Ave
Si je lie un dvd avec vlc voila ce que ça me donne
[code]zoox@_____:~$ vlc dvd://
VLC media player 1.1.3 The Luggage (revision exported)
Blocked: call to unsetenv(“DBUS_ACTIVATION_ADDRESS”)
Blocked: call to unsetenv(“DBUS_ACTIVATION_BUS_TYPE”)
Warning: call to signal(13, 0x1)
Blocked: call to setlocale(6, “”)
Blocked: call to sigaction(17, 0xb719a0d4, 0xb719a048)
Warning: call to srand(1298531497)
Warning: call to rand()
(process:4089): Gtk-WARNING **: Locale not supported by C library.
Using the fallback ‘C’ locale.
libdvdnav: Using dvdnav version 4.1.3
libdvdread: Encrypted DVD support unavailable.
** No css library available. See **
** /usr/share/doc/libdvdread4/README.Debian **
** for more information. **
libdvdnav: DVD Title: 50_ANS_DE_CONQUETES_SPATIALES
libdvdnav: DVD Serial Number: 37348efa
libdvdnav: DVD Title (Alternative):
libdvdnav: Unable to find map file ‘/home/zoox/.dvdnav/50_ANS_DE_CONQUETES_SPATIALES.map’
*** Zero check failed in /home/user/libdvdread/src/ifo_read.c:517
for vmgi_mat->zero_3 = 0x00000000010000000000000000000000000000
libdvdnav: DVD disk reports itself with Region mask 0x00000000. Regions: 1 2 3 4 5 6 7 8
Warning: call to srand(421344)
libdvdnav: Language ‘en’ not found, using ‘fr’ instead
libdvdnav: Menu Languages available: fr
*** libdvdread: CHECK_VALUE failed in /home/user/libdvdread/src/nav_read.c:263 ***
*** for dsi->dsi_gi.zero1 == 0 ***
swScaler: pal8 is not supported as output pixel format
[0x8a1f954] swscale scale error: could not init SwScaler and/or allocate memory
[swscaler @ 0x8ac3ff0] bad dst image pointers
Vlc c’est ouvert avec du sons mais pas d’image.
De plus j’ai accès à toutes les option vidéo et le contraste, etc sont bien réglé.
