Wifi debian 5.0.5
J’ai un problème avec ma wifi, j’ai fait des recherches et je suis tombé sur ce tuto : ici, j’ai donc suivi les instructions, effectuer la commande :
"/sbin/iwconfig", ma carte n’est pas reconnue, je passe donc à l’étape 2, malheureusement je ne connais pas ma carte wifi, je lance donc la commande :
“lspci” dont voici le résultat :
00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 09) 00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 09) 00:02.1 Display controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 09) 00:1a.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 03) 00:1a.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 03) 00:1a.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 03) 00:1a.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 03) 00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03) 00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 03) 00:1c.3 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 4 (rev 03) 00:1d.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 03) 00:1d.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 03) 00:1d.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 03) 00:1d.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 03) 00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 93) 00:1f.0 ISA bridge: Intel Corporation ICH9M LPC Interface Controller (rev 03) 00:1f.2 IDE interface: Intel Corporation ICH9M/M-E 2 port SATA IDE Controller (rev 03) 00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 03) 00:1f.5 IDE interface: Intel Corporation ICH9M/M-E 2 port SATA IDE Controller (rev 03) 02:00.0 Network controller: Atheros Communications Inc. Device 002b (rev 01) 04:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8040 PCI-E Fast Ethernet Controller je ne trouve pas le nom de ma carte, peut-être que vous pouvez m’aider ?
Merci par avance
P.s : mon ordi est un samsung r-730
je penche pour Atheros Communications :wink:
regarde dans truc et astuce fran.b a fait un tuto aussi plus simple :slight_smile: mai j’arrive pas mette la main dessus, le tien me semble un peux long mai bon le wifi …
merci, je vais chercher.
edit : en effet, la carte était bien la Atheros, voilà le tuto avec lequel j’ai installé ma carte :
ici
en espérant que cela puisse servir à quelqu’un.
