Est-ce que quelqu’un pourrait me donner des éclaircissements sur ces warnings recueillis dans mes logs ?
code NVIDIA(0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 20.755] (WW) NVIDIA(0): mode “1920x1080” is specified in the EDID; however, the
[ 20.755] (WW) NVIDIA(0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 20.755] (WW) NVIDIA(0): exclude this mode’s VertRefresh (50.0 Hz); ignoring
[ 20.755] (WW) NVIDIA(0): VertRefresh check for mode “1920x1080”.
[ 20.755] (WW) NVIDIA(0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 20.755] (WW) NVIDIA(0): mode “1280x720” is specified in the EDID; however, the
[ 20.755] (WW) NVIDIA(0): VertRefresh check for mode “1280x720”.
[ 20.755] (WW) NVIDIA(0): EDID’s valid HorizSync range (30.000-83.000 kHz) would
[ 20.755] (WW) NVIDIA(0): exclude this mode’s HorizSync (28.1 kHz); ignoring
[ 20.755] (WW) NVIDIA(0): HorizSync check for mode “1920x1080”.
[ 20.755] (WW) NVIDIA(0): mode “720x576” is specified in the EDID; however, the
[ 20.755] (WW) NVIDIA(0): VertRefresh check for mode “720x576”.
[ 20.755] (WW) NVIDIA(0): exclude this mode’s HorizSync (27.0 kHz); ignoring
[ 20.755] (WW) NVIDIA(0): exclude this mode’s VertRefresh (24.0 Hz); ignoring
[ 20.755] (WW) NVIDIA(0): exclude this mode’s VertRefresh (25.0 Hz); ignoring
[ 20.755] (WW) NVIDIA(0): exclude this mode’s VertRefresh (30.0 Hz); ignoring
[ 20.755] (WW) NVIDIA(0): exclude this mode’s HorizSync (15.6 kHz); ignoring
[ 20.755] (WW) NVIDIA(0): HorizSync check for mode “720x576”.
[ 20.755] (WW) NVIDIA(0): exclude this mode’s VertRefresh (50.1 Hz); ignoring
[ 20.755] (WW) NVIDIA(0): mode “1152x864” is specified in the EDID; however, the
[ 20.755] (WW) NVIDIA(0): exclude this mode’s VertRefresh (75.0 Hz); ignoring
[ 20.755] (WW) NVIDIA(0): VertRefresh check for mode “1152x864”.
[ 20.756] (WW) NVIDIA(0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 20.756] (WW) NVIDIA(0): mode “1920x1080” is specified in the EDID; however, the
[ 20.756] (WW) NVIDIA(0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 20.756] (WW) NVIDIA(0): exclude this mode’s VertRefresh (50.0 Hz); ignoring
[ 20.756] (WW) NVIDIA(0): VertRefresh check for mode “1920x1080”.
[ 20.757] (WW) NVIDIA(0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 20.757] (WW) NVIDIA(0): mode “1280x720” is specified in the EDID; however, the
[ 20.757] (WW) NVIDIA(0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 20.757] (WW) NVIDIA(0): exclude this mode’s VertRefresh (50.0 Hz); ignoring
[ 20.757] (WW) NVIDIA(0): VertRefresh check for mode “1280x720”.
[ 20.757] (WW) NVIDIA(0): mode “1920x1080” is specified in the EDID; however, the
[ 20.757] (WW) NVIDIA(0): EDID’s valid HorizSync range (30.000-83.000 kHz) would
[ 20.757] (WW) NVIDIA(0): exclude this mode’s HorizSync (28.1 kHz); ignoring
[ 20.757] (WW) NVIDIA(0): HorizSync check for mode “1920x1080”.
[ 20.757] (WW) NVIDIA(0): VertRefresh check for mode “1920x1080”.
[ 20.760] (WW) NVIDIA(0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 20.760] (WW) NVIDIA(0): mode “720x576” is specified in the EDID; however, the
[ 20.761] (WW) NVIDIA(0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 20.761] (WW) NVIDIA(0): exclude this mode’s VertRefresh (50.0 Hz); ignoring
[ 20.761] (WW) NVIDIA(0): VertRefresh check for mode “720x576”.
[ 20.761] (WW) NVIDIA(0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 20.761] (WW) NVIDIA(0): mode “1920x1080” is specified in the EDID; however, the
[ 20.761] (WW) NVIDIA(0): EDID’s valid HorizSync range (30.000-83.000 kHz) would
[ 20.761] (WW) NVIDIA(0): exclude this mode’s HorizSync (27.0 kHz); ignoring
[ 20.761] (WW) NVIDIA(0): HorizSync check for mode “1920x1080”.
[ 20.761] (WW) NVIDIA(0): exclude this mode’s VertRefresh (24.0 Hz); ignoring
[ 20.761] (WW) NVIDIA(0): VertRefresh check for mode “1920x1080”.
[ 20.761] (WW) NVIDIA(0): exclude this mode’s HorizSync (28.1 kHz); ignoring
[ 20.761] (WW) NVIDIA(0): exclude this mode’s VertRefresh (25.0 Hz); ignoring
[ 20.762] (WW) NVIDIA(0): EDID’s valid VertRefresh range (58.000-62.000 Hz) would
[ 20.762] (WW) NVIDIA(0): exclude this mode’s VertRefresh (30.0 Hz); ignoring
[ 20.762] (WW) NVIDIA(0): VertRefresh check for mode “1920x1080”.
[ 20.762] (WW) NVIDIA(0): The EDID for LG Electronics LG TV (DFP-1) contradicts itself:
[ 20.762] (WW) NVIDIA(0): mode “720x576” is specified in the EDID; however, the
[ 20.762] (WW) NVIDIA(0): EDID’s valid HorizSync range (30.000-83.000 kHz) would
[ 20.762] (WW) NVIDIA(0): exclude this mode’s HorizSync (15.6 kHz); ignoring
[ 20.762] (WW) NVIDIA(0): HorizSync check for mode “720x576”.
[ 20.762] (WW) NVIDIA(0): exclude this mode’s VertRefresh (50.1 Hz); ignoring
[ 20.762] (WW) NVIDIA(0): VertRefresh check for mode “720x576”.
[ 20.762] (WW) NVIDIA(0): mode “1152x864” is specified in the EDID; however, the
[ 20.762] (WW) NVIDIA(0): exclude this mode’s VertRefresh (75.0 Hz); ignoring
[ 20.762] (WW) NVIDIA(0): VertRefresh check for mode “1152x864”.[/code]
Voici mon xorg.conf
[code]# nvidia-settings: X configuration file generated by nvidia-settings
nvidia-settings: version 290.10 (pbuilder@cake) Wed Nov 23 12:20:24 UTC 2011
Section "ServerLayout"
Identifier "Layout0"
Screen 0 “Screen0” 0 0
InputDevice “Keyboard0” "CoreKeyboard"
InputDevice “Mouse0” "CorePointer"
Option “Xinerama” "0"
EndSection
Section "Files"
EndSection
Section “InputDevice”
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option “Protocol” "auto"
Option “Device” "/dev/psaux"
Option “Emulate3Buttons” "no"
Option “ZAxisMapping” "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section “Monitor”
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "PKB Maestro243DL"
HorizSync 31.0 - 83.0
VertRefresh 56.0 - 76.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 460"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option “TwinView” "1"
Option “TwinViewXineramaInfoOrder” "DFP-0"
Option “metamodes” "DFP-0: 1920x1080_60 +0+0, DFP-1: 1920x1080_60 +0+0"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Merci.
Jul
