Vérifier ma configuration samba
Bonjour, je ne parviens toujours pas à faire accéder la secrétaire sous windows à mes documents.
[global]
netbios name = NICOLASDEBIAN
server string = Samba file and print server
workgroup = WORKGROUP
security = user
hosts allow = 127. 192.168.0.
interfaces = 127.0.0.1/8 192.168.70.33/24 enp1s0
bind interfaces only = yes
remote announce = 192.168.0.255
remote browse sync = 192.168.0.255
printcap name = cups
load printers = yes
cups options = raw
printing = cups
guest account = smbguest
log file = /var/log/samba/samba.log
max log size = 1000
null passwords = no
username level = 6
password level = 6
encrypt passwords = yes
unix password sync = yes
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
local master = no
domain master = no
preferred master = no
domain logons = no
os level = 33
logon drive = m:
logon home = /home/nicolas/Public
logon path = \\%L\profiles\%u
logon script = %G.bat
time server = no
name resolve order = wins lmhosts bcast
wins support = no
wins proxy = no
dns proxy = no
preserve case = yes
short preserve case = yes
client use spnego = no
client signing = no
client schannel = no
server signing = no
server schannel = no
nt pipe support = yes
nt status support = yes
allow trusted domains = no
obey pam restrictions = yes
enable spoolss = yes
client plaintext auth = no
disable netbios = no
follow symlinks = no
update encrypted = yes
pam password change = no
passwd chat timeout = 120
hostname lookups = no
username map = /etc/samba/smbusers
passdb backend = tdbsam
passwd program = /usr/bin/passwd '%u'
passwd chat = *New*password* %n\n *ReType*new*password* %n\n *passwd*changed*\n
add user script = /usr/sbin/useradd -d /dev/null -c 'Samba User Account' -s /dev/null '%u'
add user to group script = /usr/sbin/useradd -d /dev/null -c 'Samba User Account' -s /dev/null -g '%g' '%u'
add group script = /usr/sbin/groupadd '%g'
delete user script = /usr/sbin/userdel '%u'
delete user from group script = /usr/sbin/userdel '%u' '%g'
delete group script = /usr/sbin/groupdel '%g'
add machine script = /usr/sbin/useradd -d /dev/null -g sambamachines -c 'Samba Machine Account' -s /dev/null -M '%u'
machine password timeout = 120
idmap uid = 16777216-33554431
idmap gid = 16777216-33554431
template shell = /dev/null
winbind use default domain = yes
winbind separator = @
winbind cache time = 360
winbind trusted domains only = yes
winbind nested groups = no
winbind nss info = no
winbind refresh tickets = no
winbind offline logon = no
[homes]
comment = Home Directories
path = /home/nicolas/Public
read only = yes
available = yes
browseable = yes
writable = yes
guest ok = yes
public = yes
printable = yes
locking = no
strict locking = no
[netlogon]
comment = Network Logon Service
read only = no
available = yes
browseable = yes
writable = no
guest ok = yes
public = yes
printable = yes
locking = no
strict locking = no
[profiles]
comment = User Profiles
path = /var/samba/profiles
read only = no
available = yes
browseable = yes
writable = yes
guest ok = no
public = no
printable = no
create mode = 0600
directory mask = 0700
locking = no
strict locking = no
[nico-doc]
comment = pas de commentaires
available = yes
browseable = yes
writeable = yes
guest ok = yes
locking = no
strict locking = no
[sharing]
browseable = yes
writeable = yes
valid users = nicolas
write list = nicolas
create mask = 0700
directory mask = 700
Sur son ordi il est dit que je ne donne pas l’accés ( ???))
Merci de vos éclairages
Nico
Ça fait un petit moment que je n’ai pas joué avec samba, mais ton fichier me parait vachement compliqué… Voilà ce que j’utilise chez moi :
[global]
dns proxy = no
log file = /var/log/samba/log.%m
max log size = 1000
syslog = 0
panic action = /usr/share/samba/panic-action %d
server role = standalone server
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
pam password change = yes
map to guest = bad user
usershare allow guests = yes
[homes]
browseable = no
read only = yes
create mask = 0700
valid users = %S
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
guest ok = no
read only = yes
create mask = 0700
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
browseable = yes
read only = yes
guest ok = no
[windows]
path = "/mnt/windows"
read only = yes
guest ok = yes
public = yes
En gros le fichier de base livré par Debian avec simplement un partage en plus. Là j’ai supprimé les commentaires pour que ce soit moins pénible à lire.
Mon partage est en lecture seule, mais est-ce que déjà ça, fonctionne ?
IL fait quoi ce sujet dans le forum “Trucs & Astuces” !?
Merci de vous conformer à la[FAQ)(/faq) en veillant à poster dans le forum adéquat !
Ce post est une demande d’assistance ; direction dans le forum “Support” :frowning:
Obligé de le déplacer !
Bonjour, veux tu que j’essaie ton script chez moi en corrigeant les chemins ?
Désolé et merci
C’est vrai que j’ai pas été très complet dans ma réponse, mais en effet, ça peut faire un point de départ.
