voici lspci -v
Mais je doute que cela vienne de la carte m’enfin !!
00:00.0 Host bridge: Silicon Integrated Systems [SiS] SiS645DX Host & Memory & AGP Controller (rev 01)
Subsystem: ASUSTeK Computer Inc. Device 8081
Flags: bus master, medium devsel, latency 32
Memory at d8000000 (32-bit, non-prefetchable) [size=64M]
Capabilities:
Kernel driver in use: agpgart-sis
00:01.0 PCI bridge: Silicon Integrated Systems [SiS] Virtual PCI-to-PCI bridge (AGP) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 64
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: d7000000-d7ffffff
Prefetchable memory behind bridge: e0000000-febfffff
00:02.0 ISA bridge: Silicon Integrated Systems [SiS] SiS962 [MuTIOL Media IO] (rev 25)
Flags: bus master, medium devsel, latency 0
00:02.1 SMBus: Silicon Integrated Systems [SiS] SiS961/2 SMBus Controller
Flags: medium devsel
I/O ports at e600 [size=32]
Kernel driver in use: sis96x_smbus
00:02.5 IDE interface: Silicon Integrated Systems [SiS] 5513 [IDE] (prog-if 80 [Master])
Subsystem: ASUSTeK Computer Inc. Device 807a
Flags: bus master, medium devsel, latency 128, IRQ 16
[virtual] Memory at 000001f0 (32-bit, non-prefetchable) [size=8]
[virtual] Memory at 000003f0 (type 3, non-prefetchable) [size=1]
[virtual] Memory at 00000170 (32-bit, non-prefetchable) [size=8]
[virtual] Memory at 00000370 (type 3, non-prefetchable) [size=1]
I/O ports at a400 [size=16]
Kernel driver in use: SIS_IDE
00:02.7 Multimedia audio controller: Silicon Integrated Systems [SiS] AC’97 Sound Controller (rev a0)
Subsystem: ASUSTeK Computer Inc. Device 80b0
Flags: bus master, medium devsel, latency 32, IRQ 18
I/O ports at 9400 [size=256]
I/O ports at 9000 [size=128]
Capabilities:
Kernel driver in use: Intel ICH
00:03.0 USB Controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f) (prog-if 10 [OHCI])
Flags: bus master, medium devsel, latency 32, IRQ 20
Memory at d6800000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci_hcd
00:03.1 USB Controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f) (prog-if 10 [OHCI])
Flags: bus master, medium devsel, latency 32, IRQ 21
Memory at d6000000 (32-bit, non-prefetchable) [size=4K]
00:03.3 USB Controller: Silicon Integrated Systems [SiS] USB 2.0 Controller (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 32, IRQ 23
Memory at d5800000 (32-bit, non-prefetchable) [size=4K]
Capabilities:
Kernel driver in use: ehci_hcd
00:04.0 Ethernet controller: Silicon Integrated Systems [SiS] SiS900 PCI Fast Ethernet (rev 91)
Subsystem: ASUSTeK Computer Inc. Motherboard P4S800D-X
Flags: bus master, medium devsel, latency 32, IRQ 19
I/O ports at 8800 [size=256]
Memory at d5000000 (32-bit, non-prefetchable) [size=4K]
Expansion ROM at dffe0000 [disabled] [size=128K]
Capabilities:
Kernel driver in use: sis900
01:00.0 VGA compatible controller: ATI Technologies Inc RV280 [Radeon 9200] (rev 01) (prog-if 00 [VGA controller])
Subsystem: Giga-byte Technology Device 4026
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 16
Memory at f0000000 (32-bit, prefetchable) [size=128M]
I/O ports at d800 [size=256]
Memory at d7800000 (32-bit, non-prefetchable) [size=64K]
Expansion ROM at effe0000 [disabled] [size=128K]
Capabilities:
01:00.1 Display controller: ATI Technologies Inc RV280 [Radeon 9200] (Secondary) (rev 01)
Subsystem: Giga-byte Technology Device 4027
Memory at e0000000 (32-bit, prefetchable) [size=128M]
Memory at d7000000 (32-bit, non-prefetchable) [size=64K]
Capabilities:
