Voici le HOWTO:
[quote]II. Linux and Mac OS X
Requirements for Building TrueCrypt for Linux and Mac OS X:
GNU Make
GNU C++ Compiler 4.0 or compatible
Apple Xcode (Mac OS X only)
pkg-config
wxWidgets 2.8 shared library and header files installed or wxWidgets 2.8 library source code (available at wxwidgets.org)
FUSE library and header files (available at fuse.sourceforge.net and code.google.com/p/macfuse)
RSA Security Inc. PKCS #11 Cryptographic Token Interface (Cryptoki) 2.20 header files (available at ftp://ftp.rsasecurity.com/pub/pkcs/pkcs-11/v2-20) located in a standard include path or in a directory defined by the environment variable ‘PKCS11_INC’.
Instructions for Building TrueCrypt for Linux and Mac OS X:
Change the current directory to the root of the TrueCrypt source code.
If you have no wxWidgets shared library installed, run the following command to configure the wxWidgets static library for TrueCrypt and to build it: $ make WX_ROOT=/usr/src/wxWidgets wxbuild The variable WX_ROOT must point to the location of the source code of the wxWidgets library. Output files will be placed in the ‘./wxrelease/’ directory.
To build TrueCrypt, run the following command: $ make or if you have no wxWidgets shared library installed: $ make WXSTATIC=1
If successful, the TrueCrypt executable should be located in the directory ‘Main’.
By default, a universal executable supporting both graphical and text user
interface is built. To build a console-only executable, which requires no GUI
library, use the ‘NOGUI’ parameter:
$ make NOGUI=1 WX_ROOT=/usr/src/wxWidgets wxbuild
$ make NOGUI=1 WXSTATIC=1
Requirements for Running TrueCrypt on Linux:
[quote]non tu n’as pas besoin de ça
et il y a même une version portable
tu dois télécharger l’archive .tar.gz puis choisir l’option “extract .deb” (ou un truc du style)
tu récupère le .deb dans ton /tmp (en principe)
tu décompresses le .deb (c’est une archive avant tout)
et tu décompresse encore les deux archives qu’il y a à l’intérieur[/quote]
Oui je sais mais je préfère compiler à partir des sources, de plus la version “portable” est censé être
uniquement pour ubuntu et non pour debian.
En tout cas, je trouve ça très très grave d’être obliger de télécharger des fichiers de façon non sécurisé nécessaire pour la compilation d’un logiciel de sécurité, surtout de chiffrement, c’est vraiment du grand n’importe quoi !
Imaginez que les logiciels que vous téléchargez via les dépots ne soit pas authentifiés…
Donc si quelqu’un sait ou je pourrais télécharger ces fichiers, ca m’aiderait vraiment
[quote]- RSA Security Inc. PKCS #11 Cryptographic Token Interface (Cryptoki) 2.20
environment variable ‘PKCS11_INC’.[/quote]
Merci.
