe fragment all right reserved
Package: gsfonts
Pin: version *
[/quote]Il me manque peut-être des paquets ou il faut attendre ?
