Unknown chipset: NV120
Je suis sur une debian 9 à jour, mais impossible de lancer l’interface graphique.
J’ai une carte vidia nvidia Gforce 980 TI, j’utilise le driver nouveau (pour l’instant, je verrai après pour mettre le driver officiel). Dès que je boot j’ai un écran noir et qui clignote, impossible d’avoir un shell avec un ctrl + alt +f1-6, je boot sois en mode rescue soit par ssh pour pouvoir bricoler.
Dans les log de xorg j’ai ceci:
[   722.640] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[   722.640] (II) xfree86: Adding drm device (/dev/dri/card0)
[   722.641] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
[   722.642] (--) PCI:*(0:1:0:0) 10de:17c8:10de:1151 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[   722.642] (II) LoadModule: "glx"
[   722.642] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   722.649] (II) Module glx: vendor="X.Org Foundation"
[   722.649] 	compiled for 1.19.2, module version = 1.0.0
[   722.649] 	ABI class: X.Org Server Extension, version 10.0
[   722.649] (==) Matched nouveau as autoconfigured driver 0
[   722.649] (==) Matched nv as autoconfigured driver 1
[   722.649] (==) Matched modesetting as autoconfigured driver 2
[   722.649] (==) Matched fbdev as autoconfigured driver 3
[   722.649] (==) Matched vesa as autoconfigured driver 4
[   722.649] (==) Assigned the driver to the xf86ConfigLayout
[   722.649] (II) LoadModule: "nouveau"
[   722.649] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[   722.650] (II) Module nouveau: vendor="X.Org Foundation"
[   722.650] 	compiled for 1.19.3, module version = 1.0.13
[   722.650] 	Module class: X.Org Video Driver
[   722.650] 	ABI class: X.Org Video Driver, version 23.0
[   722.650] (II) LoadModule: "nv"
[   722.650] (WW) Warning, couldn't open module nv
[   722.650] (II) UnloadModule: "nv"
[   722.650] (II) Unloading nv
[   722.650] (EE) Failed to load module "nv" (module does not exist, 0)
[   722.650] (II) LoadModule: "modesetting"
[   722.650] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[   722.651] (II) Module modesetting: vendor="X.Org Foundation"
[   722.651] 	compiled for 1.19.2, module version = 1.19.2
[   722.651] 	Module class: X.Org Video Driver
[   722.651] 	ABI class: X.Org Video Driver, version 23.0
[   722.651] (II) LoadModule: "fbdev"
[   722.651] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[   722.651] (II) Module fbdev: vendor="X.Org Foundation"
[   722.651] 	compiled for 1.19.0, module version = 0.4.4
[   722.651] (II) LoadModule: "vesa"
[   722.651] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[   722.652] (II) Module vesa: vendor="X.Org Foundation"
[   722.652] 	compiled for 1.19.0, module version = 2.3.4
[   722.652] 	Module class: X.Org Video Driver
[   722.652] 	ABI class: X.Org Video Driver, version 23.0
[   722.652] (II) NOUVEAU driver Date:   Tue Sep 20 00:31:06 2016 -0400
[   722.652] (II) NOUVEAU driver for NVIDIA chipset families :
[   722.652] 	RIVA TNT        (NV04)
[   722.652] 	RIVA TNT2       (NV05)
[   722.652] 	GeForce 256     (NV10)
[   722.652] 	GeForce 2       (NV11, NV15)
[   722.652] 	GeForce 4MX     (NV17, NV18)
[   722.652] 	GeForce 3       (NV20)
[   722.652] 	GeForce 4Ti     (NV25, NV28)
[   722.652] 	GeForce FX      (NV3x)
[   722.652] 	GeForce 6       (NV4x)
[   722.652] 	GeForce 7       (G7x)
[   722.652] 	GeForce 8       (G8x)
[   722.652] 	GeForce GTX 200 (NVA0)
[   722.652] 	GeForce GTX 400 (NVC0)
[   722.652] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[   722.652] (II) FBDEV: driver for framebuffer: fbdev
[   722.652] (II) VESA: driver for VESA chipsets: vesa
[   722.710] (II) [drm] nouveau interface version: 1.3.1
[   722.710] (EE) Unknown chipset: NV120
[   722.710] (WW) Falling back to old probe method for modesetting
[   722.710] (II) modeset(1): using default device
[   722.710] (II) Loading sub module "fbdevhw"
[   722.710] (II) LoadModule: "fbdevhw"
[   722.711] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[   722.712] (II) Module fbdevhw: vendor="X.Org Foundation"
[   722.712] 	compiled for 1.19.2, module version = 0.0.2
[   722.712] 	ABI class: X.Org Video Driver, version 23.0
[   722.712] (**) FBDEV(2): claimed PCI slot 1@0:0:0
[   722.712] (II) FBDEV(2): using default device
[   722.712] (WW) Falling back to old probe method for vesa
[   722.712] (EE) Screen 0 deleted because of no matching config section.
[   722.712] (II) UnloadModule: "modesetting"
[   722.712] (EE)
Fatal server error:
[   722.712] (EE) Cannot run in framebuffer mode. Please specify busIDs        for all framebuffer devices
[   722.712] (EE)
[   722.712] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[   722.712] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   722.712] (EE)
[   722.729] (EE) Server terminated with error (1). Closing log file.
Merci du coup de main! :slight_smile:
NV120 ne figure pas dans les carte supporter par nouveau (https://nouveau.freedesktop.org/wiki/CodeNames/)
les solution qui me vienne a l’esprit sont:
_sois tu boot en utilisant ton cpu pour le graphique
_sois mettre le driver Nvidia
