Oui, mais je croix bien que le syslogd n’était pas encore lancé. En tout cas, j’ai regardé mais je n’ai rien trouvé
Je le poste ici au cas ou :
goog:/var/log# dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.26-2-amd64 (Debian 2.6.26-15) (dannf@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-25)) #1 SMP Fri Mar 27 04:02:59 UTC 2009
[ 0.000000] Command line: root=/dev/sda7 ro quiet
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000bff90000 (usable)
[ 0.000000] BIOS-e820: 00000000bff90000 - 00000000bff9e000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000bff9e000 - 00000000bffe0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bffe0000 - 00000000c0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 0000000180000000 (usable)
[ 0.000000] Entering add_active_range(0, 0, 159) 0 entries of 3200 used
[ 0.000000] Entering add_active_range(0, 256, 786320) 1 entries of 3200 used
[ 0.000000] Entering add_active_range(0, 1048576, 1572864) 2 entries of 3200 used
[ 0.000000] max_pfn_mapped = 1572864
[ 0.000000] init_memory_mapping
[ 0.000000] DMI 2.4 present.
[ 0.000000] ACPI: RSDP 000FAE70, 0014 (r0 ACPIAM)
[ 0.000000] ACPI: RSDT BFF90000, 0038 (r1 MSTEST TESTONLY 7000815 MSFT 97)
[ 0.000000] ACPI: FACP BFF90200, 0084 (r2 MSTEST OEMFACP 7000815 MSFT 97)
[ 0.000000] ACPI: DSDT BFF905C0, 918E (r1 A0483 A0483035 35 INTL 20060113)
[ 0.000000] ACPI: FACS BFF9E000, 0040
[ 0.000000] ACPI: APIC BFF90390, 006C (r1 MSTEST OEMAPIC 7000815 MSFT 97)
[ 0.000000] ACPI: MCFG BFF90400, 003C (r1 MSTEST OEMMCFG 7000815 MSFT 97)
[ 0.000000] ACPI: OEMB BFF9E040, 007B (r1 MSTEST AMI_OEM 7000815 MSFT 97)
[ 0.000000] ACPI: HPET BFF99750, 0038 (r1 MSTEST OEMHPET 7000815 MSFT 97)
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at 0000000000000000-0000000180000000
[ 0.000000] Bootmem setup node 0 0000000000000000-0000000180000000
[ 0.000000] NODE_DATA [000000000000f000 - 0000000000013fff]
[ 0.000000] bootmap [0000000000014000 - 0000000000043fff] pages 30
[ 0.000000] early res: 0 [0-fff] BIOS data page
[ 0.000000] early res: 1 [6000-7fff] TRAMPOLINE
[ 0.000000] early res: 2 [200000-673397] TEXT DATA BSS
[ 0.000000] early res: 3 [37998000-37fefe25] RAMDISK
[ 0.000000] early res: 4 [9fc00-fffff] BIOS reserved
[ 0.000000] early res: 5 [8000-efff] PGTABLE
[ 0.000000] [ffffe20000000000-ffffe20003bfffff] PMD -> [ffff810001200000-ffff810003ffffff] on node 0
[ 0.000000] [ffffe20003c00000-ffffe200053fffff] PMD -> [ffff81000c000000-ffff81000d7fffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] DMA32 4096 -> 1048576
[ 0.000000] Normal 1048576 -> 1572864
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0 -> 159
[ 0.000000] 0: 256 -> 786320
[ 0.000000] 0: 1048576 -> 1572864
[ 0.000000] On node 0 totalpages: 1310511
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 1247 pages reserved
[ 0.000000] DMA zone: 2696 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 14280 pages used for memmap
[ 0.000000] DMA32 zone: 767944 pages, LIFO batch:31
[ 0.000000] Normal zone: 7168 pages used for memmap
[ 0.000000] Normal zone: 517120 pages, LIFO batch:31
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 0, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Setting APIC routing to flat
[ 0.000000] ACPI: HPET id: 0x8086a202 base: 0xfed00000
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
[ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 00000000bff90000 - 00000000bff9e000
[ 0.000000] PM: Registered nosave memory: 00000000bff9e000 - 00000000bffe0000
[ 0.000000] PM: Registered nosave memory: 00000000bffe0000 - 00000000c0000000
[ 0.000000] PM: Registered nosave memory: 00000000c0000000 - 00000000fee00000
[ 0.000000] PM: Registered nosave memory: 00000000fee00000 - 00000000fee01000
[ 0.000000] PM: Registered nosave memory: 00000000fee01000 - 00000000ffb00000
[ 0.000000] PM: Registered nosave memory: 00000000ffb00000 - 0000000100000000
[ 0.000000] Allocating PCI resources starting at c4000000 (gap: c0000000:3ee00000)
[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] PERCPU: Allocating 37168 bytes of per cpu data
[ 0.000000] NR_CPUS: 32, nr_cpu_ids: 4
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 1287760
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=/dev/sda7 ro quiet
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 4096 (order: 12, 32768 bytes)
[ 0.000000] TSC calibrated against PM_TIMER
[ 0.000000] time.c: Detected 2399.995 MHz processor.
[ 0.004000] Console: colour VGA+ 80x25
[ 0.004000] console [tty0] enabled
[ 0.004000] Checking aperture...
[ 0.004000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.004000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.004000] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.004000] Placing software IO TLB between 0x4000000 - 0x8000000
[ 0.004000] Memory: 5092884k/6291456k available (2224k kernel code, 149160k reserved, 1081k data, 392k init)
[ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated
[ 0.004000] hpet clockevent registered
[ 0.083871] Calibrating delay using timer specific routine.. 4803.56 BogoMIPS (lpj=9607124)
[ 0.083907] Security Framework initialized
[ 0.083911] SELinux: Disabled at boot.
