Wacom Bamboo Fun et Gimp
Je viens de me faire plaisir en m’offrant une tablette graphique Wacom Bamboo Fun.
Je suis sous Debian Lenny. J’ai installé les drivers sous synaptic: wacom-tools & xserver-xorg-input-wacom version 0.8.1.6-1
J’ai fait des modifs dans /etc/X11/xorg.conf:
/etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice “Configured Mouse”
Option “AIGLX” “true”
    InputDevice    "stylus"    "SendCoreEvents"
    InputDevice    "eraser"    "SendCoreEvents"
    InputDevice    "pad"
EndSection
Section “Files”
# path to defoma fonts
FontPath     "/usr/share/fonts/X11/misc"
FontPath     "/usr/X11R6/lib/X11/fonts/misc"
FontPath     "/usr/share/fonts/X11/cyrillic"
FontPath     "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath     "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath     "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath     "/usr/share/fonts/X11/Type1"
FontPath     "/usr/X11R6/lib/X11/fonts/Type1"
FontPath     "/usr/share/fonts/X11/100dpi"
FontPath     "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath     "/usr/share/fonts/X11/75dpi"
FontPath     "/usr/X11R6/lib/X11/fonts/75dpi"
FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
Load "GLcore"
Load “wacom”
Charge “extmod” mais sans DGA extension
SubSection "extmod"
	Option	    "omit xfree86-dga"
EndSubSection
EndSection
#input wacom
Section "InputDevice"
Driver "wacom"
Identifier "stylus"
Option “Device” “/dev/input/wacom” # USB ONLY
Option “Type” "stylus"
Option “USB” “on” # USB ONLY
EndSection
Driver "wacom"
Identifier "eraser"
Option “Type” "eraser"
EndSection
Driver "wacom"
Identifier "pad"
Option “Type” "pad"
EndSection
fin imput wacom
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Monitor"
Identifier "Écran générique"
HorizSync 28.0 - 64.0
VertRefresh 43.0 - 60.0
Option "DPMS"
EndSection
Section "Device"
Identifier "ATI"
Driver "fglrx"
Option “VideoOverlay” "on"
Option “OpenGLOverlay” "off"
BusID "PCI:5:0:0"
Option “UseFastTLS” "2"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI"
Monitor "Écran générique"
Option “backingstore” "true"
Defaultdepth 24
SubSection "Display"
	Depth     1
	Modes    "1280x1024" "1280x960" "1280x854" "1280x800" "1280x768" "1200x800" "1152x864" "1024x768" "800x600" "640x480"
EndSubSection
	Depth     4
EndSubSection
	Depth     8
EndSubSection
	Depth     15
EndSubSection
	Depth     16
EndSubSection
	Depth     24
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
Section “Extensions”
Option “Composite” “Enable”
Option “RENDER” "Enable"
EndSection
Avec tout ça, ça à l’air de fonctionner mais je n’arrive à avoir la gestion de la pression sous gimp.
Qu’ai-je oublié?
Merci de votre attention.
Ok tout fonctionne dans GIMP.
La tablette était correctement installée. Par contre, GIMP était mal configuré.
hello mimosa,
je viens de m’acheter une bamboo fun A6
tu en ais ou dans ta config, perso sur gimp j’ai un souci de configuration :
configurer le contrôle d’entrée > entree linux > etat : Périphérique non supporté: permission non accordée.
y aurait-il un group a ajouter à l’utilisateur, pas évident.
Ta bamboo fonctionne correctement ?
