J’ai installer LENNY le week end dernier et depuis je n’ai plus d’accès au wifi.
J’ai une carte Intel 3945 avec le firmware installé, je detecte les réseaux WIFI mais je ne peux pas m’y connecter.
J’utilise Network Manager ou la ligne de commande et c’est pareil.
J’ai aussi testé plusieurs réseau WIFI.
Voici les messages de log que j’ai:
syslog
Mar 12 17:38:23 timar-laptop NetworkManager: <info> User request to enable wireless.
Mar 12 17:38:24 timar-laptop kernel: [ 144.257211] ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 17 (level, low) -> IRQ 17
Mar 12 17:38:24 timar-laptop kernel: [ 144.257377] PM: Writing back config space on device 0000:03:00.0 at offset 1 (was 100002, writing 100006)
Mar 12 17:38:24 timar-laptop kernel: [ 144.311432] Registered led device: iwl-phy0:radio
Mar 12 17:38:24 timar-laptop kernel: [ 144.311432] Registered led device: iwl-phy0:assoc
Mar 12 17:38:24 timar-laptop kernel: [ 144.311432] Registered led device: iwl-phy0:RX
Mar 12 17:38:24 timar-laptop kernel: [ 144.311432] Registered led device: iwl-phy0:TX
Mar 12 17:38:24 timar-laptop kernel: [ 144.319241] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Mar 12 17:38:34 timar-laptop dhcdbd: message_handler: message handler not found under /com/redhat/dhcp/wlan0 for sub-path wlan0.dbus.get.reason
Mar 12 17:38:34 timar-laptop NetworkManager: <debug> [1236875914.577113] nm_device_802_11_wireless_get_activation_ap(): Forcing AP 'PRiVaTeWLaN'
Mar 12 17:38:34 timar-laptop NetworkManager: <info> User Switch: /org/freedesktop/NetworkManager/Devices/wlan0 / PRiVaTeWLaN
Mar 12 17:38:34 timar-laptop NetworkManager: <info> Deactivating device wlan0.
Mar 12 17:38:34 timar-laptop NetworkManager: <info> Device wlan0 activation scheduled...
Mar 12 17:38:34 timar-laptop NetworkManager: <info> Activation (wlan0) started...
Mar 12 17:38:34 timar-laptop NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Mar 12 17:38:34 timar-laptop NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Mar 12 17:38:34 timar-laptop NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Mar 12 17:38:34 timar-laptop NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Mar 12 17:38:34 timar-laptop NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Mar 12 17:38:34 timar-laptop NetworkManager: <info> Activation (wlan0/wireless): access point 'PRiVaTeWLaN' is encrypted, but NO valid key exists. New key needed.
Mar 12 17:38:34 timar-laptop NetworkManager: <info> Activation (wlan0) New wireless user key requested for network 'PRiVaTeWLaN'.
Mar 12 17:38:34 timar-laptop NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Mar 12 17:38:48 timar-laptop NetworkManager: <info> Activation (wlan0) New wireless user key for network 'PRiVaTeWLaN' received.
Mar 12 17:38:48 timar-laptop NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Mar 12 17:38:48 timar-laptop NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Mar 12 17:38:48 timar-laptop NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Mar 12 17:38:48 timar-laptop NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Mar 12 17:38:48 timar-laptop NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Mar 12 17:38:48 timar-laptop NetworkManager: <info> Activation (wlan0/wireless): access point 'PRiVaTeWLaN' is encrypted, and a key exists. No new key needed.
Mar 12 17:38:50 timar-laptop NetworkManager: <info> SUP: sending command 'INTERFACE_ADD wlan0#011#011wext#011/var/run/wpa_supplicant#011'
Mar 12 17:38:50 timar-laptop NetworkManager: <info> SUP: response was 'OK'
Mar 12 17:38:50 timar-laptop NetworkManager: <info> SUP: sending command 'AP_SCAN 1'
Mar 12 17:38:50 timar-laptop NetworkManager: <info> SUP: sending command 'ADD_NETWORK'
Mar 12 17:38:50 timar-laptop NetworkManager: <info> SUP: response was '0'
Mar 12 17:38:50 timar-laptop NetworkManager: <info> SUP: sending command 'SET_NETWORK 0 ssid 50526956615465574c614e'
Mar 12 17:38:50 timar-laptop NetworkManager: <info> SUP: sending command 'SET_NETWORK 0 proto WPA'
Mar 12 17:38:50 timar-laptop NetworkManager: <info> SUP: sending command 'SET_NETWORK 0 key_mgmt WPA-PSK'
Mar 12 17:38:50 timar-laptop NetworkManager: <info> SUP: sending command 'SET_NETWORK 0 psk <key>'
Mar 12 17:38:50 timar-laptop NetworkManager: <info> SUP: sending command 'ENABLE_NETWORK 0'
Mar 12 17:38:50 timar-laptop NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Mar 12 17:38:53 timar-laptop kernel: [ 173.662498] wlan0: Initial auth_alg=0
Mar 12 17:38:53 timar-laptop kernel: [ 173.662498] wlan0: authenticate with AP b2:08:9f:2c:7b:74
Mar 12 17:38:54 timar-laptop kernel: [ 173.862461] wlan0: authenticate with AP b2:08:9f:2c:7b:74
Mar 12 17:38:54 timar-laptop kernel: [ 174.063549] wlan0: authenticate with AP b2:08:9f:2c:7b:74
Mar 12 17:38:54 timar-laptop kernel: [ 174.263559] wlan0: authentication with AP b2:08:9f:2c:7b:74 timed out
Mar 12 17:38:58 timar-laptop NetworkManager: <info> Old device 'wlan0' activating, won't change.
Mar 12 17:39:06 timar-laptop kernel: [ 185.893434] wlan0: Initial auth_alg=0
Mar 12 17:39:06 timar-laptop kernel: [ 185.893434] wlan0: authenticate with AP b2:08:9f:2c:7b:74
Mar 12 17:39:06 timar-laptop kernel: [ 185.893640] wlan0: Initial auth_alg=0
Mar 12 17:39:06 timar-laptop kernel: [ 185.893640] wlan0: authenticate with AP b2:08:9f:2c:7b:74
Mar 12 17:39:06 timar-laptop kernel: [ 186.097730] wlan0: authenticate with AP b2:08:9f:2c:7b:74
Mar 12 17:39:06 timar-laptop kernel: [ 186.297770] wlan0: authenticate with AP b2:08:9f:2c:7b:74
Mar 12 17:39:06 timar-laptop kernel: [ 186.497728] wlan0: authentication with AP b2:08:9f:2c:7b:74 timed out
Les 8 dernières lignes sont répétées une dizaine de fois.
C’est un réseau Wifi sur une freebox qui fonctionnait sous Etch avec du WPA.
Toute aide est bienvenue.
personne ne voit quoi me dire. Tout semble normale mais pourtant ça ne fonctionne pas.
