Uswsusp : bogue, grave ?
apt-get install uswsusp
[color=#0000FF]SACHANT QUE je suis sous Sid en 64 bits en ext3 et que les dépendances qui vont bien sont installées correctement.
VOTRE AVIS :question:
[/color]
la version Squeeze/Sid
[quote]critical bugs of uswsusp (-> 0.8-1.2+b1)
#550725 - uswsusp: Cases serious corruption on Ext4, with swap image file
grave bugs of uswsusp (-> 0.8-1.2+b1)
#521147 - uswsusp: Fail to suspend, keyboard freeze, screen black showing “Looking for splash image”
#498917 - uswsusp: hibernate de-formats swap partition
#528483 - uswsusp: s2disk hangs indefinitely :question: :question: :question:
serious bugs of uswsusp (-> 0.8-1.2+b1)
#503337 - On upgrades the default power off mode ends up as reboot
Summary:
uswsusp(5 bugs)
Are you sure you wan[/quote]
La version Lenny
[quote]Retrieving bug reports… Done
Parsing Found/Fixed information… Done
grave bugs of uswsusp (-> 0.7-1.2)
Summary:
uswsusp(1 bug)
Are you sure you want[/quote]
