Salut à tous,
Je laisse le script d’antidote au cas ou :
[code]#!/bin/bash
Script d’aide au lancement d’Antidote. Ajuste les variables d’environnement nécessaires
à l’intégration à certains texteurs.
SELF=$0
if [ -h “$SELF” ] ; then
SELF=readlink -f "$SELF"
fi
if [ ${USER} == “root” ] ; then HOME=/root ; fi
ANTIDOTE_CONFIG=${HOME}/.antidote/7.0
SELF=$(cd $(dirname “$SELF”); pwd -P)/$(basename “$SELF”)
SELF_DIR=dirname "$SELF"
SELF_NAME=basename "$SELF"
SELF_BIN=${SELF_NAME}.bin
EXTENSION_SUBDIR=sed -e '/\[Antidote7\]/,/^$/ !d' /etc/antidote.conf | grep ^Antidote.*Extensions= | awk -F = '{ print $2 }'
LIB_PATH=""
for REP in “${ANTIDOTE_CONFIG}/${EXTENSION_SUBDIR}/lib/”* ; do
LIB_PATH=$REP:$LIB_PATH
done
if [[ ! “$LD_LIBRARY_PATH” =~ (^/lib:|:/lib:|:/lib$) ]] ; then
LIB_PATH=/lib:$LIB_PATH
fi
if [[ ! “$LD_LIBRARY_PATH” =~ (^/usr/lib:|:/usr/lib:|:/usr/lib$) ]] ; then
LIB_PATH=/usr/lib:$LIB_PATH
fi
UNOPATH=sed -e '/\[LibreOffice\]/,/UnoPath/ !d' ${SELF_DIR}/../Donnees/Configuration/config.ini | grep ^UnoPath= | awk -F = '{ print $2 }'
UNOPATH_ENV=""
if [ -n “$UNOPATH” -a -e “${UNOPATH}/soffice” ] ; then
UNOPATH_ENV="UNOPATH_ENV=${UNOPATH}"
export UNO_PATH=${UNOPATH}
fi
LD_LIBRARY_PATH=${SELF_DIR}/lib:${LIB_PATH}:${LD_LIBRARY_PATH} HOME=${HOME} “${SELF_DIR}/${SELF_BIN}” “$@”[/code]
