J’ai un soucis pour configurer mon wifi (je suis chez free avec une clé WPA (TKIP + AES) ). J’ai essayer avec wicd mais impossible de me connecter.
J’ai ensuite désinstallé wicd et essayer en manuel en suivant ce tuto.
Une chose me parait bizarre quand je fais # iwconfig c’est Access Point: Not-Associated dans wlan0.
Si quelqu’un a une piste, je suis preneur.
[quote]~$ lspci | grep -i network
00:0a.0 Network controller: RaLink RT2561/RT61 802.11g PCI[/quote]
[quote]~$ cat /etc/network/interfaces
This file describes the network interfaces available on your system
auto lo
iface lo inet loopback
The primary network interface
allow-hotplug eth0
iface eth0 inet dhcp[/quote]
[quote]~$ cat /etc/resolv.conf
nameserver 212.27.40.240
nameserver 212.27.40.241
[quote]# ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:08:54:54:87:bd
Interruption:9 Adresse de base:0xcc00
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:48 errors:0 dropped:0 overruns:0 frame:0
TX packets:48 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3328 (3.2 KiB) TX bytes:3328 (3.2 KiB)
wlan0 Link encap:Ethernet HWaddr 00:18:f8:b0:19:d9
wmaster0 Link encap:UNSPEC HWaddr 00-18-F8-B0-19-D9-6C-6F-00-00-00-00-00-00-00-00
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)[/quote]
[quote]# iwlist scan
lo Interface doesn’t support scanning.
eth0 Interface doesn’t support scanning.
wmaster0 Interface doesn’t support scanning.
wlan0 Scan completed :
Cell 01 - Address: 00:0F:A3:E0:50:28
ESSID:"chezfree"
Mode:Master
Channel:7
Frequency:2.442 GHz (Channel 7)
Quality=55/100 Signal level=-28 dBm
Encryption key:on
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : TKIP CCMP
Authentication Suites (1) : PSK
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : TKIP
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s; 36 Mb/s
48 Mb/s; 54 Mb/s
Extra:tsf=0000002f0bf299d7
Cell 02 - Address: 00:17:33:C6:14:74
ESSID:"Neuf WiFi"
Mode:Master
Channel:11
Frequency:2.462 GHz (Channel 11)
Quality=46/100 Signal level=-82 dBm
Encryption key:off
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
24 Mb/s; 36 Mb/s; 54 Mb/s; 6 Mb/s; 9 Mb/s
12 Mb/s; 48 Mb/s
Extra:tsf=0000002f0c6b2d91
Cell 03 - Address: 00:17:33:C6:14:6D
ESSID:"NEUF_146C"
Mode:Master
Channel:11
Encryption key:on
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : CCMP TKIP
12 Mb/s; 48 Mb/s
Extra:tsf=0000002f0c6b326e[/quote]
[quote]# iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wmaster0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:"chezfree"
Mode:Managed Frequency:2.442 GHz Access Point: Not-Associated
Tx-Power=17 dBm
Retry min limit:7 RTS thr:off Fragment thr=2352 B
Encryption key:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
[quote]# lsmod | grep rt61
rt61pci 20960 0
crc_itu_t 2080 1 rt61pci
rt2x00pci 7648 1 rt61pci
rt2x00lib 22432 2 rt61pci,rt2x00pci
eeprom_93cx6 2144 1 rt61pci
A partir d’ici j’ai modifié comme dans le tuto d’ashgenesis.
[quote]# This file describes the network interfaces available on your system
auto lo
allow-hotplug eth0
#config avec DHCP
auto wlan0
iface wlan0 inet dhcp
wpa-conf managed
wpa-ap-scan 1
wpa-scan-ssid 1
wpa-ssid chezfree
wpa-key-mgmt WPA-PSK
#wpa-psk password ##
wpa-psk maclecrypteravecwpa-passphrase
[quote]# /etc/init.d/networking restart
Reconfiguring network interfaces…There is already a pid file /var/run/dhclient.wlan0.pid with pid 1856
killed old client process, removed PID file
Internet Systems Consortium DHCP Client V3.1.1
Copyright 2004-2008 Internet Systems Consortium.
All rights reserved.
For info, please visit isc.org/sw/dhcp/
wmaster0: unknown hardware address type 801
Listening on LPF/wlan0/00:18:f8:b0:19:d9
Sending on LPF/wlan0/00:18:f8:b0:19:d9
Sending on Socket/fallback
There is already a pid file /var/run/dhclient.eth0.pid with pid 1852
Listening on LPF/eth0/00:08:54:54:87:bd
Sending on LPF/eth0/00:08:54:54:87:bd
DHCPRELEASE on eth0 to 192.168.0.254 port 67
send_packet: Network is unreachable
send_packet: please consult README file regarding broadcast address.
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 10
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 12
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 18
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
done.[/quote]
Merci d’avance pour toutes les réponses
