Usb 9-4: device descriptor read/64, error -32
Bonsoir,
j’ai récupéré un nouvel ordinateur, sur lequel j’ai des prises USB 2 et 2 prises USB 3.0. Sous squeeze, toutes marchent sans soucis. Sous sid, dès que je branche quelque chose (ici une souris) sur une des prises USB 2, j’ai le message d’erreur suivant :
[ 4099.972537] usb 9-3: new low-speed USB device number 25 using ohci-pci
[ 4100.576234] usb 9-3: device not accepting address 25, error -32
[ 4100.715623] usb 9-3: new low-speed USB device number 26 using ohci-pci
[ 4101.123970] usb 9-3: device not accepting address 26, error -32
[ 4101.263919] usb 9-3: new low-speed USB device number 27 using ohci-pci
[ 4101.403842] usb 9-3: device descriptor read/64, error -32
[ 4102.039538] usb 9-3: device descriptor read/64, error -32
[ 4102.283429] usb 9-3: device descriptor read/64, error -32
[ 4102.387379] hub 9-0:1.0: unable to enumerate USB device on port 3
Quand je connecte mon imprimante, j’ai un message d’erreur légèrement différent :
[ 5407.737679] usb 3-2: new high-speed USB device number 5 using ehci-pci
[ 5407.850041] usb 3-2: device descriptor read/64, error -32
[ 5408.065920] usb 3-2: device descriptor read/64, error -32
[ 5408.281430] usb 3-2: new high-speed USB device number 6 using ehci-pci
[ 5408.393363] usb 3-2: device descriptor read/64, error -32
[ 5408.613216] usb 3-2: device descriptor read/64, error -32
[ 5408.825156] usb 3-2: new high-speed USB device number 7 using ehci-pci
[ 5409.232948] usb 3-2: device not accepting address 7, error -32
[ 5409.344909] usb 3-2: new high-speed USB device number 8 using ehci-pci
[ 5409.752699] usb 3-2: device not accepting address 8, error -32
[ 5409.752720] hub 3-0:1.0: unable to enumerate USB device on port 2
[ 5410.068555] usb 6-2: new full-speed USB device number 2 using ohci-pci
[ 5410.208483] usb 6-2: device descriptor read/64, error -32
[ 5410.456371] usb 6-2: device descriptor read/64, error -32
[ 5410.696252] usb 6-2: new full-speed USB device number 3 using ohci-pci
[ 5410.836177] usb 6-2: device descriptor read/64, error -32
[ 5411.084061] usb 6-2: device descriptor read/64, error -32
[ 5411.323949] usb 6-2: new full-speed USB device number 4 using ohci-pci
[ 5411.731746] usb 6-2: device not accepting address 4, error -32
[ 5411.867684] usb 6-2: new full-speed USB device number 5 using ohci-pci
[ 5412.275485] usb 6-2: device not accepting address 5, error -32
[ 5412.275529] hub 6-0:1.0: unable to enumerate USB device on port 2
J’ai cherché sur internet mais toutes les solutions trouvées (éteindre le PC, débrancher le cordon, attendre 5mn et redémarrer ou modifier /sys/module/usbcore/parameters/old_scheme_first en Y) n’ont rien donné …
À titre de comparaison le dmesg sur une prise usb 3.0 :
[ 5732.948611] usb 1-1: new low-speed USB device number 4 using xhci_hcd
[ 5732.998290] usb 1-1: New USB device found, idVendor=046d, idProduct=c03e
[ 5732.998294] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5732.998296] usb 1-1: Product: USB-PS/2 Optical Mouse
[ 5732.998298] usb 1-1: Manufacturer: Logitech
[ 5732.998381] usb 1-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 5733.011539] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-1/1-1:1.0/input/input21
[ 5733.011806] hid-generic 0003:046D:C03E.0004: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:02:00.0-1/input0
J’ai rencontré ce genre de message avec la webcam interne mais j’en avais conclu que la connexion devait être physiquement rompue. Étonnant que ça fonctionne avec squeeze ou avec les ports usb3… Si je lis bien, les pilotes usb ehci-pci ou ohci-pci ne gèrent pas alors que le pilote xhci_hcd gère. J’ai soupçonné le 64 bits pendant un moment mais sans parvenir à le montrer.
Entre Squeeze et Sid l’eau a pas mal coulé sous les ponts. Peut-être tenter avec une Stable en Live pour aider à cerner d’où ça vient ?
@jcms33 : En effet, j’ai une squeeze 32bits et une sid 64 bits
@Zbf : exactement les mêmes message d’erreur sous une wheezy 64 bits.
Pour info quand je branche sous la squeeze, j’ai ce genre de message : (souris)
[  627.313524] usb 8-3: new low speed USB device using ohci_hcd and address 3
[  627.682660] usb 8-3: New USB device found, idVendor=1532, idProduct=000d
[  627.682664] usb 8-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  627.682667] usb 8-3: Product: Razer Diamondback 3G
[  627.682669] usb 8-3: Manufacturer: Razer
[  627.682761] usb 8-3: configuration #1 chosen from 1 choice
[  627.693887] input: Razer Razer Diamondback 3G as /devices/pci0000:00/0000:00:16.0/usb8/8-3/8-3:1.0/input/input7
[  627.693995] generic-usb 0003:1532:000D.0005: input,hidraw3: USB HID v1.10 Mouse [Razer Razer Diamondback 3G] on usb-0000:00:16.0-3/input0
(imprimante) :
[  476.509519] usb 1-2: new high speed USB device using ehci_hcd and address 3
[  476.643151] usb 1-2: New USB device found, idVendor=03f0, idProduct=5611
[  476.643155] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  476.643158] usb 1-2: Product: Photosmart C3100 series
[  476.643160] usb 1-2: Manufacturer: HP
[  476.643161] usb 1-2: SerialNumber: MY6B9C627Y04P9
[  476.643256] usb 1-2: configuration #1 chosen from 1 choice
[  476.643910] usblp0: USB Bidirectional printer dev 3 if 1 alt 0 proto 2 vid 0x03F0 pid 0x5611
[  476.644364] scsi7 : SCSI emulation for USB Mass Storage devices
[  476.644515] usb-storage: device found at 3
[  476.644517] usb-storage: waiting for device to settle before scanning
[  481.644625] usb-storage: device scan complete
[  481.645095] scsi 7:0:0:0: Direct-Access     HP       Photosmart C3180 1.00 PQ: 0 ANSI: 2
[  481.647582] sd 7:0:0:0: [sdd] Attached SCSI removable disk
Si je lis bien, ohci_hcd et ehci_hcd gèrent sous squeeze (32) mais ohci_pci et ehci_pci ne gèrent pas sous wheezy,jessie,sid (64) : les modules pci bloquant, les modules hcd ne prennent jamais le relais.
Oups, j’avais complètement zappé le sujet : en effet ça semble être le cas. néanmoins si je désactive ohci_pci et ehci_pci, quand j’essaie de brancher ma souris, je n’ai aucun message dans dmesg.
