Utiliser plutot le connecteur vidéo du panneau arrière
Bonjour à toutes et à tous,
Je voudrais me servir du connecteur vidéo du panneau arrière de mon PC plutôt que la carte graphique qui est utilisée.
Comment faire pour la remplacer ? Es ce possible ?
Je mets en ligne le retour de la commande :
lspci -v
[size=85][code]00:00.0 Host bridge: Advanced Micro Devices [AMD] nee ATI Radeon Xpress 200 Host Bridge (rev 01)
Subsystem: Dell Device 01e5
Flags: bus master, 66MHz, medium devsel, latency 64
00:02.0 PCI bridge: Advanced Micro Devices [AMD] nee ATI RS480 PCI-X Root Port (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: dfd00000-dfefffff
Prefetchable memory behind bridge: 00000000c0000000-00000000cfffffff
Capabilities: [50] Power Management version 3
Capabilities: [58] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [b0] Subsystem: Dell Device 01e5
Capabilities: [b8] HyperTransport: MSI Mapping Enable+ Fixed+
Kernel driver in use: pcieport
00:12.0 SATA controller: Advanced Micro Devices [AMD] nee ATI SB600 Non-Raid-5 SATA (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 22
I/O ports at fe00 [size=8]
I/O ports at fe10 [size=4]
I/O ports at fe20 [size=8]
I/O ports at fe30 [size=4]
I/O ports at fec0 [size=16]
Memory at dfff6c00 (32-bit, non-prefetchable) [size=1K]
Capabilities: [60] Power Management version 2
Capabilities: [50] MSI: Enable- Count=1/4 Maskable- 64bit+
Capabilities: [70] SATA HBA v1.0
Kernel driver in use: ahci
00:13.0 USB controller: Advanced Micro Devices [AMD] nee ATI SB600 USB (OHCI0) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 16
Memory at dfff7000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci_hcd
00:13.1 USB controller: Advanced Micro Devices [AMD] nee ATI SB600 USB (OHCI1) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 17
Memory at dfff8000 (32-bit, non-prefetchable) [size=4K]
00:13.2 USB controller: Advanced Micro Devices [AMD] nee ATI SB600 USB (OHCI2) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 18
Memory at dfff9000 (32-bit, non-prefetchable) [size=4K]
00:13.3 USB controller: Advanced Micro Devices [AMD] nee ATI SB600 USB (OHCI3) (prog-if 10 [OHCI])
Memory at dfffa000 (32-bit, non-prefetchable) [size=4K]
00:13.4 USB controller: Advanced Micro Devices [AMD] nee ATI SB600 USB (OHCI4) (prog-if 10 [OHCI])
Memory at dfffb000 (32-bit, non-prefetchable) [size=4K]
00:13.5 USB controller: Advanced Micro Devices [AMD] nee ATI SB600 USB Controller (EHCI) (prog-if 20 [EHCI])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 19
Memory at dfff6900 (32-bit, non-prefetchable) [size=256]
Capabilities: [c0] Power Management version 2
Capabilities: [e4] Debug port: BAR=1 offset=00e0
Kernel driver in use: ehci_hcd
00:14.0 SMBus: Advanced Micro Devices [AMD] nee ATI SBx00 SMBus Controller (rev 13)
Flags: 66MHz, medium devsel
I/O ports at 0b00 [size=16]
Memory at fed00000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: piix4_smbus
00:14.1 IDE interface: Advanced Micro Devices [AMD] nee ATI SB600 IDE (prog-if 8a [Master SecP PriP])
I/O ports at 01f0 [size=8]
I/O ports at 03f4 [size=1]
I/O ports at 0170 [size=8]
I/O ports at 0374 [size=1]
I/O ports at ffa0 [size=16]
Capabilities: [70] MSI: Enable- Count=1/1 Maskable- 64bit-
Kernel driver in use: pata_atiixp
00:14.2 Audio device: Advanced Micro Devices [AMD] nee ATI SBx00 Azalia (Intel HDA)
Flags: bus master, slow devsel, latency 64, IRQ 16
Memory at dfffc000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Capabilities: [60] MSI: Enable- Count=1/1 Maskable- 64bit+
Kernel driver in use: snd_hda_intel
00:14.3 ISA bridge: Advanced Micro Devices [AMD] nee ATI SB600 PCI to LPC Bridge
Flags: bus master, 66MHz, medium devsel, latency 0
00:14.4 PCI bridge: Advanced Micro Devices [AMD] nee ATI SBx00 PCI to PCI Bridge (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=64
Memory behind bridge: dfc00000-dfcfffff
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Cedar PRO [Radeon HD 5450/6350] (prog-if 00 [VGA controller])
Subsystem: Advanced Micro Devices [AMD] nee ATI Device 010e
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at dfde0000 (64-bit, non-prefetchable) [size=128K]
I/O ports at ec00 [size=256]
Expansion ROM at dfe00000 [disabled] [size=128K]
Capabilities: [58] Express Legacy Endpoint, MSI 00
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [150] Advanced Error Reporting
Kernel driver in use: radeon
01:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI Cedar HDMI Audio [Radeon HD 5400/6300 Series]
Subsystem: Advanced Micro Devices [AMD] nee ATI Cedar HDMI Audio [Radeon HD 5400/6300 Series]
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at dfddc000 (64-bit, non-prefetchable) [size=16K]
02:09.0 Ethernet controller: Broadcom Corporation BCM4401-B0 100Base-TX (rev 02)
Flags: bus master, fast devsel, latency 64, IRQ 21
Memory at dfcfe000 (32-bit, non-prefetchable) [size=8K]
Capabilities: [40] Power Management version 2
Kernel driver in use: b44
[/code][/size]
Merci pour vos conseils par avance.
