Installe vim-tiny.
packages.debian.org/wheezy/vim-tiny
Exemple /etc/vim/vimrc.tiny
[code]" Vim configuration file, in effect when invoked as “vi”. The aim of this
" configuration file is to provide a Vim environment as compatible with the
" original vi as possible. Note that ~/.vimrc configuration files as other
" configuration files in the runtimepath are still sourced.
" When Vim is invoked differently (“vim”, “view”, “evim”, …) this file is
" not sourced; /etc/vim/vimrc and/or /etc/vim/gvimrc are.
" Debian system-wide default configuration Vim
set runtimepath=~/.vim,/var/lib/vim/addons,/usr/share/vim/vimfiles,/usr/share/vim/vim74,/usr/share/vim/vimfiles/after,/var/lib/vim/addons/after,~/.vim/after
set compatible
" vim: set ft=vim:[/code]
Vim configuration file, in effect when invoked as “vi” : configuration de vim (vi improved) quand il est appellé en tant que vi.
set compatible : compatible avec vi.