[ 0.083914] Capability LSM initialized
[ 0.084005] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.088005] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.088005] Mount-cache hash table entries: 256
[ 0.088005] Initializing cgroup subsys ns
[ 0.088005] Initializing cgroup subsys cpuacct
[ 0.088005] Initializing cgroup subsys devices
[ 0.088005] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.088005] CPU: L2 cache: 4096K
[ 0.088005] CPU 0/0 -> Node 0
[ 0.088005] CPU: Physical Processor ID: 0
[ 0.088005] CPU: Processor Core ID: 0
[ 0.088005] CPU0: Thermal monitoring enabled (TM2)
[ 0.088005] using mwait in idle threads.
[ 0.088842] ACPI: Core revision 20080321
[ 0.144009] CPU0: Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz stepping 06
[ 0.144009] Using local APIC timer interrupts.
[ 0.148009] APIC timer calibration result 16666634
[ 0.148009] Detected 16.666 MHz APIC timer.
[ 0.148009] Booting processor 1/1 ip 6000
[ 0.156009] Initializing CPU#1
[ 0.156009] Calibrating delay using timer specific routine.. 4800.02 BogoMIPS (lpj=9600059)
[ 0.156009] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.156009] CPU: L2 cache: 4096K
[ 0.156009] CPU 1/1 -> Node 0
[ 0.156009] CPU: Physical Processor ID: 0
[ 0.156009] CPU: Processor Core ID: 1
[ 0.156009] CPU1: Thermal monitoring enabled (TM2)
[ 0.236014] CPU1: Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz stepping 06
[ 0.236014] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[ 0.240015] Brought up 2 CPUs
[ 0.240015] Total of 2 processors activated (9603.59 BogoMIPS).
[ 0.240015] CPU0 attaching sched-domain:
[ 0.240015] domain 0: span 0-1
[ 0.240015] groups: 0 1
[ 0.240015] domain 1: span 0-1
[ 0.240015] groups: 0-1
[ 0.240015] CPU1 attaching sched-domain:
[ 0.240015] groups: 1 0
[ 0.240015] net_namespace: 1224 bytes
[ 0.240015] Booting paravirtualized kernel on bare hardware
[ 0.240015] NET: Registered protocol family 16
[ 0.240015] ACPI: bus type pci registered
[ 0.240015] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.240015] PCI: Not using MMCONFIG.
[ 0.240015] PCI: Using configuration type 1 for base access
[ 0.240015] ACPI: EC: Look up EC in DSDT
[ 0.251581] ACPI: Interpreter enabled
[ 0.251583] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.251599] ACPI: Using IOAPIC for interrupt routing
[ 0.251651] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.254065] PCI: MCFG area at e0000000 reserved in ACPI motherboard resources
[ 0.266397] PCI: Using MMCONFIG at e0000000 - efffffff
[ 0.276017] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.276017] pci 0000:00:1f.0: quirk: region 0800-087f claimed by ICH6 ACPI/GPIO/TCO
[ 0.276017] pci 0000:00:1f.0: quirk: region 0480-04bf claimed by ICH6 GPIO
[ 0.276017] PCI: Transparent bridge - 0000:00:1e.0
[ 0.276017] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.276017] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P2._PRT]
[ 0.276129] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.276343] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT]
[ 0.276455] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P8._PRT]
[ 0.276567] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P9._PRT]
[ 0.293014] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.293014] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.293014] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.293014] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 *15)
[ 0.293134] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 *14 15)
[ 0.293250] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.293366] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.293482] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[ 0.297014] ACPI Warning (tbutils-0217): Incorrect checksum in table [OEMB] - B8, should be AF [20080321]
[ 0.297014] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 0.297014] pnp: PnP ACPI init
[ 0.297014] ACPI: bus type pnp registered
[ 0.297014] pnp 00:00: parse allocated resources
[ 0.297014] pnp 00:00: add io 0xcf8-0xcff flags 0x1
[ 0.297014] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.297014] pnp 00:01: parse allocated resources
[ 0.297014] pnp 00:01: add mem 0xfed14000-0xfed19fff flags 0x1
[ 0.297014] pnp 00:01: PNP0c01: calling quirk_system_pci_resources+0x0/0x15c
[ 0.297014] pnp 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.297014] pnp 00:02: parse allocated resources
[ 0.297014] pnp 00:02: add dma 4 flags 0x4
[ 0.297014] pnp 00:02: add io 0x0-0xf flags 0x1
[ 0.297014] pnp 00:02: add io 0x81-0x83 flags 0x1
[ 0.297014] pnp 00:02: add io 0x87-0x87 flags 0x1
[ 0.297014] pnp 00:02: add io 0x89-0x8b flags 0x1
[ 0.297014] pnp 00:02: add io 0x8f-0x8f flags 0x1
[ 0.297014] pnp 00:02: add io 0xc0-0xdf flags 0x1
[ 0.297014] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.297014] pnp 00:03: parse allocated resources
[ 0.297014] pnp 00:03: add io 0x70-0x71 flags 0x1
[ 0.297014] pnp 00:03: add irq 8 flags 0x1
[ 0.297014] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.297014] pnp 00:04: parse allocated resources
[ 0.297014] pnp 00:04: add io 0x61-0x61 flags 0x1
[ 0.297014] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.297014] pnp 00:05: parse allocated resources
[ 0.297014] pnp 00:05: add io 0xf0-0xff flags 0x1
[ 0.297014] pnp 00:05: add irq 13 flags 0x1
