bonsoir,
ca fait 3h que j’essais d’installer vmware player sur wheezy sans resultat.
J’ai le module vmnet qui me pose problème :
/usr/bin/make -j -C /tmp/vmware-root/modules/vmnet-only auto-build SUPPORT_SMP=1 HEADER_DIR=/lib/modules/3.2.0-1-amd64/build/include CC=/usr/bin/gcc GREP=/usr/bin/make IS_GCC_3=no VMCCVER=4.6
Using 2.6.x kernel build system.
make: entrant dans le répertoire « /tmp/vmware-root/modules/vmnet-only »
make -C /lib/modules/3.2.0-1-amd64/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. \
MODULEBUILDDIR= modules
make[1]: entrant dans le répertoire « /usr/src/linux-headers-3.2.0-1-amd64 »
CC [M] /tmp/vmware-root/modules/vmnet-only/userif.o
CC [M] /tmp/vmware-root/modules/vmnet-only/netif.o
CC [M] /tmp/vmware-root/modules/vmnet-only/filter.o
/tmp/vmware-root/modules/vmnet-only/filter.c:60:16: error: ‘THIS_MODULE’ undeclared here (not in a function)
make[4]: *** [/tmp/vmware-root/modules/vmnet-only/filter.o] Erreur 1
make[4]: *** Attente des tâches non terminées....
/tmp/vmware-root/modules/vmnet-only/netif.c: In function ‘VNetNetIfSetup’:
/tmp/vmware-root/modules/vmnet-only/netif.c:134:7: error: unknown field ‘ndo_set_multicast_list’ specified in initializer
/tmp/vmware-root/modules/vmnet-only/netif.c:134:7: warning: initialization from incompatible pointer type [enabled by default]
/tmp/vmware-root/modules/vmnet-only/netif.c:134:7: warning: (near initialization for ‘vnetNetifOps.ndo_validate_addr’) [enabled by default]
/tmp/vmware-root/modules/vmnet-only/userif.c: In function ‘VNetCsumCopyDatagram’:
/tmp/vmware-root/modules/vmnet-only/userif.c:520:3: error: incompatible type for argument 1 of ‘kmap’
/usr/src/linux-headers-3.2.0-1-common/include/linux/highmem.h:48:21: note: expected ‘struct page *’ but argument is of type ‘const struct <anonymous>’
/tmp/vmware-root/modules/vmnet-only/userif.c:523:3: error: incompatible type for argument 1 of ‘kunmap’
/usr/src/linux-headers-3.2.0-1-common/include/linux/highmem.h:54:20: note: expected ‘struct page *’ but argument is of type ‘const struct <anonymous>’
make[4]: *** [/tmp/vmware-root/modules/vmnet-only/netif.o] Erreur 1
make[4]: *** [/tmp/vmware-root/modules/vmnet-only/userif.o] Erreur 1
make[3]: *** [_module_/tmp/vmware-root/modules/vmnet-only] Erreur 2
make[2]: *** [sub-make] Erreur 2
make[1]: *** [all] Erreur 2
make[1]: quittant le répertoire « /usr/src/linux-headers-3.2.0-1-amd64 »
make: *** [vmnet.ko] Erreur 2
make: quittant le répertoire « /tmp/vmware-root/modules/vmnet-only »
après 2h de google intensif, je me tourne vers vous.
