Je suis sous gnome installé sur kde
J’ai tapé # aptitude install apt-listbugs et voila ce qu’on me dit :
[code]eglibc (2.13-25) unstable; urgency=medium
Starting with the eglibc package version 2.13-5, the libraries are
shipped in the multiarch directory /lib/ instead of the more
traditional /lib, where is the multiarch triplet and can be
retrieved with ‘dpkg-architecture -qDEB_HOST_MULTIARCH’. Similarly the
includes are now shipped in /usr/include/ instead of the more
traditional /usr/include.
The toolchain in Debian has been updated to cope with that, and most
build systems should be unaffected. If you are using a non-Debian
toolchain to build your software and it is not able to cope with
multiarch, you might try to pass the following options to your
compiler:
-B/usr/lib/<triplet> -I/usr/include/<triplet>
Alternatively if the build system makes hard to pass the above options,
you might try to set the LIBRARY_PATH and CPATH environment variables:
LIBRARY_PATH=/usr/lib/
CPATH=/usr/include/
export LIBRARY_PATH CPATH
– Aurelien Jarno aurel32@debian.org Mon, 09 Jan 2012 12:47:16 +0100
apt (0.8.11) unstable; urgency=low
- apt-get install pkg/experimental will now not only switch the
candidate of package pkg to the version from the release experimental
but also of all dependencies of pkg if the current candidate can’t
satisfy a versioned dependency.
– David Kalnischkies kalnischkies@gmail.com Fri, 03 Dec 2010 14:09:12 +0100
Il y a un tas de fichiers de disk-manager. J’ai cherche Synaptic , mais il n’y a pas de synaptic.
