[wheezy] choisir noyeau à l'install
bonjour a tous,
je viens d’installer wheezy sur mon pc, mais sur un disque dur de test (branché à la place de mon ssd)
je suis tombé sur une colle :
l’install me propose de choisir mon noyau :
3.1.0-1-486
3.1.0-1-686 pae
-486
-686pae
j’ai pris le premier choix, mais j’aimerais bien savoir à quoi correspond tout celà ? (je suis avec un athlon 1800 et 2go de ram)
00:00.0 RAM memory: nVidia Corporation MCP55 Memory Controller (rev a1)
00:01.0 ISA bridge: nVidia Corporation MCP55 LPC Bridge (rev a2)
00:01.1 SMBus: nVidia Corporation MCP55 SMBus (rev a2)
00:01.2 RAM memory: nVidia Corporation MCP55 Memory Controller (rev a2)
00:02.0 USB Controller: nVidia Corporation MCP55 USB Controller (rev a1)
00:02.1 USB Controller: nVidia Corporation MCP55 USB Controller (rev a2)
00:04.0 IDE interface: nVidia Corporation MCP55 IDE (rev a1)
00:05.0 IDE interface: nVidia Corporation MCP55 SATA Controller (rev a2)
00:05.1 IDE interface: nVidia Corporation MCP55 SATA Controller (rev a2)
00:05.2 IDE interface: nVidia Corporation MCP55 SATA Controller (rev a2)
00:06.0 PCI bridge: nVidia Corporation MCP55 PCI bridge (rev a2)
00:06.1 Audio device: nVidia Corporation MCP55 High Definition Audio (rev a2)
00:08.0 Bridge: nVidia Corporation MCP55 Ethernet (rev a2)
00:0a.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2)
00:0b.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2)
00:0c.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2)
00:0d.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2)
00:0e.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2)
00:0f.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
07:00.0 VGA compatible controller: nVidia Corporation GT218 [GeForce 210] (rev a2)
07:00.1 Audio device: nVidia Corporation High Definition Audio Controller (rev a1)
Ton processeur Athlon 64 est compatible 686 et PAE donc tu peux utiliser le -686-pae. Mais il est aussi 64 bits, tu aurais pu installer la distribution amd64 plutôt que i386.
Pour les détails, le web est à ta disposition.
fr.wikipedia.org/wiki/Physical_Address_Extension
packages.debian.org/wheezy/linux … .1.0-1-486
packages.debian.org/wheezy/linux … -1-686-pae
packages.debian.org/wheezy/linux … .0-1-amd64
Juste pour compléter ce que dit Pascal concernant la distrib AMD64 : grosso modo elle utilise plus de mémoire (+30% en moyenne) mais par contre c’est plus rapide que du 32 bits.
Au prix de la mémoire de nos jours (~10€ les 2Go) ça vaut pas le coup de se priver si ton processeur le gère !
Merci pour vos réponses :smiley:
Je pense remplacer le PC dans quelques mois, aussi je vais le laisser avec ses 2go.