[ 0.297014] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.297014] pnp 00:06: parse allocated resources
[ 0.297014] pnp 00:06: add irq 4 flags 0x1
[ 0.297014] pnp 00:06: add io 0x3f8-0x3ff flags 0x1
[ 0.297014] pnp 00:06: parse resource options
[ 0.297014] pnp 00:06: new independent option
[ 0.297014] pnp 00:06: new dependent option (priority 0x0)
[ 0.297014] pnp 00:06: io min 0x3f8 max 0x3f8 align 1 size 8 flags 0x1
[ 0.297014] pnp 00:06: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000010 flags 0x1
[ 0.297014] pnp 00:06: new dependent option (priority 0x1)
[ 0.297014] pnp 00:06: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1
[ 0.297014] pnp 00:06: io min 0x2f8 max 0x2f8 align 1 size 8 flags 0x1
[ 0.297014] pnp 00:06: io min 0x3e8 max 0x3e8 align 1 size 8 flags 0x1
[ 0.297014] pnp 00:06: io min 0x2e8 max 0x2e8 align 1 size 8 flags 0x1
[ 0.297014] pnp 00:06: end dependent options
[ 0.297014] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.297014] pnp 00:07: parse allocated resources
[ 0.297014] pnp 00:07: add irq 6 flags 0x1
[ 0.297014] pnp 00:07: add dma 2 flags 0x0
[ 0.297014] pnp 00:07: add io 0x3f0-0x3f5 flags 0x1
[ 0.297014] pnp 00:07: add io 0x3f7-0x3f7 flags 0x1
[ 0.297014] pnp 00:07: parse resource options
[ 0.297014] pnp 00:07: new independent option
[ 0.297014] pnp 00:07: new dependent option (priority 0x0)
[ 0.297014] pnp 00:07: io min 0x3f0 max 0x3f0 align 1 size 6 flags 0x1
[ 0.297014] pnp 00:07: io min 0x3f7 max 0x3f7 align 1 size 1 flags 0x1
[ 0.297014] pnp 00:07: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000040 flags 0x1
[ 0.297014] pnp 00:07: dma bitmask 0x4 flags 0x0
[ 0.297014] pnp 00:07: new dependent option (priority 0x1)
[ 0.297014] pnp 00:07: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1
[ 0.297014] pnp 00:07: dma bitmask 0xf flags 0x0
[ 0.297014] pnp 00:07: io min 0x370 max 0x370 align 1 size 6 flags 0x1
[ 0.297014] pnp 00:07: io min 0x377 max 0x377 align 1 size 1 flags 0x1
[ 0.297014] pnp 00:07: end dependent options
[ 0.297014] pnp 00:07: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.297014] pnp 00:08: parse allocated resources
[ 0.297014] pnp 00:08: add io 0x0-0xffffffffffffffff flags 0x10000001
[ 0.297014] pnp 00:08: add io 0x290-0x297 flags 0x1
[ 0.297014] pnp 00:08: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.297014] pnp 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.297014] pnp 00:09: parse allocated resources
[ 0.297014] pnp 00:09: add io 0x10-0x1f flags 0x1
[ 0.297014] pnp 00:09: add io 0x22-0x3f flags 0x1
[ 0.297014] pnp 00:09: add io 0x44-0x5f flags 0x1
[ 0.297014] pnp 00:09: add io 0x62-0x63 flags 0x1
[ 0.297014] pnp 00:09: add io 0x65-0x6f flags 0x1
[ 0.297014] pnp 00:09: add io 0x72-0x7f flags 0x1
[ 0.297014] pnp 00:09: add io 0x80-0x80 flags 0x1
[ 0.297014] pnp 00:09: add io 0x84-0x86 flags 0x1
[ 0.297014] pnp 00:09: add io 0x88-0x88 flags 0x1
[ 0.297014] pnp 00:09: add io 0x8c-0x8e flags 0x1
[ 0.297014] pnp 00:09: add io 0x90-0x9f flags 0x1
[ 0.297014] pnp 00:09: add io 0xa2-0xbf flags 0x1
[ 0.297014] pnp 00:09: add io 0xe0-0xef flags 0x1
[ 0.297014] pnp 00:09: add io 0x4d0-0x4d1 flags 0x1
[ 0.297014] pnp 00:09: add io 0x800-0x87f flags 0x1
[ 0.297014] pnp 00:09: add io 0x400-0x3ff flags 0x10000001
[ 0.297014] pnp 00:09: add io 0x480-0x4bf flags 0x1
[ 0.297014] pnp 00:09: add mem 0xffafe000-0xffb0cbff flags 0x1
[ 0.297014] pnp 00:09: add mem 0xffb00000-0xffbfffff flags 0x1
[ 0.297014] pnp 00:09: add mem 0xfed1c000-0xfed1ffff flags 0x1
[ 0.297014] pnp 00:09: add mem 0xfed20000-0xfed8ffff flags 0x1
[ 0.297014] pnp 00:09: add mem 0xfff00000-0xfffffffe flags 0x1
[ 0.297014] pnp 00:09: add mem 0xfebfe000-0xfebfec00 flags 0x1
[ 0.297014] pnp 00:09: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.297014] pnp 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.297014] pnp 00:0a: parse allocated resources
[ 0.297014] pnp 00:0a: add mem 0xfed00000-0xfed003ff flags 0x0
[ 0.297014] pnp 00:0a: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.297014] pnp 00:0b: parse allocated resources
[ 0.297014] pnp 00:0b: add mem 0xfec00000-0xfec00fff flags 0x0
[ 0.297014] pnp 00:0b: add mem 0xfee00000-0xfee00fff flags 0x0
[ 0.297014] pnp 00:0b: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.297014] pnp 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.297014] pnp 00:0c: parse allocated resources
[ 0.297014] pnp 00:0c: add mem 0xe0000000-0xefffffff flags 0x0
[ 0.297014] pnp 00:0c: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.297014] pnp 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.297014] pnp 00:0d: parse allocated resources
[ 0.297014] pnp 00:0d: add mem 0x0-0x9ffff flags 0x1
[ 0.297014] pnp 00:0d: add mem 0xc0000-0xcffff flags 0x0
[ 0.297014] pnp 00:0d: add mem 0xe0000-0xfffff flags 0x0
[ 0.297014] pnp 00:0d: add mem 0x100000-0xbfffffff flags 0x1
[ 0.297014] pnp 00:0d: add mem 0x0-0xffffffffffffffff flags 0x10000000
[ 0.297014] pnp 00:0d: PNP0c01: calling quirk_system_pci_resources+0x0/0x15c
[ 0.297014] pnp 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.297329] pnp: PnP ACPI: found 14 devices
[ 0.297331] ACPI: ACPI bus type pnp unregistered
[ 0.301014] usbcore: registered new interface driver usbfs
[ 0.301014] usbcore: registered new interface driver hub
[ 0.301014] usbcore: registered new device driver usb
[ 0.301015] PCI: Using ACPI for IRQ routing
[ 0.316481] PCI-GART: No AMD northbridge found.
