X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Linux Debian
Current Operating System: Linux linax 2.6.18-4-686 #1 SMP Mon Mar 26 17:17:36 UTC 2007 i686
Build Date: 20 April 2007
Before reporting problems, check wiki.x.org
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Apr 20 18:23:03 2007
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
() |–>Screen “Default Screen” (0)
() | |–>Monitor “Écran générique”
() | |–>Device “Carte vidéo générique”
() |–>Input Device “Generic Keyboard”
() |–>Input Device “Configured Mouse”
(WW) The directory “/usr/X11R6/lib/X11/fonts/misc” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/Type1” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi” does not exist.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType
(==) RgbPath set to “/etc/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81dd060
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.2
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.2
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,2770 card 103c,2a22 rev 81 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2771 card 0000,0000 rev 81 class 06,04,00 hdr 01
(II) PCI: 00:1b:0: chip 8086,27d8 card 103c,2a23 rev 01 class 04,03,00 hdr 00
(II) PCI: 00:1d:0: chip 8086,27c8 card 103c,2a22 rev 01 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,27c9 card 103c,2a22 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,27ca card 103c,2a22 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,27cb card 103c,2a22 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,27cc card 103c,2a22 rev 01 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev e1 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,27b8 card 103c,2a22 rev 01 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,27df card 103c,2a22 rev 01 class 01,01,8a hdr 00
(II) PCI: 00:1f:2: chip 8086,27c0 card 103c,2a22 rev 01 class 01,01,8f hdr 00
(II) PCI: 00:1f:3: chip 8086,27da card 103c,2a22 rev 01 class 0c,05,00 hdr 00
(II) PCI: 01:00:0: chip 1002,7146 card 1462,0470 rev 00 class 03,00,00 hdr 80
(II) PCI: 01:00:1: chip 1002,7166 card 1462,0471 rev 00 class 03,80,00 hdr 00
(II) PCI: 02:01:0: chip 1106,3044 card 103c,2a22 rev 80 class 0c,00,10 hdr 00
(II) PCI: 02:08:0: chip 8086,27dc card 103c,2a22 rev 01 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xfdc00000 - 0xfdcfffff (0x100000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:30:0), (0,2,2), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000e000 - 0x0000efff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xfde00000 - 0xfdefffff (0x100000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0xfdd00000 - 0xfddfffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI:*(1:0:0) ATI Technologies Inc RV515 [Radeon X1300] rev 0, Mem @ 0xe0000000/28, 0xfdcf0000/16, I/O @ 0xde00/8, BIOS @ 0xfdcc0000/17
(–) PCI: (1:0:1) ATI Technologies Inc RV515 [Radeon X1300] (Secondary) rev 0, Mem @ 0xfdce0000/16
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xfdefe000 - 0xfdefefff (0x1000) MX[B]
[1] -1 0 0xfdeff000 - 0xfdeff7ff (0x800) MX[B]
[2] -1 0 0xfdffe000 - 0xfdffe3ff (0x400) MX[B]
[3] -1 0 0xfdfff000 - 0xfdfff3ff (0x400) MX[B]
[4] -1 0 0xfdff8000 - 0xfdffbfff (0x4000) MX[B]
[5] -1 0 0xfdcc0000 - 0xfdcdffff (0x20000) MXB
[6] -1 0 0xfdcf0000 - 0xfdcfffff (0x10000) MXB
[7] -1 0 0xe0000000 - 0xefffffff (0x10000000) MXB
[8] -1 0 0x0000ee00 - 0x0000ee3f (0x40) IX[B]
[9] -1 0 0x0000ef00 - 0x0000ef7f (0x80) IX[B]
[10] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[11] -1 0 0x0000f600 - 0x0000f60f (0x10) IX[B]
[12] -1 0 0x0000f700 - 0x0000f703 (0x4) IX[B]
[13] -1 0 0x0000f800 - 0x0000f807 (0x8) IX[B]
[14] -1 0 0x0000f900 - 0x0000f903 (0x4) IX[B]
[15] -1 0 0x0000fa00 - 0x0000fa07 (0x8) IX[B]
[16] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[17] -1 0 0x0000fc00 - 0x0000fc1f (0x20) IX[B]
[18] -1 0 0x0000fd00 - 0x0000fd1f (0x20) IX[B]
[19] -1 0 0x0000fe00 - 0x0000fe1f (0x20) IX[B]
[20] -1 0 0x0000ff00 - 0x0000ff1f (0x20) IX[B]
[21] -1 0 0x0000de00 - 0x0000deff (0x100) IXB
(II) Inactive PCI resource ranges:
[0] -1 0 0xfdce0000 - 0xfdceffff (0x10000) MXB
(II) Active PCI resource ranges after removing overlaps:
(II) Inactive PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xfdefe000 - 0xfdefefff (0x1000) MX[B]
[5] -1 0 0xfdeff000 - 0xfdeff7ff (0x800) MX[B]
[6] -1 0 0xfdffe000 - 0xfdffe3ff (0x400) MX[B]
[7] -1 0 0xfdfff000 - 0xfdfff3ff (0x400) MX[B]
[8] -1 0 0xfdff8000 - 0xfdffbfff (0x4000) MX[B]
[9] -1 0 0xfdcc0000 - 0xfdcdffff (0x20000) MXB
[10] -1 0 0xfdcf0000 - 0xfdcfffff (0x10000) MXB
[11] -1 0 0xe0000000 - 0xefffffff (0x10000000) MXB
[12] -1 0 0xfdce0000 - 0xfdceffff (0x10000) MXB
[13] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[15] -1 0 0x0000ee00 - 0x0000ee3f (0x40) IX[B]
[16] -1 0 0x0000ef00 - 0x0000ef7f (0x80) IX[B]
[17] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[18] -1 0 0x0000f600 - 0x0000f60f (0x10) IX[B]
[19] -1 0 0x0000f700 - 0x0000f703 (0x4) IX[B]
[20] -1 0 0x0000f800 - 0x0000f807 (0x8) IX[B]
[21] -1 0 0x0000f900 - 0x0000f903 (0x4) IX[B]
[22] -1 0 0x0000fa00 - 0x0000fa07 (0x8) IX[B]
[23] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[24] -1 0 0x0000fc00 - 0x0000fc1f (0x20) IX[B]
[25] -1 0 0x0000fd00 - 0x0000fd1f (0x20) IX[B]
[26] -1 0 0x0000fe00 - 0x0000fe1f (0x20) IX[B]
[27] -1 0 0x0000ff00 - 0x0000ff1f (0x20) IX[B]
[28] -1 0 0x0000de00 - 0x0000deff (0x100) IXB
(II) LoadModule: “ddc”(II) Module already built-in
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension XFree86-DRI
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 1.3.0, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: “int10”
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: “vbe”
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.1.0
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “type1”
(II) Loading /usr/lib/xorg/modules//fonts/libtype1.so
(II) Module type1: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.0.2
(II) Loading font Type1
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “fglrx”
(II) Loading /usr/lib/xorg/modules/drivers//fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 7.1.0, module version = 8.34.8
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 1.0
[atiddxSetup] X version mismatch - detected X.org 1.3.0.0, required X.org 7.1.0.0
(II) UnloadModule: “fglrx”
(II) Unloading /usr/lib/xorg/modules/drivers//fglrx_drv.so
(EE) Failed to load module “fglrx” (module requirement mismatch, 0)
(II) LoadModule: “kbd”
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.0
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.1
(EE) No drivers available.
Fatal server error:
no screens found
