Bonjour, j’ai télécharger Urban terror (torrents) ensuite j"ai rendu executable la version i362 et je l’ai lancer en console,
Il se lance mais se quitte directement tout seul,
Voici le rapport de console,
Que faire ?
[code]val@Valentin:~$ '/home/val/Desktop/UrbanTerror/ioUrbanTerror.i386’
ioQ3 1.35urt linux-i386 Dec 20 2007
----- FS_Startup -----
Going through search path…
99 files in pk3 files
execing default.cfg
couldn’t exec q3config.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
----- Client Initialization -----
Couldn’t read q3history.
----- Initializing Renderer ----
QKEY found.
----- Client Initialization Complete -----
----- R_Init -----
…loading libGL.so.1:
Calling SDL_Init(SDL_INIT_VIDEO)…
SDL_Init(SDL_INIT_VIDEO) passed.
Initializing OpenGL display
…setting mode 4: 800 600
Using 4/4/4 Color bits, 24 depth, 0 stencil display.
GL_RENDERER: ATI Radeon 9550 / X1050 Series
Initializing OpenGL extensions
…ignoring GL_S3_s3tc
…ignoring GL_EXT_texture_env_add
…using GL_ARB_multitexture
…using GL_EXT_compiled_vertex_array
…GL_EXT_texture_filter_anisotropic not found
GL_VENDOR: ATI Technologies Inc.
GL_VERSION: 2.1.8304 Release
GL_MAX_TEXTURE_SIZE: 2048
GL_MAX_ACTIVE_TEXTURES_ARB: 8
PIXELFORMAT: color(32-bits) Z(24-bit) stencil(0-bits)
MODE: 4, 800 x 600 fullscreen hz:N/A
GAMMA: hardware w/ 0 overbright bits
CPU:
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_NEAREST
picmip: 1
texture bits: 32
multitexture: enabled
compiled vertex arrays: enabled
texenv add: disabled
compressed textures: disabled
Initializing Shaders
^3WARNING: no shader files found
Received signal 11, exiting…
----- CL_Shutdown -----
RE_Shutdown( 1 )
Erreur de segmentation
val@Valentin:~$
