Merci !
Sinon côté Bind lorsque je redémarre le service j’ai ça dans le syslog:
Mar 25 11:52:09 server named[4159]: received control channel command 'stop -p'
Mar 25 11:52:09 server named[4159]: shutting down: flushing changes
Mar 25 11:52:09 server named[4159]: stopping command channel on 127.0.0.1#953
Mar 25 11:52:09 server named[4159]: stopping command channel on ::1#953
Mar 25 11:52:09 server named[4159]: no longer listening on ::#53
Mar 25 11:52:09 server named[4159]: no longer listening on 127.0.0.1#53
Mar 25 11:52:09 server named[4159]: no longer listening on 192.168.1.10#53
Mar 25 11:52:09 server named[4159]: exiting
Mar 25 11:52:09 server named[4384]: starting BIND 9.5.1-P3 -u bind
Mar 25 11:52:09 server named[4384]: found 1 CPU, using 1 worker thread
Mar 25 11:52:09 server named[4384]: using up to 4096 sockets
Mar 25 11:52:09 server named[4384]: loading configuration from '/etc/bind/named.conf'
Mar 25 11:52:09 server named[4384]: max open files (1024) is smaller than max sockets (4096)
Mar 25 11:52:09 server named[4384]: using default UDP/IPv4 port range: [1024, 65535]
Mar 25 11:52:09 server named[4384]: using default UDP/IPv6 port range: [1024, 65535]
Mar 25 11:52:09 server named[4384]: listening on IPv6 interfaces, port 53
Mar 25 11:52:09 server named[4384]: listening on IPv4 interface lo, 127.0.0.1#53
Mar 25 11:52:09 server named[4384]: listening on IPv4 interface eth0, 192.168.1.10#53
Mar 25 11:52:09 server named[4384]: automatic empty zone: 254.169.IN-ADDR.ARPA
Mar 25 11:52:09 server named[4384]: automatic empty zone: 2.0.192.IN-ADDR.ARPA
Mar 25 11:52:09 server named[4384]: automatic empty zone: 255.255.255.255.IN-ADDR.ARPA
Mar 25 11:52:09 server named[4384]: automatic empty zone: 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.IP6.ARPA
Mar 25 11:52:09 server named[4384]: automatic empty zone: 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.IP6.ARPA
Mar 25 11:52:09 server named[4384]: automatic empty zone: D.F.IP6.ARPA
Mar 25 11:52:09 server named[4384]: automatic empty zone: 8.E.F.IP6.ARPA
Mar 25 11:52:09 server named[4384]: automatic empty zone: 9.E.F.IP6.ARPA
Mar 25 11:52:09 server named[4384]: automatic empty zone: A.E.F.IP6.ARPA
Mar 25 11:52:09 server named[4384]: automatic empty zone: B.E.F.IP6.ARPA
Mar 25 11:52:09 server named[4384]: command channel listening on 127.0.0.1#953
Mar 25 11:52:09 server named[4384]: command channel listening on ::1#953
Mar 25 11:52:09 server named[4384]: zone 0.in-addr.arpa/IN: loaded serial 1
Mar 25 11:52:09 server named[4384]: zone 127.in-addr.arpa/IN: loaded serial 1
Mar 25 11:52:09 server named[4384]: zone 255.in-addr.arpa/IN: loaded serial 1
Mar 25 11:52:09 server named[4384]: zone server.dev/IN: loaded serial 1269359805
Mar 25 11:52:09 server named[4384]: zone localhost/IN: loaded serial 2
Mar 25 11:52:09 server named[4384]: running
Il semblerait que server.dev devrait marcher non?
EDIT: Je viens de faire un test :
[code]> nslookup www.server.dev
Server: 192.168.1.10
Address: 192.168.1.10#53
nslookup sql.server.dev
nslookup server.dev
*** Can’t find server.dev: No answer
Et comme on peut le voir server.dev fonctionne de nouveau (ne fonctionnait pas il y a 5min…) et server.dev ne fonctionne pas!
Que se passe t il?
