Usb sur noyau 2.6.26 (lenny)
Suite au fil dans pause café je vais décrire mon problème principal ici.
Je branche ma clé usb, j’ai les lignes suivantes dans kern.log
Jan 15 15:21:39 obiwan kernel: [  301.180689] usb 1-3: new high speed USB device using ehci_hcd and address 6
Jan 15 15:21:39 obiwan kernel: [  301.313421] usb 1-3: configuration #1 chosen from 1 choice
Jan 15 15:21:39 obiwan kernel: [  301.314079] scsi4 : SCSI emulation for USB Mass Storage devices
Jan 15 15:21:39 obiwan kernel: [  301.314336] usb 1-3: New USB device found, idVendor=1976, idProduct=6025
Jan 15 15:21:39 obiwan kernel: [  301.314340] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 15 15:21:39 obiwan kernel: [  301.314343] usb 1-3: Product: Flash Disk
Jan 15 15:21:39 obiwan kernel: [  301.314345] usb 1-3: Manufacturer: CBM
Jan 15 15:21:39 obiwan kernel: [  301.314347] usb 1-3: SerialNumber: 2601230179B6D303
Jan 15 15:21:39 obiwan kernel: [  301.314380] usb-storage: device found at 6
Jan 15 15:21:39 obiwan kernel: [  301.314382] usb-storage: waiting for device to settle before scanning
Jan 15 15:21:44 obiwan kernel: [  306.312281] usb-storage: device scan complete
Jan 15 15:21:44 obiwan kernel: [  306.313009] scsi 4:0:0:0: Direct-Access     CBM      Flash Disk       5.00 PQ: 0 ANSI: 2
Jan 15 15:21:44 obiwan kernel: [  306.361416] sd 4:0:0:0: [sda] 1031936 512-byte hardware sectors (528 MB)
Jan 15 15:21:44 obiwan kernel: [  306.362003] sd 4:0:0:0: [sda] Write Protect is off
Jan 15 15:21:44 obiwan kernel: [  306.362009] sd 4:0:0:0: [sda] Mode Sense: 0b 00 00 08
Jan 15 15:21:44 obiwan kernel: [  306.362012] sd 4:0:0:0: [sda] Assuming drive cache: write through
Jan 15 15:21:44 obiwan kernel: [  306.364116] sd 4:0:0:0: [sda] 1031936 512-byte hardware sectors (528 MB)
Jan 15 15:21:44 obiwan kernel: [  306.364750] sd 4:0:0:0: [sda] Write Protect is off
Jan 15 15:21:44 obiwan kernel: [  306.364757] sd 4:0:0:0: [sda] Mode Sense: 0b 00 00 08
Jan 15 15:21:44 obiwan kernel: [  306.364759] sd 4:0:0:0: [sda] Assuming drive cache: write through
Jan 15 15:21:44 obiwan kernel: [  306.364762]  sda: sda1
Jan 15 15:21:44 obiwan kernel: [  306.366189] sd 4:0:0:0: [sda] Attached SCSI removable disk
Tout semble rouler.
Je copie un répertoire contenant plein de fichiers de 5Mo environ, la copie commence à un débit digne de l’usb2. Au bout de quelques secondes le débit tombe à 100ko environ.