[ 0.316486] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.316491] hpet0: 3 64-bit timers, 14318180 Hz
[ 0.317733] ACPI: RTC can wake from S4
[ 0.332772] pnp: the driver 'system' has been registered
[ 0.332784] system 00:01: iomem range 0xfed14000-0xfed19fff has been reserved
[ 0.332786] system 00:01: driver attached
[ 0.332796] system 00:08: ioport range 0x290-0x297 has been reserved
[ 0.332799] system 00:08: driver attached
[ 0.332805] system 00:09: ioport range 0x4d0-0x4d1 has been reserved
[ 0.332809] system 00:09: ioport range 0x800-0x87f has been reserved
[ 0.332812] system 00:09: ioport range 0x480-0x4bf has been reserved
[ 0.332816] system 00:09: iomem range 0xffafe000-0xffb0cbff could not be reserved
[ 0.332820] system 00:09: iomem range 0xffb00000-0xffbfffff could not be reserved
[ 0.332823] system 00:09: iomem range 0xfed1c000-0xfed1ffff has been reserved
[ 0.332826] system 00:09: iomem range 0xfed20000-0xfed8ffff has been reserved
[ 0.332830] system 00:09: iomem range 0xfff00000-0xfffffffe could not be reserved
[ 0.332833] system 00:09: iomem range 0xfebfe000-0xfebfec00 has been reserved
[ 0.332836] system 00:09: driver attached
[ 0.332843] system 00:0b: iomem range 0xfec00000-0xfec00fff has been reserved
[ 0.332847] system 00:0b: iomem range 0xfee00000-0xfee00fff could not be reserved
[ 0.332849] system 00:0b: driver attached
[ 0.332855] system 00:0c: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.332858] system 00:0c: driver attached
[ 0.332865] system 00:0d: iomem range 0x0-0x9ffff could not be reserved
[ 0.332868] system 00:0d: iomem range 0xc0000-0xcffff has been reserved
[ 0.332873] system 00:0d: iomem range 0xe0000-0xfffff could not be reserved
[ 0.332877] system 00:0d: iomem range 0x100000-0xbfffffff could not be reserved
[ 0.332879] system 00:0d: driver attached
[ 0.333856] PCI: Bridge: 0000:00:01.0
[ 0.333856] IO window: b000-bfff
[ 0.333856] MEM window: 0xf9000000-0xfbcfffff
[ 0.333856] PREFETCH window: 0x00000000d0000000-0x00000000dfffffff
[ 0.333856] PCI: Bridge: 0000:00:1c.0
[ 0.333856] IO window: disabled.
[ 0.333856] MEM window: disabled.
[ 0.333856] PREFETCH window: 0x00000000f7f00000-0x00000000f7ffffff
[ 0.333856] PCI: Bridge: 0000:00:1c.4
[ 0.333856] IO window: d000-dfff
[ 0.333856] MEM window: 0xfbe00000-0xfbefffff
[ 0.333856] PREFETCH window: disabled.
[ 0.333856] PCI: Bridge: 0000:00:1c.5
[ 0.333856] IO window: c000-cfff
[ 0.333856] MEM window: 0xfbd00000-0xfbdfffff
[ 0.333856] PCI: Bridge: 0000:00:1e.0
[ 0.333856] IO window: e000-efff
[ 0.333856] MEM window: 0xfbf00000-0xfbffffff
[ 0.333856] PREFETCH window: 0x00000000c4000000-0x00000000c40fffff
[ 0.333856] ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 0.333856] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 0.333856] ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 0.333856] PCI: Setting latency timer of device 0000:00:1c.0 to 64
[ 0.333856] ACPI: PCI Interrupt 0000:00:1c.4[A] -> GSI 16 (level, low) -> IRQ 16
[ 0.333856] PCI: Setting latency timer of device 0000:00:1c.4 to 64
[ 0.333856] ACPI: PCI Interrupt 0000:00:1c.5[B] -> GSI 17 (level, low) -> IRQ 17
[ 0.333856] PCI: Setting latency timer of device 0000:00:1c.5 to 64
[ 0.333856] PCI: Setting latency timer of device 0000:00:1e.0 to 64
[ 0.333856] NET: Registered protocol family 2
[ 0.369713] IP route cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.370223] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.374240] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.374240] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.374240] TCP reno registered
[ 0.384101] NET: Registered protocol family 1
[ 0.384229] checking if image is initramfs...<7>Switched to high resolution mode on CPU 1
[ 0.509627] Switched to high resolution mode on CPU 0
[ 0.609607] it is
[ 0.841630] Freeing initrd memory: 6495k freed
[ 0.842150] audit: initializing netlink socket (disabled)
[ 0.842150] type=2000 audit(1240771251.836:1): initialized
[ 0.842150] Total HugeTLB memory allocated, 0
[ 0.842154] VFS: Disk quotas dquot_6.5.1
[ 0.842177] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.842215] msgmni has been set to 9959
[ 0.843288] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.843290] io scheduler noop registered
[ 0.843292] io scheduler anticipatory registered
[ 0.843293] io scheduler deadline registered
[ 0.843304] io scheduler cfq registered (default)
[ 2.093991] pci 0000:01:00.0: Boot video device
[ 2.094125] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 2.094148] assign_interrupt_mode Found MSI capability
[ 2.094170] Allocate Port Service[0000:00:01.0:pcie00]
[ 2.094204] Allocate Port Service[0000:00:01.0:pcie03]
[ 2.094267] PCI: Setting latency timer of device 0000:00:1c.0 to 64
[ 2.094292] assign_interrupt_mode Found MSI capability
[ 2.094318] Allocate Port Service[0000:00:1c.0:pcie00]
[ 2.094350] Allocate Port Service[0000:00:1c.0:pcie02]
[ 2.094380] Allocate Port Service[0000:00:1c.0:pcie03]
[ 2.094449] PCI: Setting latency timer of device 0000:00:1c.4 to 64
[ 2.094474] assign_interrupt_mode Found MSI capability
[ 2.094499] Allocate Port Service[0000:00:1c.4:pcie00]
[ 2.094531] Allocate Port Service[0000:00:1c.4:pcie02]
[ 2.094563] Allocate Port Service[0000:00:1c.4:pcie03]
[ 2.094631] PCI: Setting latency timer of device 0000:00:1c.5 to 64
[ 2.094656] assign_interrupt_mode Found MSI capability
[ 2.094682] Allocate Port Service[0000:00:1c.5:pcie00]
[ 2.094712] Allocate Port Service[0000:00:1c.5:pcie02]
[ 2.094742] Allocate Port Service[0000:00:1c.5:pcie03]
[ 2.099678] hpet_resources: 0xfed00000 is busy
[ 2.099734] Linux agpgart interface v0.103
[ 2.099736] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 2.099846] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.100013] pnp: the driver 'serial' has been registered
[ 2.100176] 00:06: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.100208] serial 00:06: driver attached
[ 2.100731] brd: module loaded
[ 2.100731] input: Macintosh mouse button emulation as /class/input/input0
[ 2.100731] pnp: the driver 'i8042 kbd' has been registered
[ 2.100731] pnp: the driver 'i8042 aux' has been registered
[ 2.100731] pnp: the driver 'i8042 kbd' has been unregistered
[ 2.100731] pnp: the driver 'i8042 aux' has been unregistered
[ 2.100731] PNP: No PS/2 controller found. Probing ports directly.
[ 2.104231] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.104231] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 2.124251] mice: PS/2 mouse device common for all mice
[ 2.124251] pnp: the driver 'rtc_cmos' has been registered
[ 2.124251] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 2.124251] rtc0: alarms up to one month, y3k
[ 2.124251] rtc_cmos 00:03: driver attached
[ 2.124251] cpuidle: using governor ladder
[ 2.124251] cpuidle: using governor menu
[ 2.124251] No iBFT detected.
[ 2.124251] TCP cubic registered
[ 2.124251] NET: Registered protocol family 17
[ 2.124251] registered taskstats version 1
[ 2.124251] rtc_cmos 00:03: setting system clock to 2009-04-26 18:40:54 UTC (1240771254)
[ 2.124251] Freeing unused kernel memory: 392k freed
[ 2.186234] ACPI: SSDT BFF9E0C0, 01C6 (r1 AMI CPU1PM 1 INTL 20060113)
[ 2.186234] ACPI: ACPI0007:00 is registered as cooling_device0
[ 2.186234] ACPI: SSDT BFF9E290, 013A (r1 AMI CPU2PM 1 INTL 20060113)
[ 2.186234] ACPI: ACPI0007:01 is registered as cooling_device1
[ 2.334854] USB Universal Host Controller Interface driver v3.0
[ 2.334854] ACPI: PCI Interrupt 0000:00:1a.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 2.334854] PCI: Setting latency timer of device 0000:00:1a.0 to 64
[ 2.334854] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 2.334854] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 2.334854] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000a880
[ 2.334854] usb usb1: configuration #1 chosen from 1 choice
[ 2.334854] hub 1-0:1.0: USB hub found
[ 2.334854] hub 1-0:1.0: 2 ports detected
[ 2.356081] No dock devices found.
[ 2.358855] SCSI subsystem initialized
[ 2.363042] Uniform Multi-Platform E-IDE driver
[ 2.363045] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 2.368049] libata version 3.00 loaded.
[ 2.438861] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.438864] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.438866] usb usb1: Product: UHCI Host Controller
[ 2.438867] usb usb1: Manufacturer: Linux 2.6.26-2-amd64 uhci_hcd
[ 2.438869] usb usb1: SerialNumber: 0000:00:1a.0
[ 2.442707] ACPI: PCI Interrupt 0000:00:1a.1[B] -> GSI 17 (level, low) -> IRQ 17
[ 2.442707] PCI: Setting latency timer of device 0000:00:1a.1 to 64
[ 2.442707] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 2.442707] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
[ 2.442707] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ac00
[ 2.442707] usb usb2: configuration #1 chosen from 1 choice
[ 2.442707] hub 2-0:1.0: USB hub found
[ 2.442707] hub 2-0:1.0: 2 ports detected
[ 2.454863] Floppy drive(s): fd0 is 1.44M
[ 2.474707] FDC 0 is a post-1991 82077
[ 2.544609] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.544613] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.544616] usb usb2: Product: UHCI Host Controller
[ 2.544618] usb usb2: Manufacturer: Linux 2.6.26-2-amd64 uhci_hcd
[ 2.544620] usb usb2: SerialNumber: 0000:00:1a.1
[ 2.548504] ACPI: PCI Interrupt 0000:00:1a.7[C] -> GSI 18 (level, low) -> IRQ 18
[ 2.548504] PCI: Setting latency timer of device 0000:00:1a.7 to 64
[ 2.548504] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 2.548504] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 3
[ 2.552504] ehci_hcd 0000:00:1a.7: debug port 1
[ 2.552504] PCI: cache line size of 32 is not supported by device 0000:00:1a.7
[ 2.552504] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xf8fffc00
[ 2.567616] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 2.567690] usb usb3: configuration #1 chosen from 1 choice
[ 2.567722] hub 3-0:1.0: USB hub found
[ 2.567729] hub 3-0:1.0: 4 ports detected
[ 2.671575] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.671579] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.671581] usb usb3: Product: EHCI Host Controller
[ 2.671584] usb usb3: Manufacturer: Linux 2.6.26-2-amd64 ehci_hcd
[ 2.671586] usb usb3: SerialNumber: 0000:00:1a.7
[ 2.672524] ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 23
[ 2.672524] PCI: Setting latency timer of device 0000:00:1d.0 to 64
[ 2.672524] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 2.672524] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 2.672524] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000a400
[ 2.672524] usb usb4: configuration #1 chosen from 1 choice
[ 2.672524] hub 4-0:1.0: USB hub found
[ 2.672524] hub 4-0:1.0: 2 ports detected
[ 2.775071] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.775075] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.775077] usb usb4: Product: UHCI Host Controller
[ 2.775080] usb usb4: Manufacturer: Linux 2.6.26-2-amd64 uhci_hcd
[ 2.775082] usb usb4: SerialNumber: 0000:00:1d.0
[ 2.776585] ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 19
[ 2.776585] PCI: Setting latency timer of device 0000:00:1d.1 to 64
[ 2.776585] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 2.776585] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 5
[ 2.776585] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000a480
[ 2.776585] usb usb5: configuration #1 chosen from 1 choice
[ 2.776585] hub 5-0:1.0: USB hub found
[ 2.776585] hub 5-0:1.0: 2 ports detected
[ 2.878984] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.878987] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.878990] usb usb5: Product: UHCI Host Controller
[ 2.878992] usb usb5: Manufacturer: Linux 2.6.26-2-amd64 uhci_hcd
[ 2.878995] usb usb5: SerialNumber: 0000:00:1d.1
[ 2.880585] ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 18
[ 2.880585] PCI: Setting latency timer of device 0000:00:1d.2 to 64
[ 2.880585] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 2.880585] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 6
[ 2.880585] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000a800
[ 2.880585] usb usb6: configuration #1 chosen from 1 choice
[ 2.880585] hub 6-0:1.0: USB hub found
[ 2.880585] hub 6-0:1.0: 2 ports detected
[ 2.982809] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.982813] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.982816] usb usb6: Product: UHCI Host Controller
[ 2.982818] usb usb6: Manufacturer: Linux 2.6.26-2-amd64 uhci_hcd
[ 2.982820] usb usb6: SerialNumber: 0000:00:1d.2
[ 2.984565] ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 23
[ 2.984565] PCI: Setting latency timer of device 0000:00:1d.7 to 64
[ 2.984565] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 2.984565] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 7
[ 2.988565] ehci_hcd 0000:00:1d.7: debug port 1
[ 2.988565] PCI: cache line size of 32 is not supported by device 0000:00:1d.7
[ 2.988565] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf8fff800
[ 3.003217] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 3.003278] usb usb7: configuration #1 chosen from 1 choice
[ 3.003311] hub 7-0:1.0: USB hub found
[ 3.003318] hub 7-0:1.0: 6 ports detected
[ 3.107145] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.107149] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.107152] usb usb7: Product: EHCI Host Controller
[ 3.107154] usb usb7: Manufacturer: Linux 2.6.26-2-amd64 ehci_hcd
[ 3.107156] usb usb7: SerialNumber: 0000:00:1d.7
[ 3.108483] ACPI: PCI Interrupt 0000:05:01.0[A] -> GSI 22 (level, low) -> IRQ 22
[ 3.108483] uhci_hcd 0000:05:01.0: UHCI Host Controller
[ 3.108483] uhci_hcd 0000:05:01.0: new USB bus registered, assigned bus number 8
[ 3.108483] uhci_hcd 0000:05:01.0: irq 22, io base 0x0000e800
[ 3.108483] usb usb8: configuration #1 chosen from 1 choice
[ 3.108483] hub 8-0:1.0: USB hub found
[ 3.108483] hub 8-0:1.0: 2 ports detected
[ 3.108483] JMB: IDE controller (0x197b:0x2363 rev 0x02) at PCI slot 0000:03:00.1
[ 3.108483] JMicron IDE 0000:03:00.1: enabling device (0000 -> 0001)
[ 3.108483] ACPI: PCI Interrupt 0000:03:00.1[B] -> GSI 17 (level, low) -> IRQ 17
[ 3.108483] JMB: 100% native mode on irq 17
[ 3.108483] PCI: Setting latency timer of device 0000:03:00.1 to 64
[ 3.108483] ide0: BM-DMA at 0xd400-0xd407
[ 3.108483] ide1: BM-DMA at 0xd408-0xd40f
[ 3.108483] Probing IDE interface ide0...
[ 3.209168] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.209172] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.209175] usb usb8: Product: UHCI Host Controller
[ 3.209177] usb usb8: Manufacturer: Linux 2.6.26-2-amd64 uhci_hcd
[ 3.209179] usb usb8: SerialNumber: 0000:05:01.0
[ 3.209211] ACPI: PCI Interrupt 0000:05:01.1[B] -> GSI 23 (level, low) -> IRQ 23
[ 3.209219] uhci_hcd 0000:05:01.1: UHCI Host Controller
[ 3.209269] uhci_hcd 0000:05:01.1: new USB bus registered, assigned bus number 9
[ 3.209291] uhci_hcd 0000:05:01.1: irq 23, io base 0x0000e880
[ 3.209363] usb usb9: configuration #1 chosen from 1 choice
[ 3.209385] hub 9-0:1.0: USB hub found
[ 3.209390] hub 9-0:1.0: 2 ports detected
[ 3.312980] usb usb9: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.312984] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.312987] usb usb9: Product: UHCI Host Controller
[ 3.312989] usb usb9: Manufacturer: Linux 2.6.26-2-amd64 uhci_hcd
[ 3.312991] usb usb9: SerialNumber: 0000:05:01.1
[ 3.313027] ACPI: PCI Interrupt 0000:05:01.2[C] -> GSI 20 (level, low) -> IRQ 20
[ 3.313037] ehci_hcd 0000:05:01.2: EHCI Host Controller
[ 3.313089] ehci_hcd 0000:05:01.2: new USB bus registered, assigned bus number 10
[ 3.313125] ehci_hcd 0000:05:01.2: irq 20, io mem 0xfbfff400
[ 3.391477] usb 3-2: new high speed USB device using ehci_hcd and address 3
[ 3.403546] ehci_hcd 0000:05:01.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 3.403615] usb usb10: configuration #1 chosen from 1 choice
[ 3.403647] hub 10-0:1.0: USB hub found
[ 3.403654] hub 10-0:1.0: 4 ports detected
[ 3.507587] usb usb10: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.507591] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.507593] usb usb10: Product: EHCI Host Controller
[ 3.507596] usb usb10: Manufacturer: Linux 2.6.26-2-amd64 ehci_hcd
[ 3.507598] usb usb10: SerialNumber: 0000:05:01.2
[ 3.554073] hda: PIONEER DVD-RW DVR-111D, ATAPI CD/DVD-ROM drive
[ 3.574310] usb 3-2: configuration #1 chosen from 1 choice
[ 3.578205] usb 3-2: New USB device found, idVendor=05e3, idProduct=070e
[ 3.578207] usb 3-2: New USB device strings: Mfr=0, Product=1, SerialNumber=2
[ 3.578209] usb 3-2: Product: USB Storage
[ 3.578211] usb 3-2: SerialNumber: 000000009321
[ 3.614515] Initializing USB Mass Storage driver...
[ 3.818998] usb 3-3: new high speed USB device using ehci_hcd and address 4
[ 3.956975] usb 3-3: configuration #1 chosen from 1 choice
[ 3.957715] usb 3-3: New USB device found, idVendor=0bda, idProduct=8187
[ 3.957715] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.957715] usb 3-3: Product: RTL8187_Wireless
[ 3.957715] usb 3-3: Manufacturer: Manufacturer_Realtek_RTL8187_
[ 3.957715] usb 3-3: SerialNumber: 0015AF09EACA
[ 4.229593] scsi0 : SCSI emulation for USB Mass Storage devices
[ 4.229691] usbcore: registered new interface driver usb-storage
[ 4.229691] USB Mass Storage support registered.
[ 4.229691] usb-storage: device found at 3
[ 4.229691] usb-storage: waiting for device to settle before scanning
[ 4.458670] usb 1-1: new low speed USB device using uhci_hcd and address 2
[ 4.494723] hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 4.494831] hda: UDMA/66 mode selected
[ 4.494948] Probing IDE interface ide1...
[ 4.740655] usb 1-1: configuration #1 chosen from 1 choice
[ 4.857239] usb 1-1: New USB device found, idVendor=046d, idProduct=c310
[ 4.857243] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.857246] usb 1-1: Product: USB Multimedia Keyboard
[ 4.857248] usb 1-1: Manufacturer: BTC
[ 5.232498] ide0 at 0xdc00-0xdc07,0xd882 on irq 17
[ 5.234491] ide1 at 0xd800-0xd807,0xd482 on irq 17
[ 5.234491] ahci 0000:03:00.0: version 3.0
[ 5.234491] ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 5.914295] usbcore: registered new interface driver hiddev
[ 5.994711] input: BTC USB Multimedia Keyboard as /class/input/input1
[ 6.003781] input,hidraw0: USB HID v1.10 Keyboard [BTC USB Multimedia Keyboard] on usb-0000:00:1a.0-1
[ 6.075092] input: BTC USB Multimedia Keyboard as /class/input/input2
[ 6.083479] input,hiddev96,hidraw1: USB HID v1.10 Device [BTC USB Multimedia Keyboard] on usb-0000:00:1a.0-1
[ 6.083500] usbcore: registered new interface driver usbhid
[ 6.083503] usbhid: v2.6:USB HID core driver
[ 6.236898] usb 9-2: new full speed USB device using uhci_hcd and address 2
[ 6.396911] usb 9-2: configuration #1 chosen from 1 choice
[ 6.412860] usb 9-2: New USB device found, idVendor=050d, idProduct=0121
[ 6.412860] usb 9-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.412860] usb 9-2: Product: BELKIN BLUETOOTH USB ADAPTER CL. 1
[ 6.412860] usb 9-2: Manufacturer: Broadcom Corp
[ 6.816442] ahci 0000:03:00.0: AHCI 0001.0000 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
[ 6.816447] ahci 0000:03:00.0: flags: 64bit ncq pm led clo pmp pio slum part
[ 6.816454] PCI: Setting latency timer of device 0000:03:00.0 to 64
[ 6.820409] scsi1 : ahci
[ 6.820409] scsi2 : ahci
[ 6.820409] ata1: SATA max UDMA/133 abar m8192@0xfbefe000 port 0xfbefe100 irq 16
[ 6.820409] ata2: SATA max UDMA/133 abar m8192@0xfbefe000 port 0xfbefe180 irq 16
[ 7.228200] ata1: SATA link down (SStatus 0 SControl 300)
[ 7.636371] ata2: SATA link down (SStatus 0 SControl 300)
[ 7.656839] ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 17 (level, low) -> IRQ 17
[ 7.656839] PCI: Setting latency timer of device 0000:02:00.0 to 64
[ 7.656839] sky2 0000:02:00.0: v1.21 addr 0xfbdfc000 irq 17 Yukon-EC Ultra (0xb4) rev 2
[ 7.656839] sky2 eth0: addr 00:18:f3:90:12:02
[ 7.656839] ACPI: PCI Interrupt 0000:05:01.3[A] -> GSI 22 (level, low) -> IRQ 22
[ 7.708829] ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[22] MMIO=[fbfff800-fbffffff] Max Packet=[2048] IR/IT contexts=[4/8]
[ 7.720591] ACPI: PCI Interrupt 0000:05:03.0[A] -> GSI 21 (level, low) -> IRQ 21
[ 7.772591] ohci1394: fw-host1: OHCI-1394 1.1 (PCI): IRQ=[21] MMIO=[fbffe800-fbffefff] Max Packet=[2048] IR/IT contexts=[4/8]
[ 7.772591] ACPI: PCI Interrupt 0000:05:04.0[A] -> GSI 19 (level, low) -> IRQ 19
[ 7.772591] skge 1.13 addr 0xfbff4000 irq 19 chip Yukon-Lite rev 9
[ 7.772591] skge eth1: addr 00:18:f3:90:01:70
[ 7.772591] ata_piix 0000:00:1f.2: version 2.12
[ 7.772591] ACPI: PCI Interrupt 0000:00:1f.2[B] -> GSI 19 (level, low) -> IRQ 19
[ 7.772591] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 7.772591] PCI: Setting latency timer of device 0000:00:1f.2 to 64
[ 7.772591] scsi3 : ata_piix
[ 7.772591] scsi4 : ata_piix
[ 7.775042] ata3: SATA max UDMA/133 cmd 0x9400 ctl 0x9080 bmdma 0x8880 irq 19
[ 7.775047] ata4: SATA max UDMA/133 cmd 0x9000 ctl 0x8c00 bmdma 0x8888 irq 19
[ 7.788618] hda: ATAPI 40X DVD-ROM DVD-R CD-R/RW drive, 2000kB Cache
