Après une installation avec tous les dépendances, j’ai des erreurs sur l’utilisation de Mondo rescue:
lorsqu’il utilise mindi: ça ne marche pas voici le log de mondo (/var/log/mondoarchive.log):
Time started: Mon Aug 22 16:31:44 2011
running: dmesg -n1 > //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.tmp 2> //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.err
--------------------------------start of output-----------------------------
--------------------------------end of output------------------------------
…ran just fine.
Mondo Archive v2.2.9.7-r2840 — mondorescue.org
running i386 binaries
running on i686 architecture
NB: Mondo logs almost everything, so don’t panic if you see
some error messages. Please read them carefully before you
decide to break out in a cold sweat. Despite (or perhaps
because of) the wealth of messages. some users are inclined
to stop reading this log. If Mondo stopped for some reason,
chances are it’s detailed here. More than likely there’s a
message at the very end of this log that will tell you what
is wrong. Please read it! -Devteam
Zero…
[Main] mondoarchive.c->welcome_to_mondoarchive#101: One…
[Main] mondoarchive.c->welcome_to_mondoarchive#102: Two…
[Main] mondoarchive.c->welcome_to_mondoarchive#103: Three…
[Main] mondoarchive.c->welcome_to_mondoarchive#104: Four…
[Main] mondoarchive.c->distro_specific_kludges_at_start_of_mondoarchive#121: Unmounting old ramdisks if necessary
running: mount | grep cdrom | grep super > //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.tmp 2> //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.err
…ran with res=256
running: mount | grep floppy | grep super > //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.tmp 2> //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.err
…ran with res=256
[Main] libmondo-tools.c->mount_boot_if_necessary#1168: Started sub
[Main] libmondo-tools.c->mount_boot_if_necessary#1169: About to set g_boot_mountpt[0] to ‘\0’
[Main] libmondo-tools.c->mount_boot_if_necessary#1171: Done. Great. Seeting command to something
[Main] libmondo-tools.c->mount_boot_if_necessary#1174: Cool. Command = 'grep -v “:” /etc/fstab | grep -vE '^#.$’ | grep -E “[ ]/boot[ ]” | tr -s ’ ’ ’ ’ | cut -f1 | head -n1’
[Main] libmondo-tools.c->mount_boot_if_necessary#1178: tmp = ‘’
[Main] libmondo-tools.c->mount_boot_if_necessary#1224: Ended sub
[Main] libmondo-tools.c->get_kernel_version#254: g_kernel_version = 2.632000
running: rm -Rf /var/cache/mondo/changed.files > //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.tmp 2> //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.err
…ran just fine.
Checking sanity of your Linux distribution
running: grep ramdisk /proc/devices > //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.tmp 2> //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.err
1 ramdisk
…ran just fine.
running: mount | grep -Ew ‘vfat|fat|dos’ | grep -vE “/dev/fd|nexdisk” > //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.tmp 2> //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.err
…ran with res=256
[Main] libmondo-files.c->find_home_of_exe#360: find_home_of_exe () — Found cmp at /usr/bin/cmp
running: mindi -V > //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.tmp 2> //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.err
Mindi v2.0.7.8-r2840
…ran just fine.
running: parted2fdisk -l | grep -i raid > //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.tmp 2> //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.err
…ran with res=256
Done.
User has chosen not to backup the PC
running: umount /mnt/cdrom > //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.tmp 2> //mondo.tmp.WNJ2MJ/mondo-run-prog-thing.err
umount: /mnt/cdrom: not mounted
…ran with res=256
[Main] newt-specific.c->finish#422: Calling newtSuspend()
