Vlc n'arrive pas à lire AMD/ATI RC410M Radeon (résolu)
Je suspecte que ma nouvelle debian8 mate a du mal avec ma carte graphique…Comment puis je me dépanner sachant que ni totem ni vlc ne peut lire une video…En gros j’ai un changement d’image par seconde voire plus…
merci
root@jojo-Satellite-L30:/home/jojo# uname -a Linux jojo-Satellite-L30 3.16.0-4-686-pae #1 SMP Debian 3.16.7-ckt9-3~deb8u1 (2015-04-24) i686 GNU/Linux
root@jojo-Satellite-L30:/home/jojo# lspci 00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD/ATI] RC410 Host Bridge (rev 01) 00:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RC4xx/RS4xx PCI Bridge [int gfx] 00:12.0 IDE interface: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 Serial ATA Controller (rev 80) 00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 USB Host Controller (rev 80) 00:13.1 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 USB Host Controller (rev 80) 00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 USB2 Host Controller (rev 80) 00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 SMBus Controller (rev 82) 00:14.1 IDE interface: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 IDE Controller (rev 80) 00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 High Definition Audio Controller (rev 01) 00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 PCI-ISA Bridge (rev 80) 00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 PCI-PCI Bridge (rev 80) 01:05.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RC410M [Mobility Radeon Xpress 200M] 09:01.0 CardBus bridge: ENE Technology Inc CB1410 Cardbus Controller (rev 01) 09:02.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter (rev 10) 09:04.0 Ethernet controller: Qualcomm Atheros AR2413/AR2414 Wireless Network Adapter [AR5005G(S) 802.11bg] (rev 01)
[code]root@jojo-Satellite-L30:/home/jojo# dmidecode
dmidecode 2.12
SMBIOS 2.4 present.
37 structures occupying 1301 bytes.
Table at 0x000DF810.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: TOSHIBA
Version: V2.30
Release Date: 12/25/2006
Address: 0xE60A0
Runtime Size: 106336 bytes
ROM Size: 14848 kB
Characteristics:
ISA is supported
PCI is supported
PC Card (PCMCIA) is supported
PNP is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
ACPI is supported
USB legacy is supported
Smart battery is supported
BIOS boot specification is supported
Targeted content distribution is supported
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: TOSHIBA
Product Name: Satellite L30
Version: PSL33E-02S02HFR
Serial Number: 17077299W
UUID: A092FF29-120C-D911-BA5A-001636D1F77D
Wake-up Type: Power Switch
SKU Number: Not Specified
Family: Not Specified
Handle 0x0002, DMI type 2, 8 bytes
Base Board Information
Version: Not Applicable
Serial Number: 1234567890
Handle 0x0003, DMI type 3, 17 bytes
Chassis Information
Type: Notebook
Lock: Not Present
Version: N/A
Serial Number: None
Asset Tag:
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x424C3320
Handle 0x0004, DMI type 4, 35 bytes
Processor Information
Socket Designation: U23
Type: Central Processor
Family: Other
Manufacturer: Intel
ID: EC 06 00 00 FF FB E9 BF
Version: Intel® CPU T2060 @ 1
Voltage: 2.2 V
External Clock: 100 MHz
Max Speed: 1600 MHz
Current Speed: 1600 MHz
Status: Populated, Enabled
Upgrade: ZIF Socket
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: Not Provided
Serial Number: Not Specified
Asset Tag: Not Specified
Part Number: Not Specified
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
Socket Designation: CACHE1
Configuration: Enabled, Socketed, Level 1
Operational Mode: Write Back
Installed Size: 16 kB
Maximum Size: 16 kB
Supported SRAM Types:
Burst
Pipeline Burst
Asynchronous
Installed SRAM Type: Asynchronous
Speed: Unknown
Error Correction Type: Unknown
System Type: Unknown
Associativity: Unknown
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Socket Designation: CACHE2
Configuration: Enabled, Socketed, Level 2
Installed Size: 1024 kB
Maximum Size: 512 kB
Burst
Pipeline Burst
Asynchronous
Installed SRAM Type: Burst
Speed: Unknown
Handle 0x0007, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2 Cache
Maximum Size: 1024 kB
Burst
Pipeline Burst
Speed: Unknown
Handle 0x0008, DMI type 9, 13 bytes
System Slot Information
Designation: PCI Slot J1100
Type: 32-bit PCI
Current Usage: Unknown
Length: Long
Characteristics:
5.0 V is provided
3.3 V is provided
PME signal is supported
Handle 0x0009, DMI type 10, 8 bytes
On Board Device 1 Information
Type: Video
Status: Disabled
Description: ATI RS400M
On Board Device 2 Information
Type: Sound
Status: Disabled
Description: ADI
Handle 0x000A, DMI type 11, 5 bytes
OEM Strings
String 1: SSL3302S02HFR,H07028FR
Handle 0x000B, DMI type 12, 5 bytes
System Configuration Options
Option 1: Jumper settings can be described here.