Puis viennent les lignes suivantes (tjs dans kern.log)
Jan 15 15:23:21 obiwan kernel: [  402.672042] usb 1-3: reset high speed USB device using ehci_hcd and address 6
Jan 15 15:23:36 obiwan kernel: [  418.228042] usb 1-3: device not accepting address 6, error -110
Jan 15 15:23:36 obiwan kernel: [  418.340046] usb 1-3: reset high speed USB device using ehci_hcd and address 6
Jan 15 15:23:52 obiwan kernel: [  433.896041] usb 1-3: device not accepting address 6, error -110
Jan 15 15:23:52 obiwan kernel: [  434.008047] usb 1-3: reset high speed USB device using ehci_hcd and address 6
Jan 15 15:24:02 obiwan kernel: [  444.440040] usb 1-3: device not accepting address 6, error -110
Jan 15 15:24:03 obiwan kernel: [  444.552049] usb 1-3: reset high speed USB device using ehci_hcd and address 6
Jan 15 15:24:13 obiwan kernel: [  454.984042] usb 1-3: device not accepting address 6, error -110
Jan 15 15:24:13 obiwan kernel: [  454.984106] usb 1-3: USB disconnect, address 6
Jan 15 15:24:13 obiwan kernel: [  454.985715] sd 4:0:0:0: Device offlined - not ready after error recovery
Jan 15 15:24:13 obiwan kernel: [  454.986819] sd 4:0:0:0: [sda] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK,SUGGEST_OK
Jan 15 15:24:13 obiwan kernel: [  454.986827] end_request: I/O error, dev sda, sector 33
Jan 15 15:24:13 obiwan kernel: [  454.986855] FAT: FAT read failed (blocknr 1)
Jan 15 15:24:13 obiwan kernel: [  454.987943] scsi 4:0:0:0: rejecting I/O to dead device
Jan 15 15:24:13 obiwan kernel: [  454.987952] scsi 4:0:0:0: rejecting I/O to dead device
Jan 15 15:24:13 obiwan kernel: [  454.987955] scsi 4:0:0:0: [sda] READ CAPACITY failed
Jan 15 15:24:13 obiwan kernel: [  454.987958] scsi 4:0:0:0: [sda] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK,SUGGEST_OK
Jan 15 15:24:13 obiwan kernel: [  454.987963] scsi 4:0:0:0: [sda] Sense not available.
Jan 15 15:24:13 obiwan kernel: [  454.987967] scsi 4:0:0:0: rejecting I/O to dead device
Jan 15 15:24:13 obiwan kernel: [  454.987972] scsi 4:0:0:0: [sda] Write Protect is off
Jan 15 15:24:13 obiwan kernel: [  454.987974] scsi 4:0:0:0: [sda] Mode Sense: 00 00 00 00
Jan 15 15:24:13 obiwan kernel: [  454.987977] scsi 4:0:0:0: [sda] Assuming drive cache: write through
Jan 15 15:24:13 obiwan kernel: [  455.116069] usb 1-3: new high speed USB device using ehci_hcd and address 7
Jan 15 15:24:29 obiwan kernel: [  470.672046] usb 1-3: device not accepting address 7, error -110
Jan 15 15:24:29 obiwan kernel: [  470.784048] usb 1-3: new high speed USB device using ehci_hcd and address 8
Jan 15 15:24:44 obiwan kernel: [  486.340041] usb 1-3: device not accepting address 8, error -110
Jan 15 15:24:44 obiwan kernel: [  486.452054] usb 1-3: new high speed USB device using ehci_hcd and address 9
Jan 15 15:24:55 obiwan kernel: [  496.884041] usb 1-3: device not accepting address 9, error -110
Jan 15 15:24:55 obiwan kernel: [  496.996046] usb 1-3: new high speed USB device using ehci_hcd and address 10
Jan 15 15:25:05 obiwan kernel: [  507.428039] usb 1-3: device not accepting address 10, error -110
Si cela inspire quelqu’un…
J’ai évacué l’idée d’un problème matériel quand j’ai vu que tout tournait impec avec un noyau 2.6.18.
EDIT : Quand j’en suis là, ce n’est plus la peine de chercher à brancher quoi que ce soit même une souris.
Bon y’a quand même de l’alim sur ces ports, j’arrive à allumer une LED.
essai réalisé sur un 2.6.28 : même problème
bon, j’ai fait plusieurs essais
en déchargeant des modules pour voir s’ils mettaient le bazar : rien
en tuant des services : rien
au passage j’ai remarqué que ma carte graphique était maintenant prise en charge par le driver libre ati, j’ai pas tout perdu
je vais refaire un essai en démarrant sans l’acpi et ensuite je serai sec
Bon j’ai rajouté acpi=off dans menu.lst et c’est bon pour le noyau 2.6.28
Maintenant je sais où ça coince, reste à creuser.
Je suis quand même ouvert à des suggestions :smiley:
