Je cherchais cette fameuse commande
En voici le résultat :
filename: /lib/modules/2.6.32-5-686/kernel/drivers/net/e1000.ko
version: 8.0.35-NAPI
license: GPL
description: Intel(R) PRO/1000 Network Driver
author: Intel Corporation, <linux.nics@intel.com>
srcversion: 8E4E478C6472DA14AA960BC
alias: pci:v00008086d000010B5sv*sd*bc*sc*i*
alias: pci:v00008086d00001099sv*sd*bc*sc*i*
alias: pci:v00008086d0000108Asv*sd*bc*sc*i*
alias: pci:v00008086d0000107Csv*sd*bc*sc*i*
alias: pci:v00008086d0000107Bsv*sd*bc*sc*i*
alias: pci:v00008086d0000107Asv*sd*bc*sc*i*
alias: pci:v00008086d00001079sv*sd*bc*sc*i*
alias: pci:v00008086d00001078sv*sd*bc*sc*i*
alias: pci:v00008086d00001077sv*sd*bc*sc*i*
alias: pci:v00008086d00001076sv*sd*bc*sc*i*
alias: pci:v00008086d00001075sv*sd*bc*sc*i*
alias: pci:v00008086d00001028sv*sd*bc*sc*i*
alias: pci:v00008086d00001027sv*sd*bc*sc*i*
depends:
vermagic: 2.6.32-5-686 SMP mod_unload modversions 686
parm: TxDescriptors:Number of transmit descriptors (array of int)
parm: TxDescPower:Binary exponential size (2^X) of each transmit desc$
parm: RxDescriptors:Number of receive descriptors (array of int)
parm: TxDescriptorStep:Transmit Descriptor Step (array of int)
parm: Speed:Speed setting (array of int)
parm: Duplex:Duplex setting (array of int)
parm: AutoNeg:Advertised auto-negotiation setting (array of int)
parm: FlowControl:Flow Control setting (array of int)
parm: XsumRX:Disable or enable Receive Checksum offload (array of int)
parm: TxIntDelay:Transmit Interrupt Delay (array of int)
parm: TxAbsIntDelay:Transmit Absolute Interrupt Delay (array of int)
parm: RxIntDelay:Receive Interrupt Delay (array of int)
parm: RxAbsIntDelay:Receive Absolute Interrupt Delay (array of int)
parm: InterruptThrottleRate:Interrupt Throttling Rate (array of int)
parm: SmartPowerDownEnable:Enable PHY smart power down (array of int)
parm: copybreak:Maximum size of packet that is copied to a new buffer$
parm: ignore_64bit_dma:Ignore 64-bit DMA (DAC) capability (int)
parm: debug:Debug level (0=none,...,16=all) (int)
C’est la dernière version (8.0.35) du pilote présente sur le site d’Intel.
J’ai bien vérifié que cette version était compatible avec un noyau 2.6.32.*
Je l’ai mise à jour quand je cherchais des solutions, par contre je ne sais pas quelle était la version de base.
[Edit]
[quote]trouvé ça qui confirme:
Oui j’ai effectivement passé cette commande :
[quote]Settings for eth0:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
Auto-negotiation: on
MDI-X: Unknown
Supports Wake-on: umbg
Wake-on: g
Current message level: 0x00000007 (7)
Link detected: yes