Handle 0x000C, DMI type 15, 29 bytes
System Event Log
Area Length: 16 bytes
Header Start Offset: 0x0000
Header Length: 16 bytes
Data Start Offset: 0x0010
Access Method: General-purpose non-volatile data functions
Access Address: 0x0000
Status: Valid, Not Full
Change Token: 0x00000001
Header Format: Type 1
Supported Log Type Descriptors: 3
Descriptor 1: POST error
Data Format 1: POST results bitmap
Descriptor 2: Single-bit ECC memory error
Data Format 2: Multiple-event
Descriptor 3: Multi-bit ECC memory error
Data Format 3: Multiple-event
Handle 0x000D, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 1 GB
Error Information Handle: Not Provided
Number Of Devices: 2
Handle 0x000E, DMI type 17, 27 bytes
Memory Device
Array Handle: 0x000D
Error Information Handle: No Error
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: DIMM
Set: 1
Locator: J400
Bank Locator: Channel A0
Type: DRAM
Type Detail: Synchronous
Speed: Unknown
Manufacturer: Not Specified
Handle 0x000F, DMI type 17, 27 bytes
Memory Device
Data Width: Unknown
Form Factor: DIMM
Set: 2
Locator: J401
Bank Locator: Channel A1
Type: DRAM
Speed: Unknown
Handle 0x0010, DMI type 17, 27 bytes
Memory Device
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: 3
Locator: J501
Bank Locator: Channel B0
Type: DRAM
Speed: Unknown
Handle 0x0011, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 4
Locator: J500
Bank Locator: Channel B1
Type: DRAM
Speed: Unknown
Handle 0x0012, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x0003FFFFFFF
Range Size: 1 GB
Physical Array Handle: 0x000D
Partition Width: 2
Handle 0x0013, DMI type 20, 19 bytes
Memory Device Mapped Address
Ending Address: 0x000000003FF
Range Size: 1 kB
Physical Device Handle: 0x000E
Memory Array Mapped Address Handle: 0x0012
Partition Row Position: Unknown
Interleave Position: Unknown
Interleaved Data Depth: Unknown
Handle 0x0014, DMI type 20, 19 bytes
Range Size: 1 kB
Physical Device Handle: 0x000F
Handle 0x0015, DMI type 23, 13 bytes
System Reset
Status: Enabled
Watchdog Timer: Present
Boot Option: Do Not Reboot
Boot Option On Limit: Do Not Reboot
Reset Count: Unknown
Reset Limit: Unknown
Timer Interval: Unknown
Timeout: Unknown
Handle 0x0016, DMI type 24, 5 bytes
Hardware Security
Power-On Password Status: Disabled
Keyboard Password Status: Unknown
Administrator Password Status: Enabled
Front Panel Reset Status: Unknown
Handle 0x0017, DMI type 25, 9 bytes
System Power Controls
Next Scheduled Power-on: 12-31 23:59:59
Handle 0x0018, DMI type 26, 22 bytes
Voltage Probe
Description: Voltage Probe 1
Status: OK
Maximum Value: Unknown
Minimum Value: Unknown
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
OEM-specific Information: 0x00000000
Nominal Value: 8.192 V
Handle 0x0019, DMI type 26, 20 bytes
Voltage Probe
Description: Voltage Probe 2
Status: OK
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Handle 0x001A, DMI type 27, 14 bytes
Cooling Device
Temperature Probe Handle: 0x001C
Type: Fan
Status: OK
Cooling Unit Group: 255
Nominal Speed: Unknown Or Non-rotating
Handle 0x001B, DMI type 27, 12 bytes
Cooling Device
Type: Fan
Status: OK
Handle 0x001C, DMI type 28, 22 bytes
Temperature Probe
Description: Temperature Probe 1
Status: OK
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Nominal Value: Unknown
Handle 0x001D, DMI type 28, 20 bytes
Temperature Probe
Description: Temperature Probe 2
Status: OK
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Handle 0x001E, DMI type 29, 22 bytes
Electrical Current Probe
Description: Electrical Current Probe 1
Status: OK
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Handle 0x001F, DMI type 29, 20 bytes
Description: Electrical Current Probe 2
Status: OK
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Handle 0x0020, DMI type 30, 6 bytes
Out-of-band Remote Access
Manufacturer Name: Intel
Inbound Connection: Enabled
Outbound Connection: Disabled
Handle 0x0021, DMI type 32, 20 bytes
System Boot Information
Status:
Handle 0x0022, DMI type 33, 31 bytes
64-bit Memory Error Information
Type: OK
Granularity: Unknown
Operation: Unknown
Vendor Syndrome: Unknown
Memory Array Address: 0x0000000080000000
Device Address: 0x0000000080000000
Resolution: Unknown
Handle 0x0023, DMI type 126, 4 bytes
Inactive
Handle 0x0024, DMI type 127, 4 bytes
End Of Table
Avant d’envoyer l’annuaire as tu vérifié que ton accélération 3D est fonctionnelle via glx-info?
Ta version de vlc c’est celle des dépôts officiels?
ok je crois avoir trouvé… au driver…xserver-xorg-video-radeon mis d’office lors de l’installation il faut rajouter les microcodes firmware-linux-nonfree…
vlc à l’air de tourner… je vérifie et marque résolu en tête. merci.