[ 7.788618] Uniform CD-ROM driver Revision: 3.20
[ 8.248834] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 8.272911] ata3.00: ATA-7: SAMSUNG HD501LJ, CR100-06, max UDMA7
[ 8.272914] ata3.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 8.280915] ata3.00: configured for UDMA/133
[ 8.711343] ata4: SATA link down (SStatus 0 SControl 300)
[ 8.711343] scsi 3:0:0:0: Direct-Access ATA SAMSUNG HD501LJ CR10 PQ: 0 ANSI: 5
[ 8.711343] ACPI: PCI Interrupt 0000:00:1f.5[B] -> GSI 19 (level, low) -> IRQ 19
[ 8.711343] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 8.711343] PCI: Setting latency timer of device 0000:00:1f.5 to 64
[ 8.711343] scsi5 : ata_piix
[ 8.711343] scsi6 : ata_piix
[ 8.712587] ata5: SATA max UDMA/133 cmd 0xa080 ctl 0xa000 bmdma 0x9800 irq 19
[ 8.712590] ata6: SATA max UDMA/133 cmd 0x9c00 ctl 0x9880 bmdma 0x9808 irq 19
[ 9.043328] ata5: SATA link down (SStatus 0 SControl 300)
[ 9.092674] ieee1394: Host added: ID:BUS[0-00:1023] GUID[2000000003000ad6]
[ 9.255865] ieee1394: Host added: ID:BUS[1-00:1023] GUID[0011d80000ec42a5]
[ 9.611526] ata6: SATA link down (SStatus 0 SControl 300)
[ 9.623526] Driver 'sd' needs updating - please use bus_type methods
[ 9.623526] sd 3:0:0:0: [sda] 976773168 512-byte hardware sectors (500108 MB)
[ 9.623526] sd 3:0:0:0: [sda] Write Protect is off
[ 9.623526] sd 3:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 9.623526] sd 3:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 9.623526] sda: sda1 sda2 < sda5 sda6 sda7 >
[ 9.699665] sd 3:0:0:0: [sda] Attached SCSI disk
[ 9.928333] PM: Starting manual resume from disk
[ 9.961103] kjournald starting. Commit interval 5 seconds
[ 9.961103] EXT3-fs: mounted filesystem with ordered data mode.
[ 10.506569] usb-storage: device scan complete
[ 10.508844] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 9321 PQ: 0 ANSI: 0
[ 10.508844] scsi 0:0:0:1: Direct-Access Generic STORAGE DEVICE 9321 PQ: 0 ANSI: 0
[ 10.508844] scsi 0:0:0:2: Direct-Access Generic STORAGE DEVICE 9321 PQ: 0 ANSI: 0
[ 10.508844] scsi 0:0:0:3: Direct-Access Generic STORAGE DEVICE 9321 PQ: 0 ANSI: 0
[ 10.510435] sd 0:0:0:0: [sdb] Attached SCSI removable disk
[ 10.512524] sd 0:0:0:1: [sdc] Attached SCSI removable disk
[ 10.512925] sd 0:0:0:2: [sdd] Attached SCSI removable disk
[ 10.512925] sd 0:0:0:3: [sde] Attached SCSI removable disk
[ 10.926125] udevd version 125 started
[ 11.415129] input: Power Button (FF) as /class/input/input3
[ 11.512725] ACPI: Power Button (FF) [PWRF]
[ 11.512806] input: Power Button (CM) as /class/input/input4
[ 11.578443] ACPI: Power Button (CM) [PWRB]
[ 11.985715] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.03 (30-Apr-2008)
[ 11.985715] iTCO_wdt: Found a ICH8 or ICH8R TCO device (Version=2, TCOBASE=0x0860)
[ 11.985715] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 12.046060] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
[ 12.083976] i801_smbus 0000:00:1f.3: enabling device (0001 -> 0003)
[ 12.083976] ACPI: PCI Interrupt 0000:00:1f.3[C] -> GSI 18 (level, low) -> IRQ 18
[ 12.104125] Bluetooth: Core ver 2.11
[ 12.104125] NET: Registered protocol family 31
[ 12.104125] Bluetooth: HCI device and connection manager initialized
[ 12.104125] Bluetooth: HCI socket layer initialized
[ 12.148246] Bluetooth: HCI USB driver ver 2.9
[ 12.221228] ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 22 (level, low) -> IRQ 22
[ 12.221228] PCI: Setting latency timer of device 0000:00:1b.0 to 64
[ 12.297188] phy0: Selected rate control algorithm 'pid'
[ 12.364257] phy0: hwaddr 00:15:af:09:ea:ca, rtl8187 V1 + rtl8225z2
[10514.741279] Adding 5855652k swap on /dev/sda5. Priority:-1 extents:1 across:5855652k
[10515.105433] EXT3 FS on sda7, internal journal
[10515.313424] loop: module loaded
[10515.992819] kjournald starting. Commit interval 5 seconds
[10515.992819] EXT3 FS on sda6, internal journal
[10515.992819] EXT3-fs: mounted filesystem with ordered data mode.
[10517.198074] sky2 eth0: enabling interface
[10517.901046] NET: Registered protocol family 10
[10517.901046] lo: Disabled Privacy Extensions
[10517.901046] ADDRCONF(NETDEV_UP): eth0: link is not ready
[10518.920858] sky2 eth0: Link is up at 100 Mbps, full duplex, flow control both
[10518.920858] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[10529.261723] eth0: no IPv6 routers present
goog:/var/log#
Merci.
